For this no exact timings are needed...I only want in beforehand,
how long approximatly this adventure will take...and whether it is
possible (Swap of an external hd is available...)...so:
Is it possible and if yes: how long will it take to compile a linux
3.2 kernel (the Robert Nelson kernel) with the original defconfig on a
beagle bone white/classic natively???
Thank you very much in advance for any help!
Best regards
mcc
4-7 hours... Mostly depending on how fast your drive is..
Robert Nelson <robertcnelson@gmail.com> [13-07-19 13:56]:
Do you usually attach storage directly to the BeagleBone (if so, what
exactly), or use nfs?
I tried a few high-speed USB keys, but had better results with nfs (and
with nfs I can keep everything together on my server, protected by RAID
and regular backups).
...now if there was just a GigE option for the 'Bone.
Externally powered sata drives with usb adapter.
I've had real good luck with these: "filemate 3fme2500gw" mostly as
they are the only usb-sata adapter I've found that has a secondary
5volt power connector, so you aren't sourcing all the power from the
usb hub on the beagle...
Robert Nelson <robertcnelson@gmail.com> [13-07-19 14:20]:
>>> Hi,
Robert Nelson
http://www.rcn-ee.com/
For more options, visit http://beagleboard.org/discuss
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out.
Just an addition cause I struggled about it:
1.) External USB drive attached to the beaglebone: No reachtion at
all.
2.) External USB drive attached to an USB hub (not powered): The
electronic of the hd wakes up, the kernel recognizes the drive
correctly but when doing something with it, dmesg reports
"Drives not ready" (read: motor does not spin up).
3.) Same as 2.) : Drive fully functional.
May depend on the hd model, though...
Best regads,
mcc
Hello Robert,
Do you have a rough estimate of read / write speeds ?
With a NFS rootfs I am getting around 11.1MB/s writes, and 11.9MB/s reads. using rsize=32768,wsize=32768
I would assume the USB<->SATA adapters would be faster but . . . you never know.
Imho nfs is the best because it is free - you have Ethernet and a PC with plenty of free space. Usb sata drives are capable to achieve 30MB/s but do you need so much to just compile a kernel? I believe when compiling kernel the most of time is spent on compilation itself rather then to write to a disk. Use nfs for free
