I’m in the process of updating the eMMc image on several Blacks to run the 2013_06_20 image using the eMMc flasher from [1]. 17 of the boards flashed just fine and working. However 5 won’t update. The 4th LED never turns on and I get the following boot messages[2]. It looks like the ext2 partition isn’t there, but when I mount the SD card on my host computer it is there.
Does anyone know what’s going on?
–Mark
[1] http://beagleboard.org/latest-images
[2]
U-Boot 2013.04-dirty (May 06 2013 - 16:12:47)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
cpsw, usb_ether
Hit any key to stop autoboot: 1 0
mmc0 is current device
micro SD card found
SD/MMC found on device 0
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
** No partition table - mmc 0 **
U-Boot#
