Hi!
I am working on a cape which - besides UARTs and other I2C-devices - makes use of a PCA9546 (from NXP) I2C-multiplexer (4 busses).
After trying to enable the mux by
echo pca9546 0x70 > /sys/class/i2c-adapter/i2c-1/new_device
I found out about the patch https://github.com/beagleboard/meta-beagleboard/blob/master/common-bsp/recipes-kernel/linux/linux-mainline-3.8/not-capebus/0111-i2c-DTify-pca954x-driver.patch
So I directed my attention towards the beloved (https://groups.google.com/forum/#!category-topic/beagleboard/beaglebone-capes/Iem_mHknIUM) device tree overlays.
After fiddling around for some time with the exact phrasing of the busses (somewhere it’s referred to as “pca9546-channel” instead of “-bus”, I got some success:
echo ibb-i2c > /sys/devices/bone_capemgr.8/slots
results in
[45340.486940] bone-capemgr bone_capemgr.8: part_number ‘ibb-i2c’, version ‘N/A’
[45340.497671] bone-capemgr bone_capemgr.8: slot #10: generic override
[45340.504492] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 10
[45340.512705] bone-capemgr bone_capemgr.8: slot #10: ‘Override Board Name,00A0,Override Manuf,ibb-i2c’
[45340.522936] bone-capemgr bone_capemgr.8: slot #10: Requesting part number/version based 'ibb-i2c-00A0.dtbo
[45340.533224] bone-capemgr bone_capemgr.8: slot #10: Requesting firmware ‘ibb-i2c-00A0.dtbo’ for board-name ‘Override Board Name’, version ‘00A0’
[45340.555078] bone-capemgr bone_capemgr.8: slot #10: dtbo ‘ibb-i2c-00A0.dtbo’ loaded; converting to live tree
[45340.567104] bone-capemgr bone_capemgr.8: slot #10: #1 overlays
[45340.602194] rtc-ds1307 1-0068: rtc core: registered ds3231 as rtc1
[45340.654809] pca954x 1-0070: registered 0 multiplexed busses for I2C mux pca9546
[45340.677634] bone-capemgr bone_capemgr.8: slot #10: Applied #1 overlays.
Unfortunately, registering 0 multiplexed busses is of no help…
the DTS:
/dts-v1/;
/plugin/;
compatible = “ti,beaglebone”, “ti,beaglebone-black”;
part-number = “ibb-i2c”;
version = “00A0”;
fragment@0 {
target = <&i2c2>;
overlay {
/* shut up DTC warnings */
#address-cells = <1>;
#size-cells = <0>;
/* DS1307 RTC module */
rtc@68 {
compatible = “dallas,ds3231”;
reg = <0x68>;
/* PCA9546 I2C multiplexer */
i2cmux@70 {
#size-cells = <0>;
compatible = “nxp,pca9546”;
reg = <0x70>;
i2c@0 {
#size-cells = <0>;
compatible = “nxp,pca954x-bus”;
reg = <0>;
i2c@1 {
#size-cells = <0>;
reg = <1>;
i2c@2 {
#size-cells = <0>;
reg = <2>;
i2c@3 {
#size-cells = <0>;
reg = <3>;
I tried adding some fake device to the i2c-busses as well, but no success. In reality, there are DS2483 Onewire-interfaces connected to these busses, for which there is no appropriate kernel driver (using owfs).
Any hints?
Best regards,
Robert
