Enable SPI1 on BBB Wireless Debian 10 Kernel 6.1
Dear all,
I am trying to enable SPI1 on the BBB wireless.
When I added only uboot_overlay_addr5=/lib/firmware/BB-SPIDEV1-00A0.dtbo, both spidev0.0 and spidev0.1 appear under /dev/.
I don’t know why I’m getting SPIDEV0 although I enabled SPI1 but at least I see a SPI device.
The big problem occurs when I enabled both SPI0 and SPI1 in /boot/uEnv.txt with all else unchanged.
( In /boot/uEnv.txt like this:
uboot_overlay_addr4=/lib/firmware/BB-SPIDEV0-00A0.dtbo
I don’t see any SPI device under /dev/. Seems like enabling SPI0 somehow disabled all SPIs.
Here is the serial message from booting: looks like both SPIDEV overlays are loaded.
U-Boot 2019.04-g923f8b8 (Jan 02 2022 - 19:05:15 +0000)
CPU  : AM335X-GP rev 2.1
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBoard.org BeagleBone Black Wireless:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   eth0: MII MODE
Could not get PHY for cpsw: addr 0
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[BBBW] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2178 bytes read in 35 ms (60.5 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-6.1.12-bone-rt-r15 ...
10240512 bytes read in 686 ms (14.2 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/6.1.12-bone-rt-r15/am335x-boneblack-uboot-univ.dtb ...
203340 bytes read in 60 ms (3.2 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/6.1.12-bone-rt-r15/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 98 ms (5.9 KiB/s)
uboot_overlays: loading /lib/firmware/BB-SPIDEV0-00A0.dtbo ...
1495 bytes read in 280 ms (4.9 KiB/s)
uboot_overlays: loading /lib/firmware/BB-SPIDEV1-00A0.dtbo ...
1495 bytes read in 358 ms (3.9 KiB/s)
uboot_overlays: loading /boot/dtbs/6.1.12-bone-rt-r15/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1519 bytes read in 107 ms (13.7 KiB/s)
uboot_overlays: uboot loading of [BB-HDMI-TDA998x-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot        _overlay_video=1]...
uboot_overlays: uboot loading of [BB-BBBW-WL1835-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_        overlay_wireless=1]...
loading /boot/initrd.img-6.1.12-bone-rt-r15 ...
7333428 bytes read in 507 ms (13.8 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=        ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:6fe634 88000000] ...
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f901000, end 8ffff634 ... OK
   Loading Device Tree to 8f86c000, end 8f900fff ... OK
Starting kernel ...
Here is my /boot/uEnv.txt file, in case it’s useful:
Thank you very much for any insight!
uname_r=6.1.12-bone-rt-r15
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
###Overide capes with eeprom
#uboot_overlay_addr0=/lib/firmware/BB-I2C1-00A0.dtbo
#uboot_overlay_addr1=/lib/firmware/BB-SPIDEV0-00A0.dtbo
#uboot_overlay_addr2=/lib/firmware/BB-PWM1-00A0.dtbo
#uboot_overlay_addr3=/lib/firmware/BB-PWM2-00A0.dtbo
###Additional custom capes
#uboot_overlay_addr6=/lib/firmware/<file6>.dtbo
#uboot_overlay_addr7=/lib/firmware/<file7>.dtbo
###Custom Cape
#dtb_overlay=/lib/firmware/<file8>.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless/adc)
#disable_uboot_overlay_emmc=1
# According to Beaglebone forum, we need to disable hdmi output to use spi1
disable_uboot_overlay_video=1
disable_uboot_overlay_audio=1
disable_uboot_overlay_wireless=1
#disable_uboot_overlay_adc=1
###PRUSS OPTIONS
###pru_rproc (4.14.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo
###pru_rproc (4.19.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo
###pru_uio (4.14.x-ti, 4.19.x-ti & mainline/bone kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo
###Cape Universal Enable
###Debug: disable uboot autoload of Cape
#disable_uboot_overlay_addr0=1
#disable_uboot_overlay_addr1=1
#disable_uboot_overlay_addr2=1
#disable_uboot_overlay_addr3=1
###U-Boot fdt tweaks... (60000 = 384KB)
#uboot_fdt_buffer=0x60000
cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet video=HDMI-A-1:1024x768@60e
##enable Generic eMMC Flasher:
##make sure, these tools are installed: dosfstools rsync
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
Here is the result from running /opt/scripts/tools/version.sh, in case it is needed:
eeprom:[A335BNLTBWA51712EW001740]
dogtag:[BeagleBoard.org Debian Buster Console Image 2020-04-06]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot SPL 2019.04-g923f8b8 (Jan 02 2022 - 19:05:15 +0000)]:[location: dd MBR]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-g923f8b8]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2019.04-g923f8b8 (Jan 02 2022 - 19:05:15 +0000)]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2019.04-g923f8b8]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[BB-ADC-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.kernel]
UBOOT: Loaded Overlay:[BB-SPIDEV0-00A0]
UBOOT: Loaded Overlay:[BB-SPIDEV1-00A0]
kernel:[6.1.12-bone-rt-r15]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay_addr4=/lib/firmware/BB-SPIDEV0-00A0.dtbo]
uboot_overlay_options:[uboot_overlay_addr5=/lib/firmware/BB-SPIDEV1-00A0.dtbo]
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[disable_uboot_overlay_wireless=1]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~buster+20210821]
pkg:[bb-customizations]:[1.20221108.0-0~buster+20221108]
pkg:[bb-usb-gadgets]:[1.20220816.0-0~buster+20220816]
pkg:[bb-wl18xx-firmware]:[1.20221201.0-0~buster+20221201]
pkg:[kmod]:[26-1]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev gpio pwm eqep remoteproc admin spi iio i2c docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[    2.296462] remoteproc remoteproc0: wkup_m3 is available
[    2.889896] remoteproc remoteproc0: powering up wkup_m3
[    2.889928] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[    2.890165] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   36.111272] remoteproc remoteproc1: 4a334000.pru is available
[   36.127766] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
dmesg | grep pinctrl-single
[    2.318788] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
[    2.804419] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[    2.804640] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[    2.804842] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[    2.805051] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[    2.805461] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[    2.805669] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[    2.805849] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[    2.806061] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[    2.806255] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[    2.806457] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[    2.806509] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_13'
[    2.806517] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[    2.924439] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[    2.924630] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[    2.924768] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[    2.924905] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[    2.925124] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[    2.925262] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[    2.925407] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[    2.925537] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[    2.925686] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[    2.925819] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[    2.926061] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[    2.926272] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[    2.926477] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[    2.926667] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[    2.926853] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[    2.927326] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[    2.927546] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[    2.927756] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[    2.927948] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[    2.928134] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[    2.928326] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[    2.928521] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[    2.928712] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[    2.928914] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[    2.929099] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[    2.929293] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[    2.929470] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[    2.929669] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[    2.929865] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[    2.930046] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[    2.930248] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[    2.930439] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[    2.930623] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[    2.930816] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[    2.930995] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[    2.931713] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[    2.931923] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[    2.932117] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[    2.932310] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[    2.932504] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[    2.932692] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[    2.932879] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[    2.933056] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[    2.933252] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[    2.933446] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[    2.933658] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[    2.934316] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[    2.934544] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[    2.934742] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[    2.934935] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[    2.935334] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[    2.935560] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[    2.935756] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[    2.935950] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[    2.936150] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[    2.936331] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[    2.936540] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[    2.937594] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[    2.938702] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[    2.938944] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[    2.939287] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[    2.939590] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[    2.939882] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[    2.940216] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[    2.940426] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[    2.940638] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[    2.940835] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[    2.941121] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[    2.941342] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[    2.941352] gpio-of-helper ocp:cape-universal: ready
lsusb
Bus 001 Device 002: ID 7392:a812 Edimax Technology Co., Ltd
END
