Eeprom in Fritzing
Greetings,
I am very new to all of this and I am working on a project using out new BeagleBone Black. We want to make a cape using the Eeprom but I am struggling getting the Eeprom into Fritzing since the CAT24C256W part is not in there and the Reference Manual does not mention what kind of switches we need (SW1/SW2).
Has anyone Fritzed the Eeprom for the Cape yet that can share their design and parts?
Thank you
Dip switch, jumper, toggle switch, slide switch,…SPDT…normally open, normally closed.
The goal is to connect either of the two pins to ground, or disconnect either of the two pins from ground.
