I'm not sure if my previous post was uploaded ....
Anyway, I am using a 3A power, so this shouldn't be the problem.
And btw, I am using rcn-ee's pe-build image (natty 11.04 r3)
dmesg's output:
[ 0.032653] Initializing cgroup subsys cpuacct
[ 0.032714] Initializing cgroup subsys memory
[ 0.032775] Initializing cgroup subsys devices
[ 0.032806] Initializing cgroup subsys freezer
[ 0.032928] CPU: Testing write buffer coherency: ok
[ 0.033203] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver,
5 counters available
[ 0.033935] Brought up 1 CPUs
[ 0.033966] SMP: Total of 1 processors activated (478.91 BogoMIPS).
[ 0.034545] devtmpfs: initialized
[ 0.037811] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va
for l4_core
[ 0.037872] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va
for l4_per
[ 0.037902] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va
for l4_wkup
[ 0.051086] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
[ 0.063049] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
[ 0.075042] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
[ 0.076538] print_constraints: dummy:
[ 0.076873] NET: Registered protocol family 16
[ 0.077056] GPMC revision 5.0
[ 0.078216] OMAP GPIO hardware version 2.5
[ 0.078430] OMAP GPIO hardware version 2.5
[ 0.078643] OMAP GPIO hardware version 2.5
[ 0.078857] OMAP GPIO hardware version 2.5
[ 0.079071] OMAP GPIO hardware version 2.5
[ 0.079254] OMAP GPIO hardware version 2.5
[ 0.079895] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.081024] OMAP3 Beagle Rev: xM C
[ 0.085144] Found NAND on CS0
[ 0.085205] Registering NAND on CS0
[ 0.085479] Unable to get DVI reset GPIO
[ 0.085571] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.088348] OMAP DMA hardware revision 5.0
[ 0.095184] bio: create slab <bio-0> at 0
[ 0.096374] SCSI subsystem initialized
[ 0.097686] usbcore: registered new interface driver usbfs
[ 0.097808] usbcore: registered new interface driver hub
[ 0.098052] usbcore: registered new device driver usb
[ 0.098815] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.101684] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.101745] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.102233] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.105407] print_constraints: VUSB1V5: 1500 mV normal standby
[ 0.105834] print_constraints: VUSB1V8: 1800 mV normal standby
[ 0.106262] print_constraints: VUSB3V1: 3100 mV normal standby
[ 0.108215] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.109039] print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV
normal standby
[ 0.109497] print_constraints: VDAC: 1800 mV normal standby
[ 0.109924] print_constraints: VDVI: 1800 mV normal standby
[ 0.110443] print_constraints: VSIM: 1800 <--> 3000 mV at 1800 mV
normal standby
[ 0.110778] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.119018] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[ 0.119995] Advanced Linux Sound Architecture Driver Version
1.0.24.
[ 0.120697] NetLabel: Initializing
[ 0.120727] NetLabel: domain hash size = 128
[ 0.120758] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.120819] NetLabel: unlabeled traffic allowed by default
[ 0.121124] Switching to clocksource 32k_counter
[ 0.125457] Switched to NOHz mode on CPU #0
[ 0.136016] AppArmor: AppArmor Filesystem Enabled
[ 0.147094] musb-hdrc: version 6.0, musb-dma, otg (peripheral+host)
[ 0.150390] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk
combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.150451] musb-hdrc: MHDRC RTL version 1.800
[ 0.150451] musb-hdrc: setup fifo_mode 5
[ 0.150482] musb-hdrc: 28/31 max ep, 8192/16384 memory
[ 0.150726] musb-hdrc musb-hdrc: USB OTG mode controller at
fa0ab000 using DMA, IRQ 92
[ 0.151336] NET: Registered protocol family 2
[ 0.151672] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 0.152862] TCP established hash table entries: 16384 (order: 5,
131072 bytes)
[ 0.153259] TCP bind hash table entries: 16384 (order: 5, 131072
bytes)
[ 0.153625] TCP: Hash tables configured (established 16384 bind
16384)
[ 0.153656] TCP reno registered
[ 0.153686] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.153717] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.154205] NET: Registered protocol family 1
[ 0.154968] RPC: Registered named UNIX socket transport module.
[ 0.154998] RPC: Registered udp transport module.
[ 0.155029] RPC: Registered tcp transport module.
[ 0.155059] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 0.155334] Trying to unpack rootfs image as initramfs...
[ 0.524536] Freeing initrd memory: 3604K
[ 0.525421] PMU: registered new PMU device of type 0
[ 0.525939] omap_dsp_init: 600000 bytes @ 9ee00000
[ 0.526641] audit: initializing netlink socket (disabled)
[ 0.526733] type=2000 audit(0.546:1): initialized
[ 0.682952] VFS: Disk quotas dquot_6.5.2
[ 0.683380] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.687042] Registering unionfs 2.5.9 (for 2.6.39-rc5)
[ 0.688262] fuse init (API version 7.16)
[ 0.689575] Btrfs loaded
[ 0.689636] msgmni has been set to 955
[ 0.691040] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 253)
[ 0.691101] io scheduler noop registered
[ 0.691101] io scheduler deadline registered
[ 0.691223] io scheduler cfq registered (default)
[ 0.754211] OMAP DSS rev 2.0
[ 0.756042] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.757171] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a
OMAP UART0
[ 0.757415] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a
OMAP UART1
[ 0.757629] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a
OMAP UART2
[ 1.569763] console [ttyO2] enabled
[ 1.573669] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a
OMAP UART3
[ 1.587005] brd: module loaded
[ 1.593139] loop: module loaded
[ 1.599090] omap2-nand driver initializing
[ 1.603698] No NAND device found.
[ 1.607452] No NAND device found.
[ 1.611083] OneNAND driver initializing
[ 1.615539] usbcore: registered new interface driver cdc_ether
[ 1.621704] usbcore: registered new interface driver rndis_host
[ 1.627929] cdc_ncm: 01-June-2011
[ 1.631469] usbcore: registered new interface driver cdc_ncm
[ 1.637756] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 3.660339] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.666503] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 3.674377] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.691619] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.698303] hub 1-0:1.0: USB hub found
[ 3.702270] hub 1-0:1.0: 3 ports detected
[ 3.730804] Initializing USB Mass Storage driver...
[ 3.736022] usbcore: registered new interface driver usb-storage
[ 3.742309] USB Mass Storage support registered.
[ 3.750122] g_ether gadget: using random self ethernet address
[ 3.756256] g_ether gadget: using random host ethernet address
[ 3.763305] usb0: MAC 5e:e3:89:7c:4b:6a
[ 3.767333] usb0: HOST MAC ca:96:e8:3e:c3:af
[ 3.771850] g_ether gadget: Ethernet Gadget, version: Memorial Day
2008
[ 3.778808] g_ether gadget: g_ether ready
[ 3.782989] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 3.788665] musb-hdrc musb-hdrc: new USB bus registered, assigned
bus number 2
[ 3.796844] hub 2-0:1.0: USB hub found
[ 3.800811] hub 2-0:1.0: 1 port detected
[ 3.805450] mousedev: PS/2 mouse device common for all mice
[ 3.812042] input: twl4030_pwrbutton as /devices/platform/omap/
omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input0
[ 3.823638] i2c /dev entries driver
[ 3.827850] lirc_dev: IR Remote Control driver registered, major
250
[ 3.835144] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.842102] device-mapper: uevent: version 1.0.3
[ 3.847381] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02)
initialised: dm-devel@redhat.com
[ 3.856628] device-mapper: multipath: version 1.3.0 loaded
[ 3.862396] device-mapper: multipath round-robin: version 1.0.0
loaded
[ 3.869689] cpuidle: using governor ladder
[ 3.873992] cpuidle: using governor menu
[ 3.878173] sdhci: Secure Digital Host Controller Interface driver
[ 3.884643] sdhci: Copyright(c) Pierre Ossman
[ 3.891082] omap_hsmmc: probe of omap_hsmmc.1 failed with error -16
[ 3.897949] Registered led device: beagleboard::usr0
[ 3.898040] Registered led device: beagleboard::usr1
[ 3.899536] Registered led device: beagleboard::pmu_stat
[ 3.900177] usbcore: registered new interface driver snd-usb-6fire
[ 3.907867] OMAP3 Beagle/Devkit8000 SoC init
[ 3.990753] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 3.997589] ALSA device list:
[ 4.000701] #0: omap3beagle
[ 4.005126] TCP cubic registered
[ 4.009399] NET: Registered protocol family 10
[ 4.017150] NET: Registered protocol family 17
[ 4.022216] Registering the dns_resolver key type
[ 4.027191] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 3
[ 4.035278] ThumbEE CPU extension supported.
[ 4.039794] Registering SWP/SWPB emulation handler
[ 4.046417] usb 1-2: new high speed USB device number 2 using ehci-
omap
[ 4.055419] sr_init: No PMIC hook to init smartreflex
[ 4.060974] smartreflex smartreflex.0: omap_sr_probe: SmartReflex
driver initialized
[ 4.069274] smartreflex smartreflex.1: omap_sr_probe: SmartReflex
driver initialized
[ 4.077514] SmartReflex Class3 initialized
[ 4.087341] clock: disabling unused clocks to save power
[ 4.093872] registered taskstats version 1
[ 4.098449] fbcvt: 1280x720@60: CVT Name - .921M9-R
[ 4.124084] Console: switching to colour frame buffer device 160x45
[ 4.141601] regulator_init_complete: VDAC: incomplete constraints,
leaving on
[ 4.149261] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 4.156250] Freeing init memory: 352K
[ 4.208923] hub 1-2:1.0: USB hub found
[ 4.218597] hub 1-2:1.0: 5 ports detected
[ 4.258087] mmc0: host does not support reading read-only switch.
assuming write-enable.
[ 4.277740] mmc0: new SDHC card at address cbe7
[ 4.285736] mmcblk0: mmc0:cbe7 SD04G 3.69 GiB
[ 4.299163] mmcblk0: p1 p2
[ 4.348510] udev[67]: starting version 167
[ 4.512664] usb 1-2.1: new high speed USB device number 3 using
ehci-omap
[ 5.632232] EXT4-fs (mmcblk0p2): mounted filesystem with ordered
data mode. Opts: (null)
[ 7.431396] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-
ro
[ 7.577789] udev[247]: starting version 167
[ 8.070648] input: gpio-keys as /devices/platform/gpio-keys/input/
input1
[ 8.381622] rtc-ds1307: probe of 2-0068 failed with error -5
[ 8.493469] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 8.500427] twl_rtc twl_rtc: Power up reset detected.
[ 8.517791] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 9.720336] smsc95xx v1.0.4
[ 9.910522] smsc95xx 1-2.1:1.0: eth0: register 'smsc95xx' at usb-
ehci-omap.0-2.1, smsc95xx USB 2.0 Ethernet, 36:1f:22:01:61:5f
[ 9.910705] usbcore: registered new interface driver smsc95xx
[ 12.655487] smsc95xx 1-2.1:1.0: eth0: link up, 100Mbps, full-
duplex, lpa 0xCDE1
[ 22.019836] eth0: no IPv6 routers present
[ 139.044006] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-
ro,commit=0
[ 5336.851348] smsc95xx 1-2.1:1.0: eth0: link down
[ 5338.427917] smsc95xx 1-2.1:1.0: eth0: link up, 10Mbps, full-duplex,
lpa 0x4061
[ 5385.017089] smsc95xx 1-2.1:1.0: eth0: link down
[ 5386.554870] smsc95xx 1-2.1:1.0: eth0: link up, 100Mbps, full-
duplex, lpa 0xCDE1
[ 7738.981872] hub 1-0:1.0: port 2 disabled by hub (EMI?), re-
enabling...
[ 7738.988952] usb 1-2: USB disconnect, device number 2
[ 7738.988983] usb 1-2.1: USB disconnect, device number 3
[ 7738.990783] smsc95xx 1-2.1:1.0: eth0: unregister 'smsc95xx' usb-
Thanks again
Adi Perry
