EHCI not work at custom kernel
Hello
I compile my custom kernel at OpenWrt toolchain, Kernel boot good, but
usb devices connected do USB powered hub not working(not regonized).
I also say that at Angstorn kernel all work good.
Patches was created by comparing the kernel from git (http://
gitorious.org/usb/mainline/commits/ehci) and the original 2.6.29
bootlog:
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from nand
U-Boot 2009.06-rc2 (Jun 05 2009 - 10:19:13)
OMAP3530-GP ES3.0, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision C
Die ID #5ac400030000000004013f8901001001
mmc1 is available
reading boot.scr
** Unable to read "boot.scr" from mmc 0:1 **
reading uImage.bin
1721512 bytes read
reading ramdisk.gz
** Unable to read "ramdisk.gz" from mmc 0:1 **
Booting from mmc ...
## Booting kernel from Legacy Image at 80200000 ...
   Image Name: Linux-2.6.29-svn16127
   Data Size: 1721448 Bytes = 1.6 MB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux...........................................................................................................
Linux version 2.6.29-svn16127 (artek@home) (gcc version 4.1.2) #2 Tue
Jul 14 19:13:27 CEST 2009
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430 ES3.0
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
65024
Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw
rootfstype=ext3 rootwait omapfb.mode=dvi:1280x720M-24@60 os
Unknown boot option `omapfb.mode=dvi:1280x720M-24@60': ignoring
Unknown boot option `omapdss.def_disp=dvi': ignoring
Unknown boot option `omapfb.debug=yes': ignoring
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 1024 (order: 10, 4096 bytes)
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 128MB 128MB = 256MB total
Memory: 256128KB available (3124K code, 294K data, 148K init)
Calibrating delay loop... 479.96 BogoMIPS (lpj=1871872)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 520 bytes
regulator: core version 0.5
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP DMA hardware revision 4.0
bio: create slab <bio-0> at 0
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VMMC1: 1850 <--> 3150 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VUSB1V5: 1500 <--> 0 mV normal standby
regulator: VUSB1V8: 1800 <--> 0 mV normal standby
regulator: VUSB3V1: 3100 <--> 0 mV normal standby
regulator: VPLL2: 1800 mV normal standby
regulator: VSIM: 1800 <--> 3000 mV normal standby
i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
SCSI subsystem initialized
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
Registering mini_fo version $Id$
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 500
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
omapfb: configured for panel omap3beagle
omapfb: DISPC version 3.0 initialized
Console: switching to colour frame buffer device 128x48
omapfb: Framebuffer initialized. Total vram 1572864 planes 1
omapfb: Pixclock 61714 kHz hfreq 57.5 kHz vfreq 74.2 Hz
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
usbcore: registered new interface driver dm9601
i2c /dev entries driver
Driver 'sd' needs updating - please use bus_type methods
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB
1,8V 16-bit)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on "omap2-nand":
0x000000000000-0x000000080000 : "X-Loader"
0x000000080000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x000000680000 : "Kernel"
0x000000680000-0x000010000000 : "File System"
TI TSC210x driver initializing
usbmon: debugfs is not available
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OMAP-EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.29-svn16127 ehci_hcd
usb usb1: SerialNumber: ehci-omap.0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
g_ether gadget: using random self ethernet address
g_ether gadget: using random host ethernet address
usb0: MAC 76:5c:7d:bf:fb:72
usb0: HOST MAC de:f0:d9:ab:89:1b
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.29-svn16127 musb-hcd
usb usb2: SerialNumber: musb_hdrc
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Power Management for TI OMAP3.
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
1
twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:40:38
UTC (946687238)
Waiting for root device /dev/mmcblk0p2...
mmc0: new SD card at address e624
mmcblk0: mmc0:e624 SR064 59.5 MiB
mmcblk0: p1 p2
g_ether gadget: high speed config #1: CDC Ethernet (ECM)
kjournald starting. Commit interval 5 seconds
EXT3 FS on mmcblk0p2, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem) on device 179:2.
Freeing init memory: 148K
Please be patient, while OpenWrt loads ...
- preinit -
Press CTRL-C for failsafe
- init -
Please press Enter to activate this console.
BusyBox v1.13.4 (2009-07-14 18:45:21 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
  _______ ________ __
> >.-----.-----.-----.| | | |.----.| |_
> - || _ | -__| || | | || _|| _|
>_______|| __|_____|__|__||________||__| |____|
          >__| W I R E L E S S F R E E D O M
KAMIKAZE (bleeding edge, r16828) -------------------
  * 10 oz Vodka Shake well with ice and strain
  * 10 oz Triple sec mixture into 10 shot glasses.
  * 10 oz lime juice Salute!
