Elimination of synchronous return values in BoneScript and return of setup/loop
See https://github.com/jadonk/bonescript/issues/75
Having both synchronous and asynchronous implementations of all the functions has become a pain to maintain. I’ve used node-fibers to ‘my.wait_for’ completion of all asynchronous events in order to provide a synchronous return value, but this means that the synchronous calls must be run within a fiber such that they can block (wait for the callback, but allow the other functions to run). To facilitate this, I’m considering bringing back the setup/run functions. The concern is this will cause some existing applications to break. Please file feedback on this issue if you have strong opinions and/or reply to this e-mail thread.
Example of what will break:
var b = require('bonescript');
b.pinMode('P9_14', b.ANALOG_OUTPUT);
var value = b.analogRead('P9_36');
b.analogWrite('P9_14', value);
This simplest way to make this work synchronously with the new implementation is:
function setup() {
The most desired way to approach this problem is to rewrite your code as asynchronous:
b.pinMode('P9_14', b.ANALOG_OUTPUT, undefined, undefined, undefined, onPinMode);
function onPinMode() {
    b.analogRead('P9_36', onAnalogRead);
function onAnalogRead(x) {
    b.analogWrite('P9_14', x.value);
This has some slightly non-obvious performance advantages if you aren’t familiar with node.js’s asynchronous architecture. It also has the advantage of working over the RPC mechanism that allows you to run BoneScript within a web page and will be the primary method I will teach BoneScript from here on out.
To simplify writing this in the future I’ll handle callbacks in other function argument positions in functions like b.pinMode(pin, mode, callback), rather than requiring all of the arguments. The last argument will always be a callback.
If this just seems unmanageable to you, please let me know!
