Error while running prebuilt oneiric image on beaglebone
Hi everyone,
I am trying to build a prebuilt image of Ubuntu Oneiric on the Beaglebone. I have followed the steps on elinux.org/BeagleBoardUbuntu to get it working.
After putting the memory card into the board and booting, i get stuck at the error
[ 1.561462] brd: module loaded
[ 1.569763] loop: module loaded
[ 1.573242] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.633148] No daughter card found
[ 1.636779] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.652069] AM335X: wrong header 0xffffffff, expected 0xee3355aa
[ 1.658416] The error message above indicates that there is an issue with
[ 1.658447] the EEPROM or the EEPROM contents. After verifying the EEPROM
[ 1.658447] contents, if any, refer to the am335x_evm_setup function in the
[ 1.658447] arch/arm/mach-omap2/board-am335xevm.c file to modify the board
[ 1.658477] initialization code to match the hardware configuration
I am unable to find anyone encountering a similar problem online. Any assistance would be appreciated.
Regards
Mathur
Ah, What revision of the BeagleBone do you have, is it a clone?
