Hello to all,
Is BeagleBone Black’s ethernet port electrically isolated? Where can I find more information on it ? I want to know if it is, and I cannot find any information on beagleboard.org.
Thank you in advance for your time.
MM
Hello to all,
MM
Yes. The connector has a transformer inside it. All documentation for the board can be found at http://www.elinux.org/Beagleboard:BeagleBoneBlack. The schematic and System Reference Manual are your best sources. http://www.elinux.org/Beagleboard:BeagleBoneBlack#LATEST_PRODUCTION_FILES_.28A6.29
Thank you for your help. The isolation is for 1500 VDC (ethernet standard)?
I looked into the System Reference Manual and the wiki before asking here, but they seem to have no reference to electrical isolation. I will look into them again.
Michael.
Τη Πέμπτη, 7 Νοεμβρίου 2013 4:01:49 μ.μ. UTC+2, ο χρήστης Gerald έγραψε:
Have you ever seen an ethernet port that was functional and did not have a transformer ?
Yes, it is possible to couple the ports using isolation capacitors instead of transformers. This is not unusual in blade/backplane systems.
