Hi Folks,
i am new to openembedded. Building the images for the beaglebone
causes the following errors. I used openSuse 12.1 as build
environment. Installed the missing rpms as suggested from
openembedded. Before I go into details, I would like to thank you in
advance
kind regards,
Gerrit
The following build steps were used:
1. git clone git://git.angstrom-distribution.org/setup-scripts
2. cd setup-scripts
3. MACHINE=beaglebone ./oebb.sh config beaglebone
4. MACHINE=beaglebone ./oebb.sh update
5. ./oebb.sh bitbake virtual/kernel
6. . ~/.oe/environment-oecore
7. bitbake systemd-image
After invoking ./oebb.sh bitbake virtual/kernel the following output
occurs:
It seems that libtermcap is missing in order to build readline....
isn't it?
Loading cache: 100% |###########################################|
ETA: 00:00:00
Loaded 2613 entries from dependency cache.
OE Build Configuration:
BB_VERSION = "1.15.0"
TARGET_ARCH = "arm"
TARGET_OS = "linux-gnueabi"
MACHINE = "beaglebone"
DISTRO = "angstrom"
DISTRO_VERSION = "v2012.01-core"
TUNE_FEATURES = "armv7a vfp neon cortexa8"
TARGET_FPU = "vfp-neon"
meta-angstrom = "master:9d06c78ee23d7acc8c81d1ef780738c028f1d89d"
meta-oe
meta-efl
meta-gpe
meta-gnome
meta-xfce = "master:18266de7fc4e87754831c5e0e8ad09ccd94c93b4"
meta-opie = "master:d7122fb9047b66ce884bcc946c9e18213c57fa2f"
meta-java = "master:cc04efcf23c40f7ad5915ecc7e41c937de0d0fba"
meta-ti = "master:a4bc237c171152e4d6a014691e7c3060e1fcfd4f"
meta-ettus = "master:f097bb61772d07610d84a668dc19a47e180962b3"
meta-efikamx = "master:2ef47fdd4e8232d766c0c63d9427253ee56e31d0"
meta-nslu2 = "master:17853811179f2760791c6b138f96e9dd15493517"
meta-htc
meta-nokia
meta-openmoko
meta-palm = "master:1cce84865d2d621b6bba9108b7c28626fde46800"
meta-handheld = "master:d76030c7744dfb480c8d43073762d11dcae4893a"
meta-sugarbay
meta-crownbay
meta-emenlow
meta-fishriver
meta-jasperforest
meta-n450 = "master:7c3db7010479970f3f92501349827c517de3c36a"
meta = "master:fff18970706913e7fd7f4a119d798dddb44b388a"
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Running task 219 of 2750 (ID: 2204, virtual:native:/extopt/
beaglebone/angstroem/setup-scripts/sources/openembedded-core/meta/
recipes-core/readline/readline_6.2.bb, do_install)
NOTE: Running task 225 of 2750 (ID: 2235, virtual:native:/extopt/
recipes-extended/bzip2/bzip2_1.0.6.bb, do_compile)
NOTE: package readline-native-6.2-r0: task do_install: Started
NOTE: package bzip2-native-1.0.6-r4: task do_compile: Started
ERROR: Function 'do_install' failed (see /extopt/beaglebone/angstroem/
setup-scripts/build/tmp-angstrom_2010_x-eglibc/work/i686-linux/
readline-native-6.2-r0/temp/log.do_install.7959 for further
information)
ERROR: Logfile of failure stored in: /extopt/beaglebone/angstroem/
Log data follows:
+ cd /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
angstrom_2010_x-eglibc/work/i686-linux/readline-native-6.2-r0/
readline-6.2
+ do_install
+ autotools_do_install
+ oe_runmake DESTDIR=/extopt/beaglebone/angstroem/setup-scripts/
build/tmp-angstrom_2010_x-eglibc/work/i686-linux/readline-native-6.2-
r0/image install
+ '[' xmake = x ']'
+ bbnote make -j2 DESTDIR=/extopt/beaglebone/angstroem/setup-scripts/
r0/image install
+ echo 'NOTE: make -j2 DESTDIR=/extopt/beaglebone/angstroem/setup-
scripts/build/tmp-angstrom_2010_x-eglibc/work/i686-linux/readline-
native-6.2-r0/image install'
NOTE: make -j2 DESTDIR=/extopt/beaglebone/angstroem/setup-scripts/
r0/image install
+ make -j2 DESTDIR=/extopt/beaglebone/angstroem/setup-scripts/build/
tmp-angstrom_2010_x-eglibc/work/i686-linux/readline-native-6.2-r0/
image install
/bin/sh ./support/mkinstalldirs /extopt/beaglebone/angstroem/setup-
native-6.2-r0/image/extopt/beaglebone/angstroem/setup-scripts/build/
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/include \
angstrom_2010_x-eglibc/work/i686-linux/readline-native-6.2-r0/image/
extopt/beaglebone/angstroem/setup-scripts/build/tmp-angstrom_2010_x-
eglibc/sysroots/i686-linux/usr/include/readline /extopt/beaglebone/
angstroem/setup-scripts/build/tmp-angstrom_2010_x-eglibc/work/i686-
linux/readline-native-6.2-r0/image/extopt/beaglebone/angstroem/setup-
scripts/build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib \
eglibc/sysroots/i686-linux/usr/share/info /extopt/beaglebone/angstroem/
readline-native-6.2-r0/image/extopt/beaglebone/angstroem/setup-scripts/
build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/share/man/
man3
test -d shlib || mkdir shlib
( cd shlib ; make - --jobserver-fds=3,4 -j all )
mkdir -p -- /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
eglibc/sysroots/i686-linux/usr/include /extopt/beaglebone/angstroem/
build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/include/
readline /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
eglibc/sysroots/i686-linux/usr/lib /extopt/beaglebone/angstroem/setup-
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/share/info /extopt/
beaglebone/angstroem/setup-scripts/build/tmp-angstrom_2010_x-eglibc/
work/i686-linux/readline-native-6.2-r0/image/extopt/beaglebone/
angstroem/setup-scripts/build/tmp-angstrom_2010_x-eglibc/sysroots/i686-
linux/usr/share/man/man3
for f in readline.h chardefs.h keymaps.h history.h tilde.h rlstdc.h
rlconf.h rltypedefs.h; do \
/usr/bin/install -c -m 644 ./$f /extopt/beaglebone/angstroem/
readline ; \
done
make[1]: Entering directory `/extopt/beaglebone/angstroem/setup-
native-6.2-r0/readline-6.2/shlib'
rm -f libreadline.so.6.2
gcc -shared -Wl,-soname,libreadline.so.6.2 -L/extopt/beaglebone/
linux/usr/lib -Wl,-rpath-link,/extopt/beaglebone/angstroem/setup-
scripts/build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib -
Wl,-rpath,/extopt/beaglebone/angstroem/setup-scripts/build/tmp-
angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib -Wl,-O1 -L./lib/
termcap -Wl,-rpath,/extopt/beaglebone/angstroem/setup-scripts/build/
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib -Wl,-
soname,`basename libreadline.so.6.2 .2` -o libreadline.so.6.2
readline.so vi_mode.so funmap.so keymaps.so parens.so search.so
rltty.so complete.so bind.so isearch.so display.so signals.so util.so
kill.so undo.so macro.so input.so callback.so terminal.so text.so
nls.so misc.so xmalloc.so xfree.so history.so histexpand.so
histfile.so histsearch.so shell.so mbutil.so tilde.so compat.so -
ltermcap
( if test -d doc ; then \
cd doc && \
make - --jobserver-fds=3,4 -j infodir=/extopt/beaglebone/
linux/usr/share/info DESTDIR=/extopt/beaglebone/angstroem/setup-
native-6.2-r0/image install; \
fi )
native-6.2-r0/readline-6.2/doc'
/bin/sh ../support/mkdirs /extopt/beaglebone/angstroem/setup-scripts/
r0/image/extopt/beaglebone/angstroem/setup-scripts/build/tmp-
if test -n "" ; then \
native-6.2-r0/image ; \
fi
if test -f readline.info; then \
/usr/bin/install -c -m 644 readline.info /extopt/beaglebone/
scripts/build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/share/
info/readline.info; \
else \
/usr/bin/install -c -m 644 ./readline.info /extopt/beaglebone/
fi
/usr/lib/gcc/i586-suse-linux/4.6/../../../../i586-suse-linux/bin/ld:
cannot find -ltermcap
collect2: ld returned 1 exit status
make[1]: *** [libreadline.so.6.2] Error 1
make[1]: Leaving directory `/extopt/beaglebone/angstroem/setup-
make: [shared] Error 2 (ignored)
( cd examples ; make - --jobserver-fds=3,4 -j DESTDIR=/extopt/
work/i686-linux/readline-native-6.2-r0/image install )
if test -f rluserman.info; then \
/usr/bin/install -c -m 644 rluserman.info /extopt/beaglebone/
info/rluserman.info; \
else \
/usr/bin/install -c -m 644 ./rluserman.info /extopt/beaglebone/
fi
native-6.2-r0/readline-6.2/examples'
angstrom_2010_x-eglibc/sysroots/i686-linux/usr/share/readline
if test -f history.info; then \
/usr/bin/install -c -m 644 history.info /extopt/beaglebone/
info/history.info; \
else \
/usr/bin/install -c -m 644 ./history.info /extopt/beaglebone/
fi
if /bin/sh -c 'install-info --version' >/dev/null 2>&1; then \
install-info --dir-file=/extopt/beaglebone/angstroem/setup-
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/share/info/dir \
eglibc/sysroots/i686-linux/usr/share/info/readline.info ; \
eglibc/sysroots/i686-linux/usr/share/info/history.info ; \
eglibc/sysroots/i686-linux/usr/share/info/rluserman.info ; \
else true; fi
/usr/bin/install -c -m 644 ./readline.3 /extopt/beaglebone/angstroem/
man3/readline.3
/usr/bin/install -c -m 644 ./history.3 /extopt/beaglebone/angstroem/
man3/history.3
if test -f readline.html; then \
/usr/bin/install -c -m 644 readline.html /extopt/
work/i686-linux/readline-native-6.2-r0/image/readline.html; \
else \
/usr/bin/install -c -m 644 ./readline.html /extopt/
fi ; \
if test -f history.html; then \
/usr/bin/install -c -m 644 history.html /extopt/
work/i686-linux/readline-native-6.2-r0/image/history.html; \
else \
/usr/bin/install -c -m 644 ./history.html /extopt/
fi ; \
if test -f rluserman.html; then \
/usr/bin/install -c -m 644 rluserman.html /extopt/
work/i686-linux/readline-native-6.2-r0/image/rluserman.html; \
else \
/usr/bin/install -c -m 644 ./rluserman.html /extopt/
fi ; \
fi
( cd shlib ; make - --jobserver-fds=3,4 -j DESTDIR=/extopt/
angstrom_2010_x-eglibc/sysroots/i686-linux/usr/bin
mkdir /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
ltermcap
mv /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
eglibc/sysroots/i686-linux/usr/lib/libreadline.a /extopt/beaglebone/
scripts/build/tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib/
libreadline.old
mv: cannot stat `/extopt/beaglebone/angstroem/setup-scripts/build/
angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib/libreadline.a': No
such file or directory
make: [install-static] Error 1 (ignored)
/usr/bin/install -c -m 644 libreadline.a /extopt/beaglebone/
libreadline.a
test -n "ranlib" && ranlib /extopt/beaglebone/angstroem/setup-
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib/libreadline.a
eglibc/sysroots/i686-linux/usr/lib/libhistory.a /extopt/beaglebone/
libhistory.old
angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib/libhistory.a': No
/usr/bin/install -c -m 644 libhistory.a /extopt/beaglebone/angstroem/
libhistory.a
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib/libhistory.a
rm -f libhistory.so.6.2
gcc -shared -Wl,-soname,libhistory.so.6.2 -L/extopt/beaglebone/
soname,`basename libhistory.so.6.2 .2` -o libhistory.so.6.2 history.so
histexpand.so histfile.so histsearch.so shell.so mbutil.so xmalloc.so
xfree.so -ltermcap
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [libhistory.so.6.2] Error 1
make: [install-shared] Error 2 (ignored)
+ '[' -e /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
eglibc/sysroots/i686-linux/usr/share/info/dir ']'
+ rm -f /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
+ oe_libinstall -so -C shlib libhistory /extopt/beaglebone/angstroem/
+ dir=
+ libtool=
+ silent=
+ require_static=
+ require_shared=
+ staging_install=
+ '[' 5 -gt 0 ']'
+ case "$1" in
+ require_shared=1
+ shift
+ '[' 4 -gt 0 ']'
+ case "$1" in
+ shift
+ dir=shlib
+ shift
+ '[' 2 -gt 0 ']'
+ case "$1" in
+ break
+ libname=libhistory
+ shift
+ destpath=/extopt/beaglebone/angstroem/setup-scripts/build/tmp-
+ '[' -z /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
eglibc/sysroots/i686-linux/usr/lib ']'
+ echo /extopt/beaglebone/angstroem/setupERROR: Function
'do_install' failed (see /extopt/beaglebone/angstroem/setup-scripts/
r0/temp/log.do_install.7959 for further information)
-scripts/build/tmp-angstrom_2010_x-eglibc/work/i686-linux/readline-
+ egrep '^/extopt/beaglebone/angstroem/setup-scripts/build/tmp-
angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib/'
+ '[' -z shlib ']'
+ dotlai=libhistory.lai
++ cd shlib
++ wc -l
++ find . -name libhistory.lai
+ number_of_files=0
+ '[' 0 -gt 1 ']'
++ cd shlib
++ sed 's/^\.//;s/\/libhistory.lai$//;q'
+ dir=shlib
++ pwd
+ olddir=/extopt/beaglebone/angstroem/setup-scripts/build/tmp-
readline-6.2
+ __runcmd cd shlib
+ '[' -z '' ']'
+ echo 'oe_libinstall: cd shlib'
+ cd shlib
+ lafile=libhistory.la
+ '[' '!' -f libhistory.la ']'
++ echo libhistory
++ sed 's/-[0-9.]*$//'
+ libname1=libhistory
+ lafile1=libhistory.la
+ '[' -f libhistory.la ']'
+ library_names='libhistory.so* libhistory.dll.a libhistory.*.dylib'
+ __runcmd install -d /extopt/beaglebone/angstroem/setup-scripts/
+ '[' -z '' ']'
+ echo 'oe_libinstall: install -d /extopt/beaglebone/angstroem/setup-
tmp-angstrom_2010_x-eglibc/sysroots/i686-linux/usr/lib/'
oe_libinstall: install -d /extopt/beaglebone/angstroem/setup-scripts/
+ install -d /extopt/beaglebone/angstroem/setup-scripts/build/tmp-
+ dota=libhistory.a
+ '[' -f libhistory.a -o -n '' ']'
+ '[' -f libhistory.lai -a -n '' ']'
+ for name in '$library_names'
++ eval echo 'libhistory.so*'
+++ echo 'libhistory.so*'
+ files='libhistory.so*'
+ for f in '$files'
+ '[' '!' -e 'libhistory.so*' ']'
+ '[' -n '' ']'
++ eval echo libhistory.dll.a
+++ echo libhistory.dll.a
+ files=libhistory.dll.a
+ for f in '$files'
+ '[' '!' -e libhistory.dll.a ']'
+ '[' -n '' ']'
++ eval echo 'libhistory.*.dylib'
+++ echo 'libhistory.*.dylib'
+ files='libhistory.*.dylib'
+ for f in '$files'
+ '[' '!' -e 'libhistory.*.dylib' ']'
+ '[' -n '' ']'
+ '[' -z '' ']'
+ '[' -n 1 ']'
+ bbfatal 'oe_libinstall: unable to locate shared library'
+ echo 'ERROR: oe_libinstall: unable to locate shared library'
+ exit 1
NOTE: package readline-native-6.2-r0: task do_install: Failed
ERROR: Task 2204 (virtual:native:/extopt/beaglebone/angstroem/setup-
scripts/sources/openembedded-core/meta/recipes-core/readline/
readline_6.2.bb, do_install) failed with exit code '1'
Waiting for 1 active tasks to finish:
0: bzip2-native-1.0.6-r4 do_compile (pid 7960)
NOTE: package bzip2-native-1.0.6-r4: task do_compile: Succeeded
ERROR: 'virtual:native:/extopt/beaglebone/angstroem/setup-scripts/
sources/openembedded-core/meta/recipes-core/readline/readline_6.2.bb'
failed
