journal as in journalctl? doesn't seem to be included. but here's what I
found in dmesg that seemed relevant:
In wheezy it's systemd-journalctl
[ 2.976012] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk
combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftCo)
[ 2.976031] musb-hdrc: MHDRC RTL version 2.0
[ 2.976039] musb-hdrc: setup fifo_mode 4
[ 2.976056] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 2.977348] 47401b00.usb-phy supply vcc not found, using dummy
regulator
[ 3.005848] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk
[ 3.005863] musb-hdrc: MHDRC RTL version 2.0
[ 3.005871] musb-hdrc: setup fifo_mode 4
[ 3.005885] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 3.006170] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 3.006461] musb-hdrc musb-hdrc.1.auto: new USB bus registered,
assigned bus number 1
[ 3.006690] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 3.006703] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 3.006712] usb usb1: Product: MUSB HDRC host driver
[ 3.006721] usb usb1: Manufacturer: Linux 4.1.13-bone-rt-r17 musb-hcd
[ 3.006730] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 3.007420] hub 1-0:1.0: USB hub found
[ 3.007470] hub 1-0:1.0: 1 port detected
[ 21.101221] using random self ethernet address
[ 21.101247] using random host ethernet address
[ 21.101265] using host ethernet address: 84:EB:18:AE:CB:AA
[ 21.160643] Mass Storage Function, version: 2009/09/11
[ 21.160672] LUN: removable file: (no medium)
[ 21.160867] LUN: removable file: /dev/mmcblk0p1
[ 21.160878] Number of LUNs=1
[ 21.162626] usb0: HOST MAC 84:eb:18:ae:cb:aa
[ 21.162973] usb0: MAC a2:29:c5:ee:bf:e6
[ 21.163029] Number of LUNs=1
[ 21.166695] g_multi gadget: Multifunction Composite Gadget
[ 21.166721] g_multi gadget: g_multi ready
[ 21.767642] g_multi gadget: high-speed config #1: Multifunction with
RNDIS
[ 33.184926] net eth0: initializing cpsw version 1.12 (0)
[ 33.187423] net eth0: phy found : id is : 0x7c0f1
[ 33.187492] libphy: PHY 4a101000.mdio:01 not found
[ 33.192436] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 33.218457] net eth0: BQL enabled
[ 33.228304] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 132.378851] device usb0 entered promiscuous mode
[ 153.177973] device usb0 left promiscuous mode
[ 1555.067418] device usb0 entered promiscuous mode
[ 1570.862790] device usb0 left promiscuous mode
Here's what you should see:
Host:
[ 4310.886819] usb 5-1.4: new high-speed USB device number 5 using xhci_hcd
[ 4310.977656] usb 5-1.4: New USB device found, idVendor=1d6b,
idProduct=0104
[ 4310.977663] usb 5-1.4: New USB device strings: Mfr=3, Product=4,
SerialNumber=5
[ 4310.977667] usb 5-1.4: Product: BeagleBoneBlack
[ 4310.977670] usb 5-1.4: Manufacturer: Circuitco
[ 4310.977673] usb 5-1.4: SerialNumber: -BBG115081143
[ 4310.982450] usb-storage 5-1.4:1.4: USB Mass Storage device detected
[ 4310.982579] scsi host11: usb-storage 5-1.4:1.4
[ 4311.003239] cdc_acm 5-1.4:1.2: ttyACM0: USB ACM device
[ 4311.003873] usbcore: registered new interface driver cdc_acm
[ 4311.003874] cdc_acm: USB Abstract Control Model driver for USB modems
and ISDN adapters
[ 4311.008181] usbcore: registered new interface driver cdc_ether
[ 4311.012262] cfg80211: World regulatory domain updated:
[ 4311.012266] cfg80211: DFS Master region: unset
[ 4311.012268] cfg80211: (start_freq - end_freq @ bandwidth),
(max_antenna_gain, max_eirp), (dfs_cac_time)
[ 4311.012270] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A,
2000 mBm), (N/A)
[ 4311.012272] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A,
2000 mBm), (N/A)
[ 4311.012274] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A,
2000 mBm), (N/A)
[ 4311.012276] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000
KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 4311.012278] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000
KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 4311.012280] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A,
2000 mBm), (0 s)
[ 4311.012281] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A,
2000 mBm), (N/A)
[ 4311.012283] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz),
(N/A, 0 mBm), (N/A)
[ 4311.013968] rndis_host 5-1.4:1.0 eth0: register 'rndis_host' at
usb-0000:00:10.1-1.4, RNDIS device, 84:eb:18:af:f5:e8
[ 4311.014010] usbcore: registered new interface driver rndis_host
[ 4311.015133] usbcore: registered new interface driver rndis_wlan
[ 4311.019341] rndis_host 5-1.4:1.0 enx84eb18aff5e8: renamed from eth0
[ 4311.052121] IPv6: ADDRCONF(NETDEV_UP): enx84eb18aff5e8: link is not ready
[ 4311.982606] scsi 11:0:0:0: Direct-Access Linux File-Stor Gadget
0401 PQ: 0 ANSI: 2
[ 4311.983127] sd 11:0:0:0: Attached scsi generic sg5 type 0
[ 4311.983783] sd 11:0:0:0: [sdf] 196608 512-byte logical blocks: (100
MB/96.0 MiB)
[ 4311.984032] sd 11:0:0:0: [sdf] Write Protect is off
[ 4311.984036] sd 11:0:0:0: [sdf] Mode Sense: 0f 00 00 00
[ 4311.984332] sd 11:0:0:0: [sdf] Write cache: enabled, read cache:
enabled, doesn't support DPO or FUA
[ 4311.989100] sdf:
[ 4311.991160] sd 11:0:0:0: [sdf] Attached SCSI removable disk
[ 4324.263618] usb 2-3: USB disconnect, device number 4
$ sudo ifconfig -a
enx84eb18aff5e8: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 84:eb:18:af:f5:e8 txqueuelen 1000 (Ethernet)
RX packets 43 bytes 6563 (6.4 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
$ sudo dhclient enx84eb18aff5e8
$ sudo ifconfig -a
inet 192.168.7.1 netmask 255.255.255.252 broadcast 192.168.7.3
inet6 fe80::86eb:18ff:feaf:f5e8 prefixlen 64 scopeid 0x20<link>
RX packets 46 bytes 7247 (7.0 KiB)
TX packets 41 bytes 8987 (8.7 KiB)
(odd naming is systemd-network in debian stretch)
Bone:
root@beaglebone:~# journalctl | grep usb0
Dec 06 21:30:13 beaglebone connmand[297]: usb0 {create} index 3 type 1
<ETHER>
Dec 06 21:30:13 beaglebone connmand[297]: usb0 {update} flags 4098 <DOWN>
Dec 06 21:30:13 beaglebone connmand[297]: usb0 {newlink} index 3 address
00:00:00:00:00:00 mtu 1500
Dec 06 21:30:13 beaglebone connmand[297]: usb0 {newlink} index 3 operstate
2 <DOWN>
Dec 06 21:30:13 beaglebone connmand[297]: Adding interface usb0 [ gadget ]
84:EB:18:AF:F5:E0 mtu 1500
2 <DOWN>
Dec 06 21:30:13 beaglebone kernel: usb0: HOST MAC 84:eb:18:af:f5:e8
Dec 06 21:30:13 beaglebone kernel: usb0: MAC 84:eb:18:af:f5:e0
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {add} address 192.168.7.2/24
label usb0 family 2
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {update} flags 69699
<UP,RUNNING,LOWER_UP>
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {newlink} index 3 address
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {newlink} index 3 operstate
6 <UP>
Dec 06 21:30:16 beaglebone avahi-daemon[291]: Joining mDNS multicast group
on interface usb0.IPv4 with address 192.168.7.2.
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {add} route 192.168.7.0 gw
0.0.0.0 scope 253 <LINK>
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {add} route fe80:: gw ::
scope 0 <UNIVERSE>
Dec 06 21:30:16 beaglebone avahi-daemon[291]: New relevant interface
usb0.IPv4 for mDNS.
Dec 06 21:30:16 beaglebone avahi-daemon[291]: Registering new address
record for 192.168.7.2 on usb0.IPv4.
Dec 06 21:30:16 beaglebone avahi-daemon[291]: Withdrawing address record
Dec 06 21:30:16 beaglebone avahi-daemon[291]: Leaving mDNS multicast group
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {del} address 192.168.7.2/24
label usb0
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {del} route 192.168.7.0 gw
Dec 06 21:30:16 beaglebone connmand[297]: usb0 {add} address 192.168.7.2/30
label usb0 family 2
Dec 06 21:30:16 beaglebone avahi-daemon[291]: Interface usb0.IPv4 no longer
relevant for mDNS.
usb0.IPv4 for mDNS.
Dec 06 21:30:18 beaglebone avahi-daemon[291]: Joining mDNS multicast group
on interface usb0.IPv6 with address fe80::86eb:18ff:feaf:f5e0.
Dec 06 21:30:18 beaglebone avahi-daemon[291]: New relevant interface
usb0.IPv6 for mDNS.
Dec 06 21:30:18 beaglebone avahi-daemon[291]: Registering new address
record for fe80::86eb:18ff:feaf:f5e0 on usb0.*.
Dec 06 21:32:09 beaglebone dnsmasq-dhcp[727]: DHCPDISCOVER(usb0)
192.168.7.1 84:eb:18:af:f5:e8
Dec 06 21:32:09 beaglebone dnsmasq-dhcp[727]: DHCPOFFER(usb0) 192.168.7.1
84:eb:18:af:f5:e8
Dec 06 21:32:09 beaglebone dnsmasq-dhcp[727]: DHCPREQUEST(usb0) 192.168.7.1
84:eb:18:af:f5:e8
Dec 06 21:32:09 beaglebone dnsmasq-dhcp[727]: DHCPACK(usb0) 192.168.7.1
84:eb:18:af:f5:e8 hades
dnsmasq-dhcp & udhcpd are pretty changeable..
