[100%] Linking C executable ../../bin/Release/edgeai-tiovx-modules-test
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_dl_color_convert_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_multi_scaler_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_img_mosaic_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_dl_pre_proc_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_dl_color_blend_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_viss_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_ldc_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_pyramid_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_dof_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_dof_viz_module_test.c.o:(.bss+0x0): multiple definition of `gAppObj'; CMakeFiles/edgeai-tiovx-modules-test.dir/app_tiovx_color_convert_module_test.c.o:(.bss+0x0): first defined here
/usr/bin/ld: warning: libdlr.so, needed by /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLRInputSizeDim'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `DeleteDLRModel'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `RunDLRModel'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `DLRGetLastError'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `CreateDLRModel'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLROutput'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLROutputSizeDim'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLRInputShape'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `SetDLRInput'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLROutputShape'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLRNumOutputs'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLRInputName'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLROutputName'
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/10/../../../../lib/libtivision_apps.so: undefined reference to `GetDLRNumInputs'
collect2: error: ld returned 1 exit status
make[2]: *** [test/CMakeFiles/edgeai-tiovx-modules-test.dir/build.make:290: ../bin/Release/edgeai-tiovx-modules-test] Error 1
make[1]: *** [CMakeFiles/Makefile2:142: test/CMakeFiles/edgeai-tiovx-modules-test.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
Setup FAILED! : Make sure you have active network connection
So, those are my errors.
I am building so far. I am getting closer. I can almost use the webcam to port the edge_ai_apps
to the BBAI-64 but the build creates errors at 100% for the C/C++ files.
P.S. If you are working on this idea, like the fellow that brought this up earlier in the year, please do reply.
I am getting close, i.e. as the /dev/video2
for the webcam can be shown during builds from this repo.
I am currently building the docker
installs on the BBAI-64. I found that listening to the TI docs. was not too workable. So, I will keep building until I can configure it correctly.
