Exception Stack Error and USR LED 1 and 3 are ON
Please tell me what could be causing the error message.
I tried the latest image also and the current image is am335x-debian-11.6-minimal-armhf-2023-04-06-2gb.img
U-Boot SPL 2019.04-g1da4564 (Aug 31 2021 - 14:32:40 +0000)
Trying to boot from MMC2
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
U-Boot 2019.04-g1da4564 (Aug 31 2021 - 14:32:40 +0000)
CPU  : AM335X-GP rev 2.1
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
Reset Source: Global external warm reset has occurred.
RTC 32KCLK Source: External.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
1713 bytes read in 22 ms (75.2 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.162-ti-r58 ...
10531328 bytes read in 683 ms (14.7 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/5.10.162-ti-r58/am335x-boneblack-uboot-univ.dtb ...
210612 bytes read in 45 ms (4.5 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/5.10.162-ti-r58/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 113 ms (4.9 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.162-ti-r58/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 118 ms (12.7 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.162-ti-r58/overlays/BB-HDMI-TDA998x-00A0.dtbo ...
5321 bytes read in 97 ms (52.7 KiB/s)
loading /boot/initrd.img-5.10.162-ti-r58 ...
6509864 bytes read in 429 ms (14.5 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:635528 88000000] ...
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f9ca000, end 8ffff528 ... OK
   Loading Device Tree to 8f933000, end 8f9c9fff ... OK
Starting kernel ...
[    0.151581] l3-aon-clkctrl:0000:0: failed to disable
[    8.254520] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    8.286363] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[    8.286394] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[    8.803067] omap_voltage_late_init: Voltage driver support not added
[    8.900708] 8<--- cut here ---
[    8.903806] Unhandled fault: external abort on non-linefetch (0x1008) at 0xe2326000
[    8.911502] pgd = 5aece55d
[    8.914219] [e2326000] *pgd=8349f811, *pte=4a326653, *ppte=4a326453
[    8.920546] Internal error: : 1008 [#1] PREEMPT SMP ARM
[    8.925798] Modules linked in:
[    8.928878] CPU: 0 PID: 5 Comm: kworker/0:0 Not tainted 5.10.162-ti-r58 #1bullseye
[    8.936479] Hardware name: Generic AM33XX (Flattened Device Tree)
[    8.942620] Workqueue: events deferred_probe_work_func
[    8.947797] PC is at sysc_probe+0xd18/0x15f8
[    8.952090] LR is at _raw_spin_unlock_irqrestore+0x28/0x54
[    8.957599] pc : [<c087ecfc>]    lr : [<c0eef994>]    psr: 600e0013
[    8.963892] sp : c18eddf8  ip : 001ccf00  fp : 00000000
[    8.969139] r10: c0f6e374  r9 : 00000000  r8 : c0f6e834
[    8.974385] r7 : 00000000  r6 : c1b03c10  r5 : c16bf8b0  r4 : c3607240
[    8.980940] r3 : e2326000  r2 : 00026000  r1 : e2300000  r0 : 00000000
[    8.987497] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[    8.994663] Control: 10c5387d  Table: 8321c019  DAC: 00000051
[    9.000433] Process kworker/0:0 (pid: 5, stack limit = 0x633d7dc1)
[    9.006640] Stack: (0xc18eddf8 to 0xc18ee000)
[    9.011017] dde0:                                                       00000001 00000000
[    9.019234] de00: c151a258 c11a51dc c16bf8b0 00000001 c1b03c10 c11a509c 00000001 00000001
[    9.027450] de20: 00000030 e456aa91 00000000 00000000 c1b03c10 c15da15c 00000000 c16c6b54
[    9.035667] de40: c15da15c 0000000a df8ed5c0 c09de498 c1b03c10 c16c6b4c 00000000 c09dbcd8
[    9.043884] de60: c15da15c e456aa91 df8ed5c0 c1b03c10 c15da15c c09dc714 c15e77e4 c11d0010
[    9.052102] de80: c164e088 00000000 df8ed5c0 c09dc500 c11d0010 c09dc6e8 c15da15c 00000000
[    9.060319] dea0: c18ededc c09dc714 c15e77e4 c11d0010 c164e088 c09d9988 df8ed5c0 c189f06c
[    9.068535] dec0: c2feec38 e456aa91 c1b03c10 00000001 c1b03c54 c09dc170 00000000 c1b03c10
[    9.076752] dee0: 00000001 e456aa91 c1ae47d4 c15e7a40 c1b03c10 c09dacb8 c1ae47d4 c1b03c10
[    9.084969] df00: c15e779c c09db4f4 c15e77c8 c189a480 df8ed5c0 df8f0800 00000000 00000000
[    9.093185] df20: 00000000 c015a4ec c18ec000 df8ed5c0 c18dbebc c189a480 df8ed5c0 c189a494
[    9.101402] df40: df8ed5d8 c1504d00 00000008 c18ec000 df8ed5c0 c015aa8c c18ae324 c1635b17
[    9.109619] df60: c18ae324 c18ae300 c18ae280 00000000 c18ec000 c015a8ac c189a480 c18dbeb4
[    9.117835] df80: c18ae324 c01600d0 00000000 c18ae280 c015ff84 00000000 00000000 00000000
[    9.126051] dfa0: 00000000 00000000 00000000 c0100148 00000000 00000000 00000000 00000000
[    9.134268] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.142484] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[    9.150722] [<c087ecfc>] (sysc_probe) from [<c09de498>] (platform_drv_probe+0x48/0x98)
[    9.158681] [<c09de498>] (platform_drv_probe) from [<c09dbcd8>] (really_probe+0xf8/0x4e4)
[    9.166902] [<c09dbcd8>] (really_probe) from [<c09dc500>] (driver_probe_device+0xf4/0x1c8)
[    9.175209] [<c09dc500>] (driver_probe_device) from [<c09d9988>] (bus_for_each_drv+0x80/0xd0)
[    9.183778] [<c09d9988>] (bus_for_each_drv) from [<c09dc170>] (__device_attach+0xac/0x200)
[    9.192082] [<c09dc170>] (__device_attach) from [<c09dacb8>] (bus_probe_device+0x84/0x8c)
[    9.200299] [<c09dacb8>] (bus_probe_device) from [<c09db4f4>] (deferred_probe_work_func+0x98/0xdc)
[    9.209307] [<c09db4f4>] (deferred_probe_work_func) from [<c015a4ec>] (process_one_work+0x1b8/0x578)
[    9.218486] [<c015a4ec>] (process_one_work) from [<c015aa8c>] (worker_thread+0x1e0/0x524)
[    9.226710] [<c015aa8c>] (worker_thread) from [<c01600d0>] (kthread+0x14c/0x150)
[    9.234147] [<c01600d0>] (kthread) from [<c0100148>] (ret_from_fork+0x14/0x2c)
[    9.241400] Exception stack(0xc18edfb0 to 0xc18edff8)
[    9.246474] dfa0:                                     00000000 00000000 00000000 00000000
[    9.254691] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    9.262905] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    9.269555] Code: e5941014 e3130004 e0813002 1a000193 (e5933000)
[    9.275681] ---[ end trace 24133f2d16dd0490 ]---
