In anticipation of a shiny new bone being tossed at my doorstep any day now, I would like to be able to build a minimal image using Angstrom. Unfortunately I have not any luck is getting a good build. Works great for Beagleboard though.
MACHINE=beaglebone ./oebb.sh config beaglebone
MACHINE=beaglebone ./oebb.sh update
MACHINE=beaglebone ./oebb.sh bitbake virtual/kernel
Here is the error that I am seeing:
> DEBUG: Trying Upstream
> ERROR: Function 'Fetcher failure for URL: 'file://0001-f_rndis-HACK-around-undefined-variables.patch'. Unable to fetch URL file://0001-f_rndis-HACK-around-undefined-variables.patch from any source.' failed
NOTE: package linux-ti33x-psp-3.1-r2c+gitr1d84d8853fa30cf3db2571a5aec572accca4e29d: task do_fetch: Failed
ERROR: Task 4 (/home/mark/projects/angstrom/setup-scripts/sources/meta-ti/recipes-kernel/linux/linux-ti33x-psp_3.1.bb, do_fetch) failed with exit code '1'
Obviously it cannot get this specific file.
Hmm, this file is present in the repo: History for recipes-kernel/linux/linux-ti33x-psp-3.1/0001-f_rndis-HACK-around-undefined-variables.patch - Angstrom-distribution/meta-ti · GitHub
Should I keep trying and see if this eventually gets resolved
I can't reproduce your error, what kind of filesystem and distro are you using?
Hi Koen,
I'm using Mint 11 and EXT4. Here is a wee bit more information if that helps at all.
DEBUG: Trying PREMIRRORS
DEBUG: For url ['file', '',
'0001-f_rndis-HACK-around-undefined-variables.patch', '', '', {}] comparing ['cvs', '.*', '/.*', '', '', {}] to ['http', 'www.angstrom-distribution.org', '/unstable/sources/', '', '', {}]
'0001-f_rndis-HACK-around-undefined-variables.patch', '', '', {}] comparing ['svn', '.*', '/.*', '', '', {}] to ['http', 'www.angstrom-distribution.org', '/unstable/sources/', '', '', {}]
'0001-f_rndis-HACK-around-undefined-variables.patch', '', '', {}] comparing ['git', '.*', '/.*', '', '', {}] to ['http', 'www.angstrom-distribution.org', '/unstable/sources/', '', '', {}]
'0001-f_rndis-HACK-around-undefined-variables.patch', '', '', {}] comparing ['hg', '.*', '/.*', '', '', {}] to ['http', 'www.angstrom-distribution.org', '/unstable/sources/', '', '', {}]
'0001-f_rndis-HACK-around-undefined-variables.patch', '', '', {}] comparing ['bzr', '.*', '/.*', '', '', {}] to ['http', 'www.angstrom-distribution.org', '/unstable/sources/', '', '', {}]
'0001-f_rndis-HACK-around-undefined-variables.patch', '', '', {}] comparing ['osc', '.*', '/.*', '', '', {}] to ['http', 'www.angstrom-distribution.org', '/unstable/sources/', '', '', {}]
'0001-f_rndis-HACK-around-undefined-variables.patch', '', '', {}] comparing ['p4', '.*', '/.*', '', '', {}] to ['http', 'www.angstrom-distribution.org', '/unstable/sources/', '', '', {}]
'0001-f_rndis-HACK-around-undefined-variables.patch', '', '', {}] comparing ['svk', '.*', '/.*', '', '', {}] to ['http', 'www.angstrom-distribution.org', '/unstable/sources/', '', '', {}]
Mark
