Error ./build_kernel.sh step getting Started with beaglebone black
Hello everyone, I am new to learning about beagle bone. I followed the instructions on the link Debian: Getting Started with the BeagleBone Black - Linux Guides - Electronic Component and Engineering Solution Forum - TechForum β”‚ DigiKey
Go to the Linux Kernel step. I follow mainline:
git clone GitHub - RobertCNelson/bb-kernel ./kernelbuildscripts
cd kernelbuildscripts/
and build:
#user@localhost:~/kernelbuildscripts$
./build_kernel.sh
In fact, the correctly executed program will look like the image below, but the build I produce does not have a kernel_version file and deploy file has nothing. I don’t understand the reason why that is so.
So both of us are on the same page post your
system.sh
The build probably failed somewhere in compilation, run ./tools/rebuild.sh again, as it might pop up early again. (One of the issues with multi core building, the build error gets hidden so fast)
Thank you, I have solved the problem
