error getting shell in beagleboard
I have compiled the linux kernel 3 for the beagle board with the following steps:
$ make omap2plus_defconfig
$ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi- uImage
got the uImage
For rootfs, i have built the busybox with following steps.
$ make menuconfig
Enabled,
  • static binary
  • cross compiler prefix - arm-none-linux-gnueabi-
    then,
    $ make
with this got _install folder inside the busybox folder, then i created the etc, dev, proc,sys and lib forlder
In etc folder, inittab file is created with the content,
::sysinit:/etc/init.rcS
::respawn:/bin/sh
inside the /etc/init.d created the rcS file and filled the content with,
mount -t proc none /proc
mount -t sysfs none /sys
mdev -s
In dev folder, created the console device node with,
$ mknod -m 600 console c 5 1
In lib folder, copied libc and ld-linux library from the arm toolchain
And my kernel command line argument is,
setenv bootargs console=ttyO2,115200 root=/dev/mmcblk0p2 rw rootwait
with this kernel is getting booted and printed the log messages, but finally it struct with executing /bin/sh.
I’ve attached the kernel log,
Can anybody help me to sort out the error which i am doing here?
kernel_log.txt (10.3 KB)
