Anyone seen this before?
Trying to boot 3.0.0 with OE patches from an SD Card, and with a
network cable connected results in the following traceback.
Not connecting a network cable makes the errors go away.
[ 83.386779] Process gtk-update-icon (pid: 351, stack limit = 0xdd95c2f0)
[ 83.393798] Stack: (0xdd95dfb0 to 0xdd95e000)
[ 83.398345] dfa0: 007f9225
007ba664 000000bf 2fffffff
[ 83.406890] dfc0: 00ff2f2f 00ff0000 00ff0000 00ff0000 00ff0000
00ff0000 00000000 00799225
[ 83.415435] dfe0: 00ff0000 be9f8780 000000ff 4027e084 20000010
ffffffff 00000000 00000000
[ 83.423980] Code: bad PC value
[ 83.427490] ---[ end trace 4ae88755f08e391e ]---
[ 83.434570] S98configure[58]: Segmentation fault
[ 83.840148] S98configure[58]: Segmentation fault
[ 83.867004] S98configure[58]: gtk-update-icon-cache: Failed to open
file /usr/share/icons/gnome/.icon-theme.cache : File exists
[ 89.605407] S98configure[58]: gtk-update-icon-cache: Failed to open
file /usr/share/icons/HighContrastLargePrint/.icon-theme.cache : File
exists
[ 89.932525] S98configure[58]: gtk-update-icon-cache: Failed to open
file /usr/share/icons/Mist/.icon-theme.cache : File exists
[ 89.967773] S98configure[58]: gtk-update-icon-cache: Failed to open
[ 91.477386] S98configure[58]: gtk-update-icon-cache: Failed to open
exists
[ 91.788269] S98configure[58]: gtk-update-icon-cache: Failed to open
[ 91.822631] S98configure[58]: gtk-update-icon-cache: Failed to open
[ 94.313598] S98configure[58]: gtk-update-icon-cache: Failed to open
exists
[ 95.381011] S98configure[58]: gtk-update-icon-cache: Failed to open
[ 95.415405] S98configure[58]: gtk-update-icon-cache: Failed to open
[ 99.084899] Unable to handle kernel NULL pointer dereference at
virtual address 00000000
[ 99.093383] pgd = c0004000
[ 99.096191] [00000000] *pgd=00000000
[ 99.099945] Internal error: Oops: 17 [#2]
[ 99.104125] Modules linked in: ipv6
[ 99.107788] CPU: 0 Tainted: G D (3.0.0+ #1)
[ 99.113342] PC is at ehci_quiesce+0xc/0x94
[ 99.117614] LR is at ehci_stop+0x34/0x8c
[ 99.121734] pc : [<c0325ce4>] lr : [<c0328bfc>] psr: 200001d3
[ 99.121734] sp : c064de70 ip : 00000108 fp : c06b8624
[ 99.133728] r10: c064dec0 r9 : 00000000 r8 : dee08504
[ 99.139190] r7 : c0328b94 r6 : 00000100 r5 : dee08504 r4 : dee08608
[ 99.145996] r3 : 00000000 r2 : dee086ec r1 : dee086b8 r0 : dee08608
[ 99.152832] Flags: nzCv IRQs off FIQs off Mode SVC_32 ISA ARM
Segment kernel
[ 99.160644] Control: 10c5387d Table: 9d804019 DAC: 00000015
[ 99.166656] Process swapper (pid: 0, stack limit = 0xc064c2f0)
[ 99.172760] Stack: (0xc064de70 to 0xc064e000)
[ 99.177307] de60: dee08608
dee086b8 dee08608 dee08504
[ 99.185852] de80: 00000100 c0328bfc 00000001 a0000153 dee08504
c007a3d4 00200200 60000153
[ 99.194396] dea0: dee08504 c007a3d4 00200200 c06b87a0 c064c000
c007a3d4 c064c000 00000003
[ 99.202941] dec0: c064dec0 c064dec0 0000000a 00000001 c06b8628
c064c000 00000100 c06b8600
[ 99.211517] dee0: 0000000a c0075ec0 0000a246 c0677bdc 00000000
00000001 00000003 00000025
[ 99.220062] df00: 00000000 c0654258 00000003 00000003 413fc082
00000000 00000000 c0076290
[ 99.228607] df20: 00000025 c0040064 60000053 ffffffff fa200000
c0044ff8 00051f4d 00000000
[ 99.237152] df40: 00051f4d 00000000 c06a662c c0654258 c0654258
[ 99.245697] df60: 00000000 00000000 00000000 c064df80 c0054dcc
c0054dd8 60000053 ffffffff
[ 99.254272] df80: 00000000 00051f4d 00000063 04aae30b 00000063
04a5c3be 00000001 00000000
[ 99.262817] dfa0: c0654248 c0654258 c06d7a6c c0377404 c064c000
c0652254 c06a5d04 c065224c
[ 99.271362] dfc0: 80004059 c0045f40 c064e9b4 c003341c c0ae1140
c0008868 c00082c8 0000060a
[ 99.279907] dfe0: 80000100 c003341c 10c53c7d c064e060 c0033418
8000803c 00000000 00000000
[ 99.288482] [<c0325ce4>] (ehci_quiesce+0xc/0x94) from [<c0328bfc>]
(ehci_stop+0x34/0x8c)
[ 99.296936] [<c0328bfc>] (ehci_stop+0x34/0x8c) from [<c007a3d4>]
(run_timer_softirq+0x15c/0x1f8)
[ 99.306121] [<c007a3d4>] (run_timer_softirq+0x15c/0x1f8) from
[<c064dec0>] (0xc064dec0)
[ 99.314483] Code: c05d7f9a e92d4073 e1a04000 e5903004 (e5933000)
[ 99.320892] ---[ end trace 4ae88755f08e391f ]---
[ 99.325714] Kernel panic - not syncing: Fatal exception in interrupt
Joel
