NOTE: 1: /home/beagle/oe/openembedded/recipes/gettext/gettext-
native_0.17.bb, do_populate_staging (1633)
NOTE: Tasks Summary: Attempted 324 tasks of which 323 didn't need to
be rerun and 1 failed.
ERROR: '/home/beagle/oe/openembedded/recipes/qemu/qemu-
native_0.10.3.bb' failed
Please provide your suggestions for solving the issue.
no, it isn't. i'm using the dev branch, while you're using the
stable branch, so i really can't comment. i prefer to use the
development branch since i'd rather keep up with the latest fixes and
enhancements. it appears that there is an issue with the stable
branch, but someone else is going to have to address that.
> Hi Robert P. J. Day,
> I tried it two times from morning but no luck.
> Can you suggest what is the problem?
> TIA
> > > Hi,
> > > I followed the instructions given inhttp://www.angstrom-distribution.org/building-angstrom
> > > While I am trying to execute " bitbake console-image " getting the
> > > below ERROR.
first, please don't top post.
which branch of OE are you using for your build? as you can see,
i'm using the "dev" branch:
$ git branch
* org.openembedded.dev
stable/2009
and it is currently up to date with respect to "git pull". what is
the state of *your* working copy?
rday
Robert P. J. Day Waterloo, Ontario, CANADA
Linux Consulting, Training and Annoying Kernel Pedantry\.
>> > TIA
>> > > > Hi,
>> > > > below ERROR.
I am using SuSE 11.1 linux as host system.
Can anyone help where to get zlib headers installation file and how
should I install.
Please help me.
TIA
my system got struck after ~5hrs while executing the command and given
problem for login for sometime... so I forcefully made SHUTDOWN. Now
again I gave the command but encountered some errors http://pastebin.com/m751b5c64
Can anyone help in this regard is much helpful for me ?
TIA
HI,
The day it hung while executing bitbake base-image my linux system is
frequently hanging.
I am not able to any operations. It is frequently hanging.
PLEASE HELP ME IN THIS REGARD TO COME OUT OF THE PROBLEM.
HI,
frequently hanging.
If your whole host system really hangs just because of you are running bitbake then there's something seriously wrong (e.g. broken hardware) with your system. That is not a bitbake/OE related issue.
(You are not running bitbake as root, are you?)
Also please note that bitbaking for example x11-image might take up to 8-12 hours.
