error building the android toolchain: missing 'makeinfo'
i'm not sure if there's a separate beagle android mailing list so,
what the heck, i'll ask here. i wanted to build the android
toolchain, downloaded android-toolchain-20081019.tar.bz2 from embinux,
did the "configure", then "make" to get:
WARNING: `makeinfo' is missing on your system. You should only need it if
         you modified a `.texi' or `.texinfo' file, or any other file
         indirectly affecting the aspect of the manual. The spurious
         call might also be the consequence of using a buggy `make' (AIX,
         DU, IRIX). You might want to install the `Texinfo' package or
         the `GNU make' package. Grab either from any GNU archive site.
make[4]: *** [bfd.info] Error 1
make[4]: Leaving directory `/home/rpjday/beagle/android/toolchain/binutils-2.17/bfd/doc'
Making info in po
make[4]: Entering directory `/home/rpjday/beagle/android/toolchain/binutils-2.17/bfd/po'
make[4]: Nothing to be done for `info'.
make[4]: Leaving directory `/home/rpjday/beagle/android/toolchain/binutils-2.17/bfd/po'
make[4]: Entering directory `/home/rpjday/beagle/android/toolchain/binutils-2.17/bfd'
make[4]: Nothing to be done for `info-am'.
make[4]: Leaving directory `/home/rpjday/beagle/android/toolchain/binutils-2.17/bfd'
make[3]: *** [info-recursive] Error 1
make[3]: Leaving directory `/home/rpjday/beagle/android/toolchain/binutils-2.17/bfd'
make[2]: *** [all-bfd] Error 2
make[2]: Leaving directory `/home/rpjday/beagle/android/toolchain/binutils-2.17'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/rpjday/beagle/android/toolchain/binutils-2.17'
make: *** [stmp-build-target-binutils] Error 2
  'makeinfo' is certainly not missing on this system (updated f11
preview):
$ type makeinfo
makeinfo is /usr/bin/makeinfo
  the texinfo package is installed:
$ rpm -q texinfo
texinfo-4.13a-2.fc11.x86_64
  does someone know exactly how binutils checks if a utility is
"missing" so i can figure out how to convince it that makeinfo is
actually there? thanks.
rday
whoops, never mind, i think i have my answer:
http://docwiki.gumstix.org/Buildroot#Makeinfo_.22Missing.22
rday
