Hi guys, I’ve been trying to enable mmc2 on the beagleboard xm expansion board for sdio operations. Been looking into this for over 3 weeks now and tried/read everything on these forums without success, and am increasingly frustrated… I’m very new with embedded linux so please bare with me…
The problem is I simply don’t even see a clock on the SDIO_CLK pin, SDIO_CMD and SDIO_DATA0-4 all are pulled high, but the CLK is at ground with and not enabled.
Can someone provide some simple configuration to enable sdio on mmc2?
have a look at the code for the zippy or zippy2 , both enable the sd/mmc on the expansion.
Dave
Thanks Dave, unfortunately that’s one of the first things I’ve tried, the clk pin stays is ground but all the other pings are pulled high correctly.
