Expansion Pins missing from my board?
All,
My BeagleBoard from Digikey came in recently. Within minutes the display was up on my LCD!
I noticed the expansion pins were not on my board, but the docs seem to indication they would be?
Is this a pre-production board or is this a normal rev-B board?
John Westerdale
Beer. Food. Unix#
The expansion header is not supplied with the Rev B version of the board.
westerj@optonline.net wrote:
All,
This is a normal board:
http://www.flickr.com/photos/jadon/2699489131/in/pool-beagleboard
Expansion connector isn't soldered by default.
Dirk
There are two ways to install the expansion connector, top side and
bottom side. I suspect different applications will need the connector
on either side, so I am glad to have the choice.
Philip
OK. So can I add the pins in?
Yes you can add the pins.
