I have successfully loaded TI-Android pre-built image on a BBB which was downloaded from here. Everything works well on the device. I have been trying to enable adb without much luck. Basic HW and SW is as follows
Hardware
- Beaglebone black.
- 4DCAPE-43T.
- 5V power supply.
- mini usb connection to Ubuntu 12.04 LTS host system.
Software
- TI-Android JB image (TI_Android_JB_4.2.2_DevKit_4.1.1_beagleboneblack.tar.gz).
- Ubuntu 12.04 LTS host system.
On the BBB I have turned on USB debugging by
- App Launcher" → “Settings” → “Developer options”
On the Host side
lsusb output is
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp.
Bus 001 Device 004: ID 10f1:1a52 Importek
/etc/udev/rules.d/51-android.rules
SUBSYSTEM==“usb”, SYSFS{idVendor}==“18d1”, MODE=“0666”
SUBSYSTEM==“usb”, SYSFS{idVendor}==“0451”, MODE=“0666”
I have executed the following two commands
chmod a+r /etc/udev/rules.d/51-android.rules
sudo service udev restart
When I do an
adb devices
I don’t see the BBB, but when I have HTC phone attached I do see a valid response.
What I am doing wrong?
Also I plug the mini-usb to the host machine. Is this correct? Or do I have connect to the serial debugging port.
Hardware
- Beaglebone black.
- 4DCAPE-43T.
- 5V power supply.
Software
This should have been enabled by default. Was this not the case?
On the Host side
lsusb output is
When I do an
adb devices
Yes, you need to connect the mini-usb cable which came with BBB to access adb.
Recheck the connections. You should get an entry for VID 18d1 once adbd is up on BBB.
-Vishveshwar
@Vishveshwar,
I finally got the adb working on BBB. I have posted my results here.
JB422 run well. No complains yet
