executing bitbake base-image command throw error
I followed same steps mention this link:
http://www.angstrom-distribution.org/building-angstrom
When I run bitbake base-image command,I got error:
ERROR: IO Error: [Errno 13] Permission denied: '/OE/angstrom-dev/
saved_tmpdir'
Have you tried fixing those permission problems first?
Traceback (most recent call last):
  File "/OE/openembedded/bitbake/bin/bitbake", line 143, in <module>
    main()
  File "/OE/openembedded/bitbake/bin/bitbake", line 123, in main
    cooker.parseConfiguration()
  File "/OE/openembedded/bitbake/lib/bb/cooker.py", line 68, in
parseConfiguration
    self.parseConfigurationFile( os.path.join( "conf",
"bitbake.conf" ) )
  File "/OE/openembedded/bitbake/lib/bb/cooker.py", line 402, in
    bb.fetch.fetcher_init(self.configuration.data)
  File "/OE/openembedded/bitbake/lib/bb/fetch/__init__.py", line 100,
in fetcher_init
    pd.delDomain("BB_URI_HEADREVS")
  File "/OE/openembedded/bitbake/lib/bb/persist_data.py", line 70, in
delDomain
    self.connection.execute("DROP TABLE IF EXISTS %s;" % domain)
sqlite3.OperationalError: attempt to write a readonly database
I try to add following in persist_data.py file .
try:
    self.connection.execute("CREATE TABLE IF NOT EXISTS %s(key TEXT,
value TEXT);" % domain)
  except:
    bb.msg.debug(1, bb.msg.domain.PersistData, "Create table '%s'
failed" % domain)
instead of
self.connection.execute("CREATE TABLE IF NOT EXISTS %s(key TEXT, value
TEXT);" % domain)
try:
    self.connection.execute("DROP TABLE %s;" % domain)
  except:
    bb.msg.debug(1, bb.msg.domain.PersistData, "Delete table '%s'
failed" % domain)
instead of
I solve error like that
    main()
parseConfiguration
"bitbake.conf" ) )
in fetcher_init
  File "/OE/openembedded/bitbake/lib/bb/persist_data.py", line 71, in
delDomain
but I run bitbake base-image command,I got error:
ERROR: Openembedded's config sanity checker detected a potential
misconfiguration.
        Either fix the cause of this error or at your own risk disable
the checker (see sanity.conf).
        Following is the list of potential problems / advisories:
        Using dash as /bin/sh causes various subtle build problems,
please use bash instead.
try:
except:
failed" % domain)
instead of
TEXT);" % domain)
try:
except:
failed" % domain)
instead of
main()
parseConfiguration
"bitbake.conf" ) )
in fetcher_init
delDomain
misconfiguration.
Change from using dash to bash, I'm not usre how to do it (I assume
you are using ubuntu), but the google should give the answer.
Also, be careful on the permissions on directories.
Philip
try:
  except:
failed" % domain)
instead of
TEXT);" % domain)
try:
  except:
failed" % domain)
instead of
    main()
parseConfiguration
"bitbake.conf" ) )
in fetcher_init
delDomain
misconfiguration.
> > Hello,
> > saved_tmpdir'
> PGP.sig
> < 1KViewDownload
I have one OT question: why do you ask general OpenEmbedded-related
question in BeagleBoard mailing list? There are plenty of OE mailing lists!
