Hello everyone. I am following the build instructions listed here:
http://www.angstrom-distribution.org/building-angstrom
The tail end of the "bitbake base-image ; bitbake console-image x11-
image " results in:
NOTE: Running task 373 of 6116 (ID: 3923, /home/bjrosas/OE/
openembedded/recipes/xorg-util/util-macros_1.1.6.bb, do_unpack)
NOTE: Applying patch 'gcc-4.0.2-e300c2c3.patch' (recipes/gcc/gcc-4.3.1/
gcc-4.0.2-e300c2c3.patch)
NOTE: Applying patch 'gcc-arm-frename-registers.patch' (recipes/gcc/
gcc-4.3.1/gcc-arm-frename-registers.patch)
NOTE: Applying patch 'PR-36500-fix-neon.patch' (recipes/gcc/gcc-4.3.1/
gcc-release-branch/PR-36500-fix-neon.patch)
NOTE: Applying patch 'gcc-4.3.1-
SYSROOT_CFLAGS_FOR_TARGET.patch' (recipes/gcc/gcc-4.3.1/gcc-4.3.1-
SYSROOT_CFLAGS_FOR_TARGET.patch)
NOTE: Applying patch 'gcc-4.3.1-ARCH_FLAGS_FOR_TARGET.patch' (recipes/
gcc/gcc-4.3.1/gcc-4.3.1-ARCH_FLAGS_FOR_TARGET.patch)
NOTE: Unpacking ../downloads/util-macros-1.1.6.tar.gz to ../angstrom-
dev/work/armv7a-angstrom-linux-gnueabi/util-macros-1_1.1.6-r0/
NOTE: Applying patch 'zecke-xgcc-cpp.patch' (recipes/gcc/gcc-4.3.1/
zecke-xgcc-cpp.patch)
NOTE: Applying patch 'gcc-flags-for-build.patch' (recipes/gcc/
gcc-4.3.1/gcc-flags-for-build.patch)
NOTE: Applying patch 'zecke-no-host-includes.patch' (recipes/gcc/
gcc-4.3.1/zecke-no-host-includes.patch)
ERROR: function do_compile failed
ERROR: see log in /home/bjrosas/OE/angstrom-dev/work/i686-linux/qemu-
native-0.10.3-r1/temp/log.do_compile.10923
NOTE: Task failed: /home/bjrosas/OE/angstrom-dev/work/i686-linux/qemu-
ERROR: TaskFailed event exception, aborting
ERROR: Build of /home/bjrosas/OE/openembedded/recipes/qemu/qemu-
native_0.10.3.bb do_compile failed
NOTE: Running task 374 of 6116 (ID: 3933, /home/bjrosas/OE/
do_distribute_sources)
NOTE: Running task 375 of 6116 (ID: 3924, /home/bjrosas/OE/
openembedded/recipes/xorg-util/util-macros_1.1.6.bb, do_patch)
ERROR: Task 1367 (/home/bjrosas/OE/openembedded/recipes/qemu/qemu-
native_0.10.3.bb, do_compile) failed
NOTE: Waiting for 3 active tasks to finish
NOTE: 1: /home/bjrosas/OE/openembedded/recipes/gettext/gettext-
native_0.17.bb, do_compile (21223)
NOTE: 2: /home/bjrosas/OE/openembedded/recipes/xorg-util/util-
macros_1.1.6.bb, do_patch (24459)
NOTE: 3: /home/bjrosas/OE/openembedded/recipes/xorg-util/util-
macros_1.1.6.bb, do_distribute_sources (24410)
NOTE: Waiting for 2 active tasks to finish
NOTE: Waiting for 1 active tasks to finish
NOTE: Tasks Summary: Attempted 371 tasks of which 328 didn't need to
be rerun and 1 failed.
ERROR: '/home/bjrosas/OE/openembedded/recipes/qemu/qemu-
native_0.10.3.bb' failed
The error log:
/home/bjrosas/OE/angstrom-dev/work/i686-linux/qemu-native-0.10.3-r1/
lists the following error only:
qemu-0.10.3/target-i386/translate.c: In function 'disas_insn':
qemu-0.10.3/target-i386/translate.c:7499: internal compiler error:
Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.4/README.Bugs> for instructions.
make[1]: *** [translate.o] Error 1
make[1]: Leaving directory `/home/bjrosas/OE/angstrom-dev/work/i686-
linux/qemu-native-0.10.3-r1/qemu-0.10.3/x86_64-linux-user'
make: *** [subdir-x86_64-linux-user] Error 2
make: *** Waiting for unfinished jobs....
CC armeb-linux-user/gdbstub-xml.o
CC cris-linux-user/kqemu.o
CC cris-linux-user/translate-all.o
CC cris-linux-user/cpu-exec.o
CC cris-linux-user/translate.o
CC cris-linux-user/host-utils.o
CC cris-linux-user/tcg/tcg.o
CC m68k-linux-user/strace.o
CC m68k-linux-user/mmap.o
qemu-0.10.3/linux-user/mmap.c: In function 'mmap_frag':
qemu-0.10.3/linux-user/mmap.c:255: warning: ignoring return value of
'pread', declared with attribute warn_unused_result
qemu-0.10.3/linux-user/mmap.c: In function 'target_mmap':
qemu-0.10.3/linux-user/mmap.c:472: warning: ignoring return value of
CC m68k-linux-user/signal.o
CC m68k-linux-user/path.o
qemu-0.10.3/linux-user/path.c: In function 'new_entry':
qemu-0.10.3/linux-user/path.c:48: warning: ignoring return value of
'asprintf', declared with attribute warn_unused_result
CC m68k-linux-user/thunk.o
CC m68k-linux-user/elfload.o
AR armeb-linux-user/libqemu.a
CC cris-linux-user/tcg/tcg-runtime.o
CC cris-linux-user/fpu/softfloat-native.o
CC cris-linux-user/op_helper.o
LINK armeb-linux-user/qemu-armeb
CC m68k-linux-user/linuxload.o
CC cris-linux-user/helper.o
CC cris-linux-user/cris-dis.o
CC cris-linux-user/disas.o
CC m68k-linux-user/uaccess.o
CC m68k-linux-user/envlist.o
CC cris-linux-user/i386-dis.o
CC m68k-linux-user/flatload.o
CC cris-linux-user/gdbstub-xml.o
CC m68k-linux-user/m68k-sim.o
linux/qemu-native-0.10.3-r1/qemu-0.10.3/armeb-linux-user'
CC m68k-linux-user/m68k-semi.o
CC m68k-linux-user/gdbstub.o
rm -f gdbstub-xml.c
/bin/sh /home/bjrosas/OE/angstrom-dev/work/i686-linux/qemu-
native-0.10.3-r1/qemu-0.10.3/feature_to_c.sh gdbstub-xml.c /home/
qemu-0.10.3/gdb-xml/cf-core.xml /home/bjrosas/OE/angstrom-dev/work/
i686-linux/qemu-native-0.10.3-r1/qemu-0.10.3/gdb-xml/cf-fp.xml
CC m68k-linux-user/exec.o
AR cris-linux-user/libqemu.a
LINK cris-linux-user/qemu-cris
CC m68k-linux-user/kqemu.o
CC m68k-linux-user/translate-all.o
CC m68k-linux-user/cpu-exec.o
CC m68k-linux-user/translate.o
CC m68k-linux-user/host-utils.o
CC m68k-linux-user/tcg/tcg.o
CC m68k-linux-user/tcg/tcg-runtime.o
linux/qemu-native-0.10.3-r1/qemu-0.10.3/cris-linux-user'
CC m68k-linux-user/fpu/softfloat.o
CC m68k-linux-user/op_helper.o
CC m68k-linux-user/helper.o
qemu-0.10.3/target-m68k/helper.c:346: warning: no previous prototype
for 'cpu_m68k_handle_mmu_fault'
qemu-0.10.3/target-m68k/helper.c:457: warning: no previous prototype
for 'helper_btest'
CC m68k-linux-user/disas.o
CC m68k-linux-user/i386-dis.o
CC m68k-linux-user/m68k-dis.o
CC m68k-linux-user/gdbstub-xml.o
AR m68k-linux-user/libqemu.a
LINK m68k-linux-user/qemu-m68k
linux/qemu-native-0.10.3-r1/qemu-0.10.3/m68k-linux-user'
FATAL: oe_runmake failed
I am using a VM in a Windows XP environment running Ubuntu 9.10. Any
help on this would be appreciated. Thanks.
