Hi all,
I’m using UART2 channel for serial communication in my bbb. I’ve modified following lines to enable uart2
##Example v4.1.x
#cape_disable=bone_capemgr.disable_partno=
#cape_enable=bone_capemgr.enable_partno=BB-UART2
When I checked the ttyO signals, I could observe following ports
root@beaglebone:~# ls -l /dev/ttyO*
lrwxrwxrwx 1 root root 5 Jan 28 14:17 /dev/ttyO0 → ttyS0
lrwxrwxrwx 1 root root 5 Jan 28 14:17 /dev/ttyO1 → ttyS1
lrwxrwxrwx 1 root root 5 Jan 28 14:17 /dev/ttyO2 → ttyS2
lrwxrwxrwx 1 root root 5 Jan 28 14:17 /dev/ttyO4 → ttyS4
lrwxrwxrwx 1 root root 5 Jan 28 14:17 /dev/ttyO5 → ttyS5
when I tested the uart in loopback mode, I couldn’t receive any data at the channel.
After that, I’ve configured the pin manually as follows
config-pin P9_21 uart
config-pin P9_22 uart
And now, I’m getting data over uart. But, the ttyO signals are the same as follows.
In my understanding, ttyO should be like this
crw-rw---- 1 root tty 247, 0 Jan 1 2000 /dev/ttyO0
crw-rw—T 1 root dialout 247, 2 Jan 1 2000 /dev/ttyO2
Why it’s showing this difference? And what’s the actual method to enable uart?
My BBB has kernel 4.9 and debian OS 9.3
