For a project we have a couple of BBB. We have ordered them from Element14 .
The problem we have is that the 32kb eeprom is EXACTLY the same for
boards that have a following serial number.
ex : 4002112 has the same eeprom as 4002111
This is unacceptable for us, as we had planned to use that as a unique
ID (since it's supposed to be !!)
You might use the Ethernet interface MAC address to identify the units, as it is unique for each unit. I also think the AM335x 1GHz ARM® Cortex-A8 have serial numbers (the Beagleboard prints it to the serial console during boot) which might also be used to identify different units.
i’m sure it does Gerald
I can send eeprom dumps if necessary, tryed to find a way to get in contact on E14 website, but gave up after trying to find my way on their huge website. If you have a contact i’ll gladly sort it out with them.
I have just received a batch of RevC boards, and eeprom seems to be programmed correctly. I have yet to test them all out, but serial number uses all digits, and eeprom is “cleaner”
(old eeprom had the string 123456789ABCDEF couple of bytes after the serial number)
