ethernet gadget with beagleboard
I have trouble using ethernet usb gadget driver on the beagleboard (omap3530).
I am using SDK 4.2.0.7 for the kernel, I’ve compiled it with beaglebpoard config, so everything is expected to work as required on this EVM.
I have compiled both kernel and modules with ethernet gadget module enabled, but on trying to insmod the driver, I get the following;
root@beagleboard:/lib/modules/2.6.37/kernel/drivers/usb/gadget# insmod g_ether.ko
insmod: error inserting ‘g_ether.ko’: -1 No such device
Did anyone encounter such failure ?
Attached boot log.Regards,
Ran
usb_err.txt (45.2 KB)
I suspect it is related to the following error:
Welcome to The ֵngstrצm Distribution!
[ 3.811035] <28>systemd[1]: /sbin/modprobe failed with error code 1.
[ 3.822387] <30>systemd[1]: Set hostname to <beagleboard>.
[ 3.843353] <28>systemd[1]: CONFIG_CGROUPS was not set when your kernel
was compiled. Systems without control groups are not supported. We will now
sleep for 10s, and then continue boot-up. Expect breakage and please do not
file bugs. Instead fix your kernel and enable CONFIG_CGROUPS.
[ 13.897247] <28>systemd[1]: No control group support available, not
creating root group.
[ 14.307220] <27>systemd[1]: Failed to open /dev/autofs: No such file or
directory
[ 14.315338] <27>systemd[1]: Failed to initialize automounter: No such
file or directory
[ 14.323974] <29>systemd[1]: Unit proc-sys-fs-binfmt_misc.automount
entered failed state.
Starting Runtime Directory...
Is anyone familiar with it ?
Ran
It should be pretty obvious, it's actually telling you twice what
kernel config your missing..
Hint: it's telling you your kernel is mis-configured, add the config
option and reboot..
Hi Robert,
Thanks for the hint,
But I re-check the config and it seems that all relevant USB flags are configured correctly:
CONFIG_V4L_USB_DRIVERS=y
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
CONFIG_SND_USB=y
CONFIG_USB_HID=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB=y
CONFIG_USB_DEVICE_CLASS=y
CONFIG_USB_MUSB_HDRC=y
CONFIG_USB_MUSB_OMAP2PLUS_GLUE=y
CONFIG_USB_MUSB_OMAP2PLUS=y
CONFIG_USB_MUSB_PERIPHERAL=y
CONFIG_USB_GADGET_MUSB_HDRC=y
CONFIG_USB_INVENTRA_DMA_HW=y
CONFIG_USB_INVENTRA_DMA=y
CONFIG_MUSB_USE_SYSTEM_DMA_WORKAROUND=y
CONFIG_USB_MUSB_DEBUG=y
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_SELECTED=y
CONFIG_USB_GADGET_DUALSPEED=y
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
CONFIG_USB_FILE_STORAGE=m
CONFIG_USB_OTG_UTILS=y
Do you find anything missing ?
Ran
kernel was compiled. Systems without control groups are not supported.
We will now sleep for 10s, and then continue boot-up. Expect breakage
and please do not file bugs. Instead fix your kernel and enable
CONFIG_CGROUPS.
Hi Robert,
Thank you very much.
I was lazy not to notice that…
It now seems better (less errors on boot), but still fails with same error:
Can you give me another hint what might cause such failure?
This is the boot log:
Last login: Thu Jan 12 12:31:58 GMT 2012 on ttyO2
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~# modprobe g_ether
[ 30.667053] g_ether: disagrees about version of symbol module_layout
FATAL: Error inserting g_ether (/lib/modules/2.6.37/kernel/drivers/usb/gadget/g_ether.ko): Invalid module format
root@beagleboard:~# d
Texas Instruments X-Loader 1.5.0 (Jun 14 2011 - 22:04:07)
Beagle Rev C5
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.06-rc2 (Jan 15 2015 - 11:12:37)
, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 512 MiB
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #74aa000700000000015a676401014023
mmc1 is available
reading uImage
2918324 bytes read
Booting kernel from Legacy Image at 80300000 …
Image Name: Linux-2.6.37
Data Size: 2918260 Bytes = 2.8 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
[ 0.000000] Linux version 2.6.37 (ubuntu@ubuntu-laptop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #7 Thu Jan 15 18:09:40 IST 2015
[ 0.000000] CPU: ARMv7 Processor [411fc087] revision 7 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Reserving 4194304 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430/3530 ES3.1.2 (l2cache iva sgx neon isp 720mhz )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64000
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=/dev/mmcblk0p2 rw rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 252MB = 252MB total
[ 0.000000] Memory: 242740k/242740k available, 19404k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc003a000 ( 200 kB)
[ 0.000000] .text : 0xc003a000 - 0xc0568f4c (5308 kB)
[ 0.000000] .data : 0xc056a000 - 0xc071f1a0 (1749 kB)
[ 0.000000] NR_IRQS:409
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
[ 0.000000] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
[ 0.000000] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
[ 0.000000] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] GPMC revision 5.0
[ 0.000000] Trying to install interrupt handler for IRQ402
[ 0.000000] Trying to install interrupt handler for IRQ403
[ 0.000000] Trying to install interrupt handler for IRQ404
[ 0.000000] Trying to install interrupt handler for IRQ405
[ 0.000000] Trying to install interrupt handler for IRQ406
[ 0.000000] Trying to install interrupt handler for IRQ407
[ 0.000000] Trying to install interrupt handler for IRQ408
[ 0.000000] Trying to install type control for IRQ409
[ 0.000000] Trying to set irq flags for IRQ409
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Lock dependency validator: Copyright © 2006 Red Hat, Inc., Ingo Molnar
[ 0.000000] … MAX_LOCKDEP_SUBCLASSES: 8
[ 0.000000] … MAX_LOCK_DEPTH: 48
[ 0.000000] … MAX_LOCKDEP_KEYS: 8191
[ 0.000000] … CLASSHASH_SIZE: 4096
[ 0.000000] … MAX_LOCKDEP_ENTRIES: 16384
[ 0.000000] … MAX_LOCKDEP_CHAINS: 32768
[ 0.000000] … CHAINHASH_SIZE: 16384
[ 0.000000] memory used by lock dependency info: 3951 kB
[ 0.000000] per task-struct memory footprint: 2304 bytes
[ 0.000000] Calibrating delay loop… 456.86 BogoMIPS (lpj=1781760)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] regulator: dummy:
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.000000] OMAP3 Beagle Rev: C4
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.000000] OMAP DMA hardware revision 4.0
[ 0.122314] bio: create slab at 0
[ 0.133697] SCSI subsystem initialized
[ 0.147491] usbcore: registered new interface driver usbfs
[ 0.149322] usbcore: registered new interface driver hub
[ 0.150878] usbcore: registered new device driver usb
[ 0.157501] omap_device: omap_i2c.1: new worst case activate latency 0: 30517
[ 0.157684] omap_i2c omap_i2c.1: bus 1 rev3.12 at 2600 kHz
[ 0.172485] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 0.172729] twl4030: power (irq 373) chaining IRQs 376…383
[ 0.175842] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 0.192443] regulator: VMMC1: 1850 <–> 3150 mV at 3000 mV normal standby
[ 0.196044] regulator: VDAC: 1800 mV normal standby
[ 0.199615] regulator: VDVI: 1800 mV normal standby
[ 0.203613] regulator: VSIM: 1800 <–> 3000 mV at 1800 mV normal standby
[ 0.207763] regulator: VAUX3: 1800 mV normal standby
[ 0.211334] regulator: VAUX4: 1800 mV normal standby
[ 0.211914] omap_device: omap_i2c.1: new worst case deactivate latency 0: 61035
[ 0.221954] omap_i2c omap_i2c.2: bus 2 rev3.12 at 400 kHz
[ 0.236083] omap_i2c omap_i2c.3: bus 3 rev3.12 at 100 kHz
[ 0.246398] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.251586] Switching to clocksource 32k_counter
[ 0.440246] musb-hdrc: version 6.0, peripheral, debug=0
[ 0.440673] musb-hdrc musb-hdrc.0: degrade from otg to peripheral-only mode
[ 0.440795] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.440826] HS USB OTG: no transceiver configured
[ 0.440856] musb-hdrc musb-hdrc.0: musb_init_controller failed with status -19
[ 0.442718] NET: Registered protocol family 2
[ 0.443664] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.446136] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.446746] TCP bind hash table entries: 8192 (order: 6, 360448 bytes)
[ 0.452423] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.452545] TCP reno registered
[ 0.452606] UDP hash table entries: 128 (order: 1, 12288 bytes)
[ 0.453033] UDP-Lite hash table entries: 128 (order: 1, 12288 bytes)
[ 0.454437] NET: Registered protocol family 1
[ 0.456481] RPC: Registered udp transport module.
[ 0.456512] RPC: Registered tcp transport module.
[ 0.456542] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.457855] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.461059] platform iva.0: Enabled OPP corresponding to 720MHz
[ 0.465179] omap-iommu omap-iommu.0: isp registered
[ 0.466308] OMAP35x Linux PSP version 04.02.00.07 (OMAP3BEAGLE)
[ 0.654205] VFS: Disk quotas dquot_6.5.2
[ 0.654388] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.657714] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.659271] msgmni has been set to 474
[ 0.665100] io scheduler noop registered
[ 0.665191] io scheduler deadline registered
[ 0.665435] io scheduler cfq registered (default)
[ 0.728576] OMAP DSS rev 2.0
[ 0.729248] OMAP DISPC rev 3.0
[ 0.729431] OMAP VENC rev 2
[ 0.730957] OMAP DSI rev 1.0
[ 1.060791] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.073242] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.076141] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.078155] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.821472] console [ttyO2] enabled
[ 1.889343] brd: module loaded
[ 1.923370] loop: module loaded
[ 1.935363] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.942352] omap2-nand driver initializing
[ 1.947479] ONFI flash detected
[ 1.951019] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron )
[ 1.958160] Creating 5 MTD partitions on “omap2-nand.0”:
[ 1.963836] 0x000000000000-0x000000080000 : “X-Loader”
[ 1.982055] 0x000000080000-0x000000260000 : “U-Boot”
[ 1.997100] 0x000000260000-0x000000280000 : “U-Boot Env”
[ 2.011535] 0x000000280000-0x000000680000 : “Kernel”
[ 2.027618] 0x000000680000-0x000020000000 : “File System”
[ 2.298248] OneNAND driver initializing
[ 2.315246] mice: PS/2 mouse device common for all mice
[ 2.324920] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 2.343780] omap_device: omap_i2c.1: new worst case activate latency 0: 91552
[ 2.352966] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 2.372009] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 2.379119] twl_rtc twl_rtc: Power up reset detected.
[ 2.385589] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 2.393066] i2c /dev entries driver
[ 2.405456] Linux media interface: v0.10
[ 2.410736] Linux video capture interface: v2.00
[ 2.418273] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[ 2.425506] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[ 2.433227] omap3isp omap3isp: Revision 2.0 found
[ 2.438476] omap-iommu omap-iommu.0: isp: version 1.1
[ 2.559204] omap_i2c omap_i2c.2: Arbitration lost
[ 2.580078] mt9v113 2-003c: chip id mismatch read 0x0, expecting 0x2280
[ 2.597198] isp_register_subdev_group: Unable to register subdev mt9v113
[ 2.605865] omap_device: omap_wdt.-1: new worst case activate latency 0: 30517
[ 2.616241] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 2.622711] omap_device: omap_wdt.-1: new worst case deactivate latency 0: 30517
[ 2.632354] twl4030_wdt twl4030_wdt: Failed to register misc device
[ 2.639099] twl4030_wdt: probe of twl4030_wdt failed with error -16
[ 2.668334] usbcore: registered new interface driver usbhid
[ 2.674285] usbhid: USB HID core driver
[ 2.686126] ALSA device list:
[ 2.689392] No soundcards found.
[ 2.692962] oprofile: hardware counters not available
[ 2.698333] oprofile: using timer interrupt.
[ 2.703430] TCP cubic registered
[ 2.706939] Initializing XFRM netlink socket
[ 2.711639] NET: Registered protocol family 17
[ 2.716613] NET: Registered protocol family 15
[ 2.722045] Registering the dns_resolver key type
[ 2.727783] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 2.737945] ThumbEE CPU extension supported.
[ 2.764984] Power Management for TI OMAP3.
[ 2.770355] sr_init: No PMIC hook to init smartreflex
[ 2.776336] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 2.785644] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 2.795776] SmartReflex Class3 initialized
[ 2.863677] clock: disabling unused clocks to save power
[ 2.872497] platform iva.0: omap_voltage_scale: Already at the requestedrate 360000000
[ 2.880920] platform mpu.0: omap_voltage_scale: Already at the requestedrate 500000000
[ 2.889343] platform l3_main.0: omap_voltage_scale: Already at the requestedrate 166000000
[ 2.931488] omap_device: omap_i2c.1: new worst case deactivate latency 0: 122070
[ 2.940246] regulator_init_complete: incomplete constraints, leaving VDAC on
[ 2.952911] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 2.962005] omap_vout omap_vout: Buffer Size = 3686400
[ 2.971313] omap_vout omap_vout: : registered and initialized video device 15
[ 2.978973] omap_vout omap_vout: Buffer Size = 3686400
[ 2.987640] omap_vout omap_vout: : registered and initialized video device 16
[ 3.002319] Waiting for root device /dev/mmcblk0p2…
[ 3.166046] mmc0: new high speed SDHC card at address aaaa
[ 3.175537] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[ 3.200164] mmcblk0: p1 p2
[ 3.232910] EXT3-fs: barriers not enabled
[ 3.312805] kjournald starting. Commit interval 5 seconds
[ 3.319183] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 3.333465] EXT3-fs (mmcblk0p2): using internal journal
[ 3.339080] EXT3-fs (mmcblk0p2): recovery complete
[ 3.347442] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 3.355468] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 3.362091] Freeing init memory: 200K
Failed to open /dev/kmsg for logging: No such file or directory
[ 3.685821] <30>systemd[1]: systemd 37 running in system mode. (+PAM +LIBWRAP -AUDIT -SELINUX +SYSVINIT -LIBCRYPTSETUP; angstrom)
[ 3.784942] <28>systemd[1]: /sbin/modprobe failed with error code 1.
[ 3.796173] <30>systemd[1]: Set hostname to .
[ 4.271270] <27>systemd[1]: Failed to open /dev/autofs: No such file or directory
[ 4.279388] <27>systemd[1]: Failed to initialize automounter: No such file or directory
[ 4.288024] <29>systemd[1]: Unit proc-sys-fs-binfmt_misc.automount entered failed state.
Starting Runtime Directory…
Starting Remount API VFS…
Starting Lock Directory…
Starting Media Directory…
Started Apply Kernel Variables [ OK ]
Started Huge Pages File System [ OK ]
Starting POSIX Message Queue File System…
Starting File System Check on Root Device…
Started Load Kernel Modules [ OK ]
Started Configuration File System [ OK ]
Started FUSE Control File System [ OK ]
Started Set Up Additional Binary Formats [ OK ]
[ 4.773223] <30>systemd-fsck[591]: Root directory is writable, skipping check.
Starting Debug File System…
Started Security File System [ OK ]
Starting Syslog Kernel Log Buffer Bridge…
Started Syslog Kernel Log Buffer Bridge [ OK ]
Starting udev Coldplug all Devices…
Starting udev Kernel Device Manager…
Started Runtime Directory [ OK ]
Started Remount API VFS [ OK ]
Started Lock Directory [ OK ]
[ 5.108489] <30>udevd[599]: starting version 175
Started udev Kernel Device Manager [ OK ]
Started Media Directory [ OK ]
Started POSIX Message Queue File System [ OK ]
Started File System Check on Root Device [ OK ]
Started Debug File System [ OK ]
Starting Remount Root FS…
Starting STDOUT Syslog Bridge…
Started STDOUT Syslog Bridge [ OK ]
Started Remount Root FS [ OK ]
Started Opkg first boot configure [ OK ]
Starting /tmp…
Started Machine ID first boot configure [ OK ]
Started /tmp [ OK ]
Starting Load Random Seed…
Starting Recreate Volatile Files and Directories…
Started Load Random Seed [ OK ]
Started Recreate Volatile Files and Directories [ OK ]
Starting Console System Startup Logging…
Starting xinetd.service…
Started Angstrom LED config [ OK ]
Starting Timestamping service…
Started Timestamping service [ OK ]
Starting Network Manager…
Started SSH Key Generation [ OK ]
Starting System Logging Service…
Starting Permit User Sessions…
Starting Login Service…
Starting Avahi mDNS/DNS-SD Stack…
Starting Periodic Command Scheduler…
Started Periodic Command Scheduler [ OK ]
Starting internet superserver: xinetdStarting D-Bus System Message Bus…
Starting Disk Manager…
[ 7.560455] <27>systemd-logind[694]: Failed to open /sys/class/tty/tty0/active: No such file or directory
[ 7.666564] <27>systemd-logind[694]: Failed to fully start up daemon: No such file or directory
Started Console System Startup Logging [ OK ]
Started Permit User Sessions [ OK ]
[ 7.854370] <75>/usr/sbin/crond[699]: (CRON) INFO (Syslog will be used instead of sendmail.): No such file or directory
[ 7.894531] <29>systemd[1]: systemd-logind.service: main process exited, code=exited, status=1
Failed to start Login Service [FAILED]
See ‘systemctl status systemd-logind.service’ for details.
[ 8.455841] <29>systemd[1]: Unit systemd-logind.service entered failed state.
[ 8.494506] <30>avahi-daemon[697]: Found user ‘avahi’ (UID 998) and group ‘avahi’ (GID 996).
[ 8.679992] <30>avahi-daemon[697]: Successfully dropped root privileges.
Started xinetd.service [ OK ]
[ 8.894592] <30>avahi-daemon[697]: avahi-daemon 0.6.30 starting up.
[ 9.134979] <26>xinetd[760]: 760 {init_services} no services. Exiting…
[ 9.816589] <30>NetworkManager[691]: NetworkManager[691]: NetworkManager (version 0.9.2.0) is starting…
[ 10.004302] <30>udisks-daemon[706]: (process:706): GLib-WARNING **: goption.c:2168: ignoring no-arg, optional-arg or filename flags (16) on option of type 1
[ 10.050476] <14>NetworkManager[691]: NetworkManager (version 0.9.2.0) is starting…
Started D-Bus System Message Bus [[ 10.257171] <30> OK ]
NetworkManager[691]: NetworkManager[691]: Read config file (null)
[ 10.347076] <14>NetworkManager[691]: Read config file (null)
[ 10.489959] <30>load-timestamp.sh[689]: Update systemtime from /etc/timestamp
[ 11.215545] <30>load-timestamp.sh[689]: Thu Jan 12 12:19:00 UTC 2012
[ 12.624359] <27>systemd-uaccess[1042]: Failed to apply ACL on /dev/v4l-subdev1: Operation not supported
[ 12.851226] <27>systemd-uaccess[1038]: Failed to apply ACL on /dev/video8: Operation not supported
[ 13.136016] <27>systemd-uaccess[1049]: Failed to apply ACL on /dev/v4l-subdev2: Operation not supported
[ 13.214752] <27>systemd-uaccess[1058]: Failed to apply ACL on /dev/v4l-subdev4: Operation not supported
[ 13.260223] <27>systemd-uaccess[1055]: Failed to apply ACL on /dev/v4l-subdev3: Operation not supported
[ 13.492065] <27>systemd-uaccess[1046]: Failed to apply ACL on /dev/v4l-subdev5: Operation not supported
Stopping Syslog Kernel Log Buffer Bridge…
[ 13.678131] <27>systemd-uaccess[1052]: Failed to apply ACL on /dev/video7: Operation not supported
[ 13.703338] <27>systemd-uaccess[1048]: Failed to apply ACL on /dev/v4l-subdev0: Operation not supported
Started Disk Manager [ 13.740722] <27> [systemd-uaccess OK ]
[1063]: Failed to apply ACL on /dev/v4l-subdev6: Operation not supported
[ 13.777557] <27>systemd-uaccess[1053]: Failed to apply ACL on /dev/v4l-subdev7: Operation not supported
Started Avahi mDNS/DNS-SD Stack [ OK ]
[ 14.085876] <27>systemd-uaccess[1078]: Failed to apply ACL on /dev/video0: Operation not supported
Started udev Coldplug all Devices [ OK ]
[ 14.167053] <30>udisks-daemon[706]: (udisks-daemon:706): udisks-daemon-DEBUG: Starting daemon version 1.0.4
[ 14.534271] <30>avahi-daemon[697]: Successfully called chroot().
[ 14.663299] <30>avahi-daemon[697]: Successfully dropped remaining capabilities.
[ 14.978546] <30>avahi-daemon[697]: Loading service file /services/sftp-ssh.service.
Starting Serial Getty on ttyO2…
[ 15.208068] <27>systemd-uaccess[1097]: Failed to apply ACL on /dev/video2: Operation not supported
Started Serial Getty on ttyO2 [ OK ]
[ 15.409545] <30>avahi-daemon[697]: Loading service file /services/ssh.service.
[ 15.569976] <27>systemd-uaccess[1098]: Failed to apply ACL on /dev/video1: Operation not supported
[ 15.825408] <27>systemd-uaccess[1108]: Failed to apply ACL on /dev/video4: Operation not supported
[ 16.087921] <27>systemd-uaccess[1102]: Failed to apply ACL on /dev/video3: Operation not supported
[ 16.269470] <27>systemd-uaccess[1111]: Failed to apply ACL on /dev/video6: Operation not supported
[ 16.396118] <27>systemd-uaccess[1121]: Failed to apply ACL on /dev/video5: Operation not supported
[ 16.486480] <30>dbus-daemon[884]: dbus[884]: [system] Activating service name=‘org.freedesktop.PolicyKit1’ (using servicehelper)
[ 16.619537] <30>avahi-daemon[697]: Loading service file /services/udisks.service.
Starting Getty on tty1…
[ 16.708282] <29>dbus[884]: [system] Activating service name=‘org.freedesktop.PolicyKit1’ (using servicehelper)
[ 16.806762] <30>avahi-daemon[697]: Network interface enumeration completed.
Started Getty on tty1 [ OK ]
[ 16.857177] <30>avahi-daemon[697]: Registering HINFO record with values ‘ARMV7L’/‘LINUX’.
[ 16.955200] <30>avahi-daemon[697]: Server startup complete. Host name is beagleboard.local. Local service cookie is 2019548482.
[ 17.041137] <30>avahi-daemon[697]: Service “beagleboard” (/services/udisks.service) successfully established.
Starting Gnome Display Manager…[ 17.128417] <30>.
avahi-daemon[697]: Service “beagleboard” (/services/ssh.service) successfully established.
[ 17.171539] <30>avahi-daemon[697]: Service “beagleboard” (/services/sftp-ssh.service) successfully established.
Started Gnome Display Manager [ OK ]
[ 17.265960] <27>systemd-uaccess[1200]: Failed to apply ACL on /dev/snd/timer: Operation not supported
Stopped Syslog Kernel Log Buffer Bridge [ OK ]
.—O---.
.Started System Logging Service [ OK ]
-. o o
__ | —’| ‘–.| .-’| | |
The Angstrom Distribution beagleboard ttyO2
Angstrom v2012.01-core - Kernel 2.6.37
beagleboard login: Started Network Manager [ OK ]
root
Last login: Thu Jan 12 12:19:07 GMT 2012 on ttyO2
FATAL: Error inserting g_ether (/lib/modules/2.6.37/kernel/drivers/usb/gadget/g_ether.ko): No such device
root@beagleboard:~# cd /
root@beagleboard:/# find . | grep “g_ether”
./lib/modules/3.0.14+/kernel/drivers/usb/gadget/g_ether.ko
./lib/modules/2.6.37/kernel/drivers/usb/gadget/g_ether.ko
^C
root@beagleboard:/# cd /lib/modules/2.6.37/kernel/drivers/
media/ scsi/ usb/ video/
root@beagleboard:/# cd /lib/modules/2.6.37/kernel/drivers/usb/gadget/g_
-sh: cd: /lib/modules/2.6.37/kernel/drivers/usb/gadget/g_: No such file or directory
root@beagleboard:/lib/modules/2.6.37/kernel/drivers/usb/gadget# rmmod g_ether
ERROR: Module g_ether does not exist in /proc/modules
Thanks, Ran
Hi Robert,
I was lazy not to notice that....
   insmod: error inserting 'g_ether.ko': -1 No such device
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~#
This means your kernel was built seperatly from the modules..
When you build your kernel, just also build 'make modules' and install
them to the rootfs..
format
Beagle Rev C5
Reading boot sector
DRAM: 256 MB
NAND: 512 MiB
In: serial
Out: serial
Err: serial
mmc1 is available
reading uImage
2918324 bytes read
## Booting kernel from Legacy Image at 80300000 ...
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
cr=10c53c7f
instruction cache
pages: 64000
bytes)
highmem
interrupts
[ 0.000000] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc.,
Ingo Molnar
[ 0.000000] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.000000] ... MAX_LOCK_DEPTH: 48
[ 0.000000] ... MAX_LOCKDEP_KEYS: 8191
[ 0.000000] ... CLASSHASH_SIZE: 4096
[ 0.000000] ... MAX_LOCKDEP_ENTRIES: 16384
[ 0.000000] ... MAX_LOCKDEP_CHAINS: 32768
[ 0.000000] ... CHAINHASH_SIZE: 16384
[ 0.000000] Calibrating delay loop... 456.86 BogoMIPS (lpj=1781760)
[ 0.122314] bio: create slab <bio-0> at 0
30517
[ 0.172485] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.172729] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.175842] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.192443] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[ 0.203613] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
61035
mode
status -19
bytes)
bytes)
Inc.
UART0
UART1
UART2
[ 1.958160] Creating 5 MTD partitions on "omap2-nand.0":
[ 1.963836] 0x000000000000-0x000000080000 : "X-Loader"
[ 1.982055] 0x000000080000-0x000000260000 : "U-Boot"
[ 1.997100] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 2.011535] 0x000000280000-0x000000680000 : "Kernel"
[ 2.027618] 0x000000680000-0x000020000000 : "File System"
91552
30517
0: 30517
variant c rev 1
initialized
initialized
122070
on
UTC (946684800)
device 15
device 16
[ 3.002319] Waiting for root device /dev/mmcblk0p2...
mode
[ 3.796173] <30>systemd[1]: Set hostname to <beagleboard>.
directory
add: CONFIG_AUTOFS4_FS=y
Hi Robert,
I have compiled both modules and kernel, but still some error, without any information…
The new boot log is below.
Is there any idea why it fails ?
Beagle Rev C5
Reading boot sector
DRAM: 256 MB
NAND: 512 MiB
In: serial
Out: serial
Err: serial
mmc1 is available
reading uImage
2927348 bytes read
Data Size: 2927284 Bytes = 2.8 MB
OK
Starting kernel …
[ 0.000000] Linux version 2.6.37 (ubuntu@ubuntu-laptop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #8 Thu Jan 15 18:29:23 IST 2015
[ 0.000000] Memory: 242712k/242712k available, 19432k reserved, 0K highmem
[ 0.000000] .text : 0xc003a000 - 0xc056e0d0 (5329 kB)
[ 0.000000] .data : 0xc0570000 - 0xc0725220 (1749 kB)
[ 0.000000] Calibrating delay loop… 458.96 BogoMIPS (lpj=1789952)
[ 0.123657] bio: create slab at 0
[ 0.135101] SCSI subsystem initialized
[ 0.149047] usbcore: registered new interface driver usbfs
[ 0.151000] usbcore: registered new interface driver hub
[ 0.152465] usbcore: registered new device driver usb
[ 0.159149] omap_device: omap_i2c.1: new worst case activate latency 0: 61035
[ 0.159362] omap_i2c omap_i2c.1: bus 1 rev3.12 at 2600 kHz
[ 0.174316] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 0.174560] twl4030: power (irq 373) chaining IRQs 376…383
[ 0.177703] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 0.194580] regulator: VMMC1: 1850 <–> 3150 mV at 3000 mV normal standby
[ 0.198181] regulator: VDAC: 1800 mV normal standby
[ 0.201873] regulator: VDVI: 1800 mV normal standby
[ 0.205810] regulator: VSIM: 1800 <–> 3000 mV at 1800 mV normal standby
[ 0.210021] regulator: VAUX3: 1800 mV normal standby
[ 0.213623] regulator: VAUX4: 1800 mV normal standby
[ 0.214294] omap_device: omap_i2c.1: new worst case deactivate latency 0: 91552
[ 0.214691] omap_i2c omap_i2c.2: bus 2 rev3.12 at 400 kHz
[ 0.229003] omap_i2c omap_i2c.3: bus 3 rev3.12 at 100 kHz
[ 0.239440] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.244750] Switching to clocksource 32k_counter
[ 0.435150] musb-hdrc: version 6.0, peripheral, debug=0
[ 0.435577] musb-hdrc musb-hdrc.0: degrade from otg to peripheral-only mode
[ 0.435668] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.435699] HS USB OTG: no transceiver configured
[ 0.435729] musb-hdrc musb-hdrc.0: musb_init_controller failed with status -19
[ 0.437591] NET: Registered protocol family 2
[ 0.438537] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.441192] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.441772] TCP bind hash table entries: 8192 (order: 6, 360448 bytes)
[ 0.447326] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.447509] TCP reno registered
[ 0.447540] UDP hash table entries: 128 (order: 1, 12288 bytes)
[ 0.448059] UDP-Lite hash table entries: 128 (order: 1, 12288 bytes)
[ 0.449432] NET: Registered protocol family 1
[ 0.451385] RPC: Registered udp transport module.
[ 0.451416] RPC: Registered tcp transport module.
[ 0.451416] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.452758] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.456146] platform iva.0: Enabled OPP corresponding to 720MHz
[ 0.460144] omap-iommu omap-iommu.0: isp registered
[ 0.461303] OMAP35x Linux PSP version 04.02.00.07 (OMAP3BEAGLE)
[ 0.649597] VFS: Disk quotas dquot_6.5.2
[ 0.649780] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.653320] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.657958] msgmni has been set to 474
[ 0.663879] io scheduler noop registered
[ 0.663909] io scheduler deadline registered
[ 0.664184] io scheduler cfq registered (default)
[ 0.729553] OMAP DSS rev 2.0
[ 0.730224] OMAP DISPC rev 3.0
[ 0.730407] OMAP VENC rev 2
[ 0.731964] OMAP DSI rev 1.0
[ 1.061706] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.074340] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.077087] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.079193] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.822540] console [ttyO2] enabled
[ 1.891143] brd: module loaded
[ 1.925689] loop: module loaded
[ 1.937622] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.944610] omap2-nand driver initializing
[ 1.949676] ONFI flash detected
[ 1.953247] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron )
[ 1.960388] Creating 5 MTD partitions on “omap2-nand.0”:
[ 1.966064] 0x000000000000-0x000000080000 : “X-Loader”
[ 1.984436] 0x000000080000-0x000000260000 : “U-Boot”
[ 1.999542] 0x000000260000-0x000000280000 : “U-Boot Env”
[ 2.014068] 0x000000280000-0x000000680000 : “Kernel”
[ 2.030242] 0x000000680000-0x000020000000 : “File System”
[ 2.301544] OneNAND driver initializing
[ 2.317413] mice: PS/2 mouse device common for all mice
[ 2.327362] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 2.345733] omap_device: omap_i2c.1: new worst case activate latency 0: 122070
[ 2.355102] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 2.374267] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 2.381378] twl_rtc twl_rtc: Power up reset detected.
[ 2.387847] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 2.395385] i2c /dev entries driver
[ 2.407806] Linux media interface: v0.10
[ 2.413055] Linux video capture interface: v2.00
[ 2.420562] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[ 2.427795] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[ 2.435546] omap3isp omap3isp: Revision 2.0 found
[ 2.440887] omap-iommu omap-iommu.0: isp: version 1.1
[ 2.552551] omap_i2c omap_i2c.2: Arbitration lost
[ 2.573242] mt9v113 2-003c: chip id mismatch read 0x0, expecting 0x2280
[ 2.590240] isp_register_subdev_group: Unable to register subdev mt9v113
[ 2.598937] omap_device: omap_wdt.-1: new worst case activate latency 0: 30517
[ 2.609344] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 2.615814] omap_device: omap_wdt.-1: new worst case deactivate latency 0: 30517
[ 2.625457] twl4030_wdt twl4030_wdt: Failed to register misc device
[ 2.632202] twl4030_wdt: probe of twl4030_wdt failed with error -16
[ 2.661651] usbcore: registered new interface driver usbhid
[ 2.667602] usbhid: USB HID core driver
[ 2.679443] ALSA device list:
[ 2.682678] No soundcards found.
[ 2.686248] oprofile: hardware counters not available
[ 2.691619] oprofile: using timer interrupt.
[ 2.696716] TCP cubic registered
[ 2.700225] Initializing XFRM netlink socket
[ 2.704986] NET: Registered protocol family 17
[ 2.709930] NET: Registered protocol family 15
[ 2.715393] Registering the dns_resolver key type
[ 2.721282] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 2.731414] ThumbEE CPU extension supported.
[ 2.758483] Power Management for TI OMAP3.
[ 2.763824] sr_init: No PMIC hook to init smartreflex
[ 2.769836] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 2.779174] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 2.789276] SmartReflex Class3 initialized
[ 2.857177] clock: disabling unused clocks to save power
[ 2.866088] platform iva.0: omap_voltage_scale: Already at the requestedrate 360000000
[ 2.874511] platform mpu.0: omap_voltage_scale: Already at the requestedrate 500000000
[ 2.882934] platform l3_main.0: omap_voltage_scale: Already at the requestedrate 166000000
[ 2.927032] regulator_init_complete: incomplete constraints, leaving VDAC on
[ 2.938446] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 2.947753] omap_vout omap_vout: Buffer Size = 3686400
[ 2.957153] omap_vout omap_vout: : registered and initialized video device 15
[ 2.964782] omap_vout omap_vout: Buffer Size = 3686400
[ 2.973541] omap_vout omap_vout: : registered and initialized video device 16
[ 2.988342] Waiting for root device /dev/mmcblk0p2…
[ 3.141418] mmc0: new high speed SDHC card at address aaaa
[ 3.151336] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[ 3.175750] mmcblk0: p1 p2
[ 3.218505] EXT3-fs: barriers not enabled
[ 3.227325] kjournald starting. Commit interval 5 seconds
[ 3.233612] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 3.247222] EXT3-fs (mmcblk0p2): using internal journal
[ 3.252807] EXT3-fs (mmcblk0p2): recovery complete
[ 3.258544] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 3.266540] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 3.273132] Freeing init memory: 200K
[ 3.609405] <30>systemd[1]: systemd 37 running in system mode. (+PAM +LIBWRAP -AUDIT -SELINUX +SYSVINIT -LIBCRYPTSETUP; angstrom)
[ 3.713439] <28>systemd[1]: /sbin/modprobe failed with error code 1.
[ 3.724670] <30>systemd[1]: Set hostname to .
[ 4.677764] <30>systemd-fsck[593]: Root directory is writable, skipping check.
Started udev Ker[ 5.031005] <30>udevd[600]: starting version 175
Starting /tmp…
Started /tmp [ OK ]
[ 8.354309] <27>systemd-logind[707]: Failed to open /sys/class/tty/tty0/active: No such file or directory
[ 8.659515] <27>systemd-logind[707]: Failed to fully start up daemon: No such file or directory
[ 8.877380] <29>systemd[1]: systemd-logind.service: main process exited, code=exited, status=1
[ 9.057952] <75>/usr/sbin/crond[722]: (CRON) INFO (Syslog will be used instead of sendmail.): No such file or directory
[ 9.415985] <30>avahi-daemon[711]: Found user ‘avahi’ (UID 998) and group ‘avahi’ (GID 996).
[ 9.478942] <30>avahi-daemon[711]: Successfully dropped root privileges.
[ 9.517791] <29>systemd[1]: Unit systemd-logind.service entered failed state.
[ 9.659942] <30>avahi-daemon[711]: avahi-daemon 0.6.30 starting up.
[ 9.930999] <26>xinetd[868]: 868 {init_services} no services. Exiting…
[ 10.786376] <30>NetworkManager[704]: NetworkManager[704]: NetworkManager (version 0.9.2.0) is starting…
[ 11.033538] <30>udisks-daemon[770]: (process:770): GLib-WARNING **: goption.c:2168: ignoring no-arg, optional-arg or filename flags (16) on option of type 1
[ 11.310058] <14>NetworkManager[704]: NetworkManager (version 0.9.2.0) is starting…
Started D-Bus System Message Bus [ OK ]
[ 11.474243] <30>NetworkManager[704]: NetworkManager[704]: Read config file (null)
[ 11.721771] <14>NetworkManager[704]: Read config file (null)
[ 11.728485] <30>load-timestamp.sh[702]: Update systemtime from /etc/timestamp
[ 12.190551] <30>load-timestamp.sh[702]: Thu Jan 12 12:19:00 UTC 2012
[ 12.656372] <27>systemd-uaccess[1031]: Failed to apply ACL on /dev/v4l-subdev3: Operation not supported
[ 12.891265] <27>systemd-uaccess[1027]: Failed to apply ACL on /dev/v4l-subdev0: Operation not supported
.—O---. [ 13.117218] <27>systemd-uaccess[1019]: Failed to apply ACL on /dev/v4l-subdev1: Operation not supported
.-. o o
-----.-----.-[ 13.337951] <27>systemd-uaccess[1033]: Failed to apply ACL on /dev/v4l-subdev2: Operation not supported
----.| | .----…–[ 13.378295] <27>systemd-uaccess[1037]: Failed to apply ACL on /dev/v4l-subdev6: Operation not supported
— [ 13.526580] <27>systemd-uaccess[1040]: Failed to apply ACL on /dev/v4l-subdev7: Operation not supported
[ 13.677337] <27>systemd-uaccess[1028]: Failed to apply ACL on /dev/v4l-subdev5: Operation not supported
Angstrom v2012.01-co[ 13.979644] <27>systemd-uaccess[1042]: Failed to apply ACL on /dev/v4l-subdev4: Operation not supported
re - Kernel 2.6.37
beagleboard login: [ 14.332580] <27>systemd-uaccess[1049]: Failed to apply ACL on /dev/video0: Operation not supported
[ 14.667114] <27>systemd-uaccess[1051]: Failed to apply ACL on /dev/video1: Operation not supported
[ 14.995208] <27>systemd-uaccess[1053]: Failed to apply ACL on /dev/video3: Operation not supported
[ 15.218170] <27>systemd-uaccess[1055]: Failed to apply ACL on /dev/video2: Operation not supported
[ 15.450988] <27>systemd-uaccess[1057]: Failed to apply ACL on /dev/video4: Operation not supported
Started Disk Manager [ OK ]
Started Avahi mDNS/DNS-SD Stack [[ 15.689880] <27> OK ]
systemd-uaccess[1063]: Failed to apply ACL on /dev/video5: Operation not supported
[ 15.800720] <27>systemd-uaccess[1073]: Failed to apply ACL on /dev/video8: Operation not supported
[ 16.030517] <27>systemd-uaccess[1072]: Failed to apply ACL on /dev/video7: Operation not supported
[ 16.091583] <27>systemd-uaccess[1086]: Failed to apply ACL on /dev/video6: Operation not supported
[ 16.201354] <30>udisks-daemon[770]: (udisks-daemon:770): udisks-daemon-DEBUG: Starting daemon version 1.0.4
[ 16.326660] <30>avahi-daemon[711]: Successfully called chroot().
[ 16.400512] <30>avahi-daemon[711]: Successfully dropped remaining capabilities.
[ 16.473449] <30>avahi-daemon[711]: Loading service file /services/sftp-ssh.service.
[ 16.510803] <30>avahi-daemon[711]: Loading service file /services/ssh.service.
[ 16.565338] <30>avahi-daemon[711]: Loading service file /services/udisks.service.
[ 16.644561] <30>avahi-daemon[711]: Network interface enumeration completed.
[ 16.669464] <30>avahi-daemon[711]: Registering HINFO record with values ‘ARMV7L’/‘LINUX’.
[ 16.757904] <30>avahi-daemon[711]: Server startup complete. Host name is beagleboard.local. Local service cookie is 441939348.
[ 16.862426] <30>avahi-daemon[711]: Service “beagleboard” (/services/udisks.service) successfully established.
[ 16.971832] <30>dbus-daemon[969]: dbus[969]: [system] Activating service name=‘org.freedesktop.PolicyKit1’ (using servicehelper)
[ 17.104522] <29>dbus[969]: [system] Activating service name=‘org.freedesktop.PolicyKit1’ (using servicehelper)
[ 17.218292] <30>avahi-daemon[711]: Service “beagleboard” (/services/ssh.service) successfully established.
Starting Gnome D[ 17.271667] <27>isplay Manager…systemd-uaccess.
[1199]: Failed to apply ACL on /dev/snd/timer: Operation not supported
[ 17.293273] <30>avahi-daemon[711]: Service “beagleboard” (/services/sftp-ssh.service) successfully established.
.—O---.
.-. o o
beagleboard login:
.—O---.
.-. o o
beagleboard login: root
Last login: Thu Jan 12 12:19:48 GMT 2012 on ttyO2
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~# cd /lib/modules/2.6.37/kernel/drivers/usb/gadget/
Ran
Maybe debmod ?
depmod -a
then:
modprobe g_ether
Otherwise it is 2.6.37....
.Maybe debmod ?
depmod -a
then:
modprobe g_ether
I’ve tried that too…
Still same result.
We have another nibary which works well with g_ether, (but we don’t have the sources for that binary so it does not help a lot, except for telling us that there is no HW failure)
What can I do ? Is it a problem in this package (TI’S PSP 04.02.00.07) ?
Thank you,
Ran
Did anyone tried to work with the usb connector (the one that is marked as “usb otg”), for ethernet with 2.6.37 ?If not - maybe I should try use some older version for beagleboard ?
Ran
When I compiled earlier kernel version which are supposed to support OMAP3530 with beaglebone I fail to start kernel (psp 3.0.1.6, kernel 2.6.32);
1920736 bytes read
Image Name: Linux-2.6.32
Data Size: 1920672 Bytes = 1.8 MB
OK
Starting kernel …
<<-- NO more prinings -->>
I just need to work with usb ethernet in 2.6.37… why does it fail with the kernel 2.6.37 ?
Ran
Can anyone please try to see if he can work with usb otg and beagleboard
this is the download page for kernel 2.6.37 I use:
http://downloads.ti.com/dsps/dsps_public_sw/psp/LinuxPSP/OMAP_04_02/04_02_00_07/index_FDS.html
Ran
I solved the issue.
I compile now inside kernel and added:
Thank you very much for all help!
Ran
