eQEP error with 4.9 kernel
Has anyone tested the eQEP driver with the 4.9 kernel?
I’m attempting to use it with the 4.9.5-ti-r16 from 2017-01-23.
I get a Segmentation Fault when I read the position:
config-pin p8.11 qep
config-pin p8.12 qep
cat /sys/devices/platform/ocp/48304000.epwmss/48304180.eqep/position
It appears to occur in:
(eqep_get_position [tieqep]) from [] (dev_attr_show+0x2c/0x58)
More details:
https://gist.github.com/pdp7/fe07082d23f2bfbc362c733a7b0aea72
thanks!
drew
I’ve experimenting more with this eQEP error on the 4.9 kernel:
From drivers/misc/tieqep.c at found in this patch:
https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/ti-linux-4.9.y/patches/drivers/ti/eqep
This readl() runs OK in eqep_probe():
https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/ti-linux-4.9.y/patches/drivers/ti/eqep#L401
Line 697: dev_info(&pdev->dev, “QPOSCNT:0x%08x\n”, readl(eqep->mmio_base + QPOSCNT));
But the same readl() causes a seg fault in eqep_get_position():
Line 401: position = readl(eqep->mmio_base + QPOSCNT);
I’m not sure what the difference is. Maybe the memory mapping changes in between the probe and reading the sysfs file?
Any ideas?
thanks,
drew
