I have a WD 2TB external USB drive. It mounts fine on my linux laptop. When I plug it into the beagleboneblack, it times out. Any help would be appreciated!
lsusb finds the device:
Bus 001 Device 003: ID 1058:2626 Western Digital Technologies, Inc.
dmesg:
[ 3965.568158] musb-hdrc musb-hdrc.1: VBUS_ERROR in a_wait_bcon (89, <AValid), retry #1, port1 00000104
[ 3966.776484] usb 1-1: new high-speed USB device number 3 using musb-hdrc
[ 3966.977419] usb 1-1: New USB device found, idVendor=1058, idProduct=2626, bcdDevice=10.28
[ 3966.977438] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3966.977446] usb 1-1: Product: My Passport 2626
[ 3966.977454] usb 1-1: Manufacturer: Western Digital
[ 3966.977461] usb 1-1: SerialNumber: 5758573245313048344E394B
[ 3966.985267] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 3967.008783] scsi host0: usb-storage 1-1:1.0
[ 3968.041574] scsi 0:0:0:0: Direct-Access WD My Passport 2626 1028 PQ: 0 ANSI: 6
[ 3968.042213] scsi 0:0:0:1: Enclosure WD SES Device 1028 PQ: 0 ANSI: 6
[ 3968.055140] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3968.061239] scsi 0:0:0:1: Attached scsi generic sg1 type 13
[ 3968.063025] sd 0:0:0:0: [sda] Spinning up disk…
[ 3969.096578] …not responding…
The BBB specs:
System: Host: DataIntegrity-Secondary Kernel: 4.19.94-ti-r42 armv7l bits: 32 compiler: gcc v: 8.3.0 Console: tty 1 dm: N/A
Distro: Debian GNU/Linux 10 (buster)
Machine: Type: ARM Device System: TI AM335x BeagleBone Black details: Generic AM33XX rev: N/A serial: 1516BBBK13E1
Memory: RAM: total: 483.4 MiB used: 128.3 MiB (26.5%)
RAM Report: unknown-error: dmidecode was unable to generate data
PCI Slots: ARM: No ARM data found for this feature.
CPU: Topology: Single Core model: ARMv7 v7l variant: cortex-a8 bits: 32 type: UP arch: v7l family: 7 model-id: 3
stepping: 2 microcode: N/A bogomips: 995
Speed: 1000 MHz min/max: 300/1000 MHz Core speed (MHz): 1: 1000
Features: edsp fastmult half neon thumb thumbee tls vfp vfpd32 vfpv3
Vulnerabilities: No CPU vulnerability/bugs data available.
Graphics: Message: No ARM data found for this feature.
Display: tty server: N/A driver: tty: 197x45
Message: Advanced graphics data unavailable in console for root.
Audio: Device-1: simple-audio-card driver: asoc_simple_card bus ID: N/A chip ID: simple-audio-card:sound
Sound Server: ALSA v: k4.19.94-ti-r42
Network: Message: No ARM data found for this feature.
IF-ID-1: can0 state: down mac: N/A
IF-ID-2: can1 state: down mac: N/A
IF-ID-3: eth0 state: up speed: 100 Mbps duplex: full mac: 80:30:dc:53:f6:f6
IP v4: 192.168.1.212/24 scope: global broadcast: 192.168.1.255
IP v6: 2600:1700:6d52:b1f0:8230:dcff:fe53:f6f6/64 type: dynamic mngtmpaddr scope: global
IP v6: 2600:1700:6d52:b1f0::31/64 scope: global
IP v6: fe80::8230:dcff:fe53:f6f6/64 scope: link
IF-ID-4: usb0 state: up speed: N/A duplex: N/A mac: 80:30:dc:53:f6:f8
IP v4: 192.168.7.2/24 scope: global broadcast: 192.168.7.255
IP v6: fe80::8230:dcff:fe53:f6f8/64 scope: link
IF-ID-5: usb1 state: up speed: N/A duplex: N/A mac: 80:30:dc:53:f6:fc
IP v4: 192.168.6.2/24 scope: global broadcast: 192.168.6.255
IP v6: fe80::8230:dcff:fe53:f6fc/64 scope: link
WAN IP: No WAN IP data found. Connected to the web? SSL issues?
Drives: Local Storage: total: 3.56 GiB used: 2.34 GiB (65.6%)
ID-1: /dev/mmcblk1 model: S10004 size: 3.56 GiB block size: physical: 512 B logical: 512 B serial: 0x7ae2584c
rev: 0x6 scheme: MBR
Message: No Optical or Floppy data was found.
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 3.56 GiB size: 3.44 GiB (96.67%) used: 2.34 GiB (67.9%) fs: ext4 block size: 4096 B
dev: /dev/mmcblk1p1 label: rootfs uuid: 39168434-dd05-449f-aa8a-c455aec0e138
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Sensors: Message: No sensors data was found. Is sensors configured?
Repos: Active apt repos in: /etc/apt/sources.list
1: deb http://deb.debian.org/debian buster main contrib non-free
2: deb http://deb.debian.org/debian buster-updates main contrib non-free
3: deb http://deb.debian.org/debian-security buster/updates main contrib non-free
4: deb [arch=armhf] http://repos.rcn-ee.com/debian/ buster main
Active apt repos in: /etc/apt/sources.list.d/plexmediaserver.list
1: deb https://downloads.plex.tv/repo/deb public main
Processes: CPU top: 5
1: cpu: 1.6% command: -bash pid: 2205 mem: 3.02 MiB (0.6%)
2: cpu: 1.5% command: [kworker/0:1h-mmc_complete] pid: 2210 mem: 0.00 MiB (0.0%)
3: cpu: 1.4% command: plex pid: 2016 mem: 30.9 MiB (6.3%)
4: cpu: 1.0% command: sshd: pid: 2201 mem: 5.23 MiB (1.0%)
5: cpu: 0.5% command: plex pid: 1863 mem: 40.9 MiB (8.4%)
Memory top: 5
1: mem: 40.9 MiB (8.4%) command: plex pid: 1863 cpu: 0.5%
2: mem: 37.5 MiB (7.7%) command: nodejs pid: 668 cpu: 0.3%
3: mem: 30.9 MiB (6.3%) command: plex pid: 2016 cpu: 1.4%
4: mem: 12.0 MiB (2.4%) command: plex pid: 2059 cpu: 0.0%
5: mem: 6.58 MiB (1.3%) command: init pid: 1 cpu: 0.1%
Info: Processes: 87 Uptime: 1h 05m Init: systemd v: 241 runlevel: 5 Compilers: gcc: 8.3.0 alt: 8 Shell: bash v: 5.0.3
running in: tty 1 (SSH) inxi: 3.0.32
