even "stable" branch of OE for angstrom fails on module-init-tools
Hello Robert,
>> ccache gcc
>> -isystem/home/rpjday/oe/angstrom-dev/staging/x86_64-linux/usr/include
>> -O2 -Wunused -Wall -static
>> -L/home/rpjday/oe/angstrom-dev/staging/x86_64-linux/usr/lib
>> -Wl,-rpath-link,/home/rpjday/oe/angstrom-dev/staging/x86_64-linux/usr/lib
>> -Wl,-rpath,/home/rpjday/oe/angstrom-dev/staging/x86_64-linux/usr/lib
>> -Wl,-O1 -o insmod.static insmod.o
>> /usr/bin/ld: cannot find -lc
> That error implies that the compiler on your host (the fedora gcc)
> can't find the c library of your host, so I suspect the fedora gcc
> doesn't have /lib/ in its searchpatch or something.
We are building a staticly linked tool here, which might explain the
late failure.
i think i already posted that the solution was to, on my fedora 11
system, install the "glibc-static" package. apparently, f11 is the
first version of fedora that split out that static component into a
separate package, which is why the build would have worked fine on
earlier versions of fedora but not f11. so:
# yum install glibc-static
and all was well.
Thanks for reporting this.
And I didn't catch that post. Your last message in the thread I got ended in:
i'll give it some more thought. thanks.
rday
