Anyone seen anything like this in their travels to point me in the right direction? Here is the dmesg transcript during boot when I don’t have the device plugged in (And later plug it in shown at the very bottom of the transcript):
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone30 (root@imx6q-sabrelite-1gb-1) (gcc version 4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu8) ) #1 SMP Thu Nov 14 06:23:24 UTC 2013
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c09a6e00, node_mem_map c0a22000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 129792 pages, LIFO batch:31
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0e32000 s14080 r8192 d14592 u36864
[ 0.000000] pcpu-alloc: s14080 r8192 d14592 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 fixrtc root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 507240k/507240k available, 17048k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08db468 (9038 kB)
[ 0.000000] .init : 0xc08dc000 - 0xc0925700 ( 294 kB)
[ 0.000000] .data : 0xc0926000 - 0xc09a9dc0 ( 528 kB)
[ 0.000000] .bss : 0xc09a9dc0 - 0xc0a211c0 ( 477 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000253] Calibrating delay loop… 663.07 BogoMIPS (lpj=647168)
[ 0.035032] pid_max: default: 32768 minimum: 301
[ 0.035185] Security Framework initialized
[ 0.035251] Mount-cache hash table entries: 512
[ 0.041256] Initializing cgroup subsys cpuacct
[ 0.041282] Initializing cgroup subsys memory
[ 0.041325] Initializing cgroup subsys blkio
[ 0.041429] CPU: Testing write buffer coherency: ok
[ 0.041863] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.041919] Setting up static identity map for 0x8060e908 - 0x8060e960
[ 0.042996] Brought up 1 CPUs
[ 0.043011] SMP: Total of 1 processors activated (663.07 BogoMIPS).
[ 0.043837] devtmpfs: initialized
[ 0.101484] pinctrl core: initialized pinctrl subsystem
[ 0.101648] rstctl core: initialized rstctl subsystem
[ 0.101995] regulator-dummy: no parameters
[ 0.102358] NET: Registered protocol family 16
[ 0.102888] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.108701] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.109167] platform 49000000.edma: alias fck already exists
[ 0.109187] platform 49000000.edma: alias fck already exists
[ 0.109201] platform 49000000.edma: alias fck already exists
[ 0.109955] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.110053] OMAP GPIO hardware version 0.1
[ 0.110967] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.111784] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.112565] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.112857] of_get_named_gpio_flags exited with status 52
[ 0.112878] gpio-rctrl rstctl.4: loaded OK
[ 0.116166] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.117523] cpsw.0: No hwaddr in dt. Using d0:ff:50:09:53:07 from efuse
[ 0.117544] cpsw.1: No hwaddr in dt. Using d0:ff:50:09:53:09 from efuse
[ 0.125914] bio: create slab at 0
[ 0.132815] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.132977] of_get_named_gpio_flags: can’t parse gpios property
[ 0.133125] vmmcsd_fixed: 3300 mV
[ 0.134838] SCSI subsystem initialized
[ 0.135112] usbcore: registered new interface driver usbfs
[ 0.135181] usbcore: registered new interface driver hub
[ 0.135414] usbcore: registered new device driver usb
[ 0.136804] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.137841] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.139229] DCDC1: at 1500 mV
[ 0.140091] vdd_mpu: 925 <–> 1325 mV at 1325 mV
[ 0.140972] vdd_core: 925 <–> 1150 mV at 1125 mV
[ 0.141797] LDO1: at 1800 mV
[ 0.142661] LDO2: at 3300 mV
[ 0.144184] LDO3: 1800 mV
[ 0.145060] LDO4: at 3300 mV
[ 0.145812] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.146404] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.146988] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.148606] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.148766] media: Linux media interface: v0.10
[ 0.148831] Linux video capture interface: v2.00
[ 0.148924] pps_core: LinuxPPS API ver. 1 registered
[ 0.149382] Advanced Linux Sound Architecture Driver Initialized.
[ 0.150030] NetLabel: Initializing
[ 0.150045] NetLabel: domain hash size = 128
[ 0.150051] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.150128] NetLabel: unlabeled traffic allowed by default
[ 0.150471] Switching to clocksource gp_timer
[ 0.184327] NET: Registered protocol family 2
[ 0.185032] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.185117] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.185207] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.185274] TCP: reno registered
[ 0.185290] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.185315] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.185581] NET: Registered protocol family 1
[ 0.186100] RPC: Registered named UNIX socket transport module.
[ 0.186114] RPC: Registered udp transport module.
[ 0.186122] RPC: Registered tcp transport module.
[ 0.186129] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.186643] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.186902] CPU PMU: attempt to register multiple PMU devices!
[ 0.186931] arm-pmu: probe of arm-pmu failed with error -28
[ 0.187237] omap2_mbox_probe: platform not supported
[ 0.347568] VFS: Disk quotas dquot_6.5.2
[ 0.347725] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.348650] NFS: Registering the id_resolver key type
[ 0.348739] Key type id_resolver registered
[ 0.348749] Key type id_legacy registered
[ 0.348794] fuse init (API version 7.20)
[ 0.349363] Btrfs loaded
[ 0.349476] msgmni has been set to 990
[ 0.351334] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.351355] io scheduler noop registered
[ 0.351363] io scheduler deadline registered
[ 0.351387] io scheduler cfq registered (default)
[ 0.352594] tps65217-bl tps65217-bl: no platform data provided
[ 0.352625] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.353192] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.354700] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.355019] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 1.089789] console [ttyO0] enabled
[ 1.094270] [drm] Initialized drm 1.1.0 20060810
[ 1.107104] brd: module loaded
[ 1.114467] loop: module loaded
[ 1.117892] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.125209] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.132500] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.139863] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.147153] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.161130] bone-capemgr bone_capemgr.9: Baseboard: ‘A335BNLT,0A6A,5113BBBK0383’
[ 1.168932] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-black
[ 1.207191] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 1.244295] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 1.281403] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 1.318513] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 1.324761] bone-capemgr bone_capemgr.9: slot #4: specific override
[ 1.331360] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[ 1.339406] bone-capemgr bone_capemgr.9: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[ 1.349535] bone-capemgr bone_capemgr.9: slot #5: specific override
[ 1.356133] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[ 1.364179] bone-capemgr bone_capemgr.9: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[ 1.374197] bone-capemgr bone_capemgr.9: slot #6: specific override
[ 1.380791] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[ 1.388836] bone-capemgr bone_capemgr.9: slot #6: ‘Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN’
[ 1.399322] bone-capemgr bone_capemgr.9: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.408208] bone-capemgr bone_capemgr.9: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.417060] bone-capemgr bone_capemgr.9: loader: before slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.425840] bone-capemgr bone_capemgr.9: loader: check slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.434543] bone-capemgr bone_capemgr.9: initialized OK.
[ 1.440138] bone-capemgr bone_capemgr.9: loader: before slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.449002] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.458994] OneNAND driver initializing
[ 1.463950] usbcore: registered new interface driver cdc_ether
[ 1.470131] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.478963] usbcore: registered new interface driver rndis_host
[ 1.485247] bone-capemgr bone_capemgr.9: loader: after slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.493946] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.502796] usbcore: registered new interface driver cdc_ncm
[ 1.508766] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware ‘cape-bone-2g-emmc1.dtbo’ for board-name ‘Bone-LT-eMMC-2G’, version ‘00A0’
[ 1.522940] usbcore: registered new interface driver cdc_acm
[ 1.528918] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.537321] Initializing USB Mass Storage driver…
[ 1.542466] bone-capemgr bone_capemgr.9: slot #4: dtbo ‘cape-bone-2g-emmc1.dtbo’ loaded; converting to live tree
[ 1.553193] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware ‘cape-boneblack-hdmi-00A0.dtbo’ for board-name ‘Bone-Black-HDMI’, version ‘00A0’
[ 1.567413] usbcore: registered new interface driver usb-storage
[ 1.573728] USB Mass Storage support registered.
[ 1.578788] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[ 1.585457] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[ 1.592367] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.601087] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.609888] bone-capemgr bone_capemgr.9: slot #5: dtbo ‘cape-boneblack-hdmi-00A0.dtbo’ loaded; converting to live tree
[ 1.621306] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.627923] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.633167] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.642526] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[ 1.650036] platform 4830e000.fb: alias fck already exists
[ 1.655944] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.655960] musb-hdrc: MHDRC RTL version 2.0
[ 1.655969] musb-hdrc: setup fifo_mode 4
[ 1.655985] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.656091] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.661162] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.667520] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[ 1.674454] bone-capemgr bone_capemgr.9: loader: done slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.683086] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.692412] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.697672] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.706488] bone-capemgr bone_capemgr.9: loader: after slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.715301] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.715315] musb-hdrc: MHDRC RTL version 2.0
[ 1.715322] musb-hdrc: setup fifo_mode 4
[ 1.715335] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.715429] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.720484] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.725796] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.731859] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware ‘cape-boneblack-hdmin-00A0.dtbo’ for board-name ‘Bone-Black-HDMIN’, version ‘00A0’
[ 1.746308] bone-capemgr bone_capemgr.9: slot #6: dtbo ‘cape-boneblack-hdmin-00A0.dtbo’ loaded; converting to live tree
[ 1.758041] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.766310] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[ 1.766392] usb usb1: default language 0x0409
[ 1.766429] usb usb1: udev 1, busnum 1, minor = 0
[ 1.766443] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.773597] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.781187] usb usb1: Product: MUSB HDRC host driver
[ 1.786407] usb usb1: Manufacturer: Linux 3.8.13-bone30 musb-hcd
[ 1.792720] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.798184] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 1.807805] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 1.814590] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.824800] usb usb1: usb_probe_device
[ 1.824820] usb usb1: configuration #1 chosen from 1 choice
[ 1.824872] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 1.824986] hub 1-0:1.0: usb_probe_interface
[ 1.824999] hub 1-0:1.0: usb_probe_interface - got id
[ 1.825019] hub 1-0:1.0: USB hub found
[ 1.829050] hub 1-0:1.0: 1 port detected
[ 1.833208] hub 1-0:1.0: standalone hub
[ 1.833219] hub 1-0:1.0: individual port power switching
[ 1.833230] hub 1-0:1.0: no over-current protection
[ 1.833239] hub 1-0:1.0: Single TT
[ 1.833251] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 1.833261] hub 1-0:1.0: power on to power good time: 10ms
[ 1.833289] hub 1-0:1.0: local power source is good
[ 1.833355] hub 1-0:1.0: enabling power on all ports
[ 1.834070] mousedev: PS/2 mouse device common for all mice
[ 1.841668] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.849223] 44e3e000.rtc: already running
[ 1.853677] i2c /dev entries driver
[ 1.858383] pps_ldisc: PPS line discipline registered
[ 1.863808] Driver for 1-wire Dallas network protocol.
[ 1.870558] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.878297] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-devel@redhat.com
[ 1.887261] cpuidle: using governor ladder
[ 1.891601] cpuidle: using governor menu
[ 1.896026] of_get_named_gpio_flags exited with status 6
[ 1.896040] of_get_named_gpio_flags: can’t parse gpios property
[ 1.896049] of_get_named_gpio_flags: can’t parse gpios property
[ 1.896072] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 1.903312] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[ 1.910052] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 1.917255] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 1.924579] mmc.5 supply vmmc_aux not found, using dummy regulator
[ 1.931445] omap_hsmmc mmc.5: pins are not configured from the driver
[ 1.938343] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 1.938395] hub 1-0:1.0: hub_suspend
[ 1.938425] usb usb1: bus auto-suspend, wakeup 1
[ 1.965187] of_get_named_gpio_flags: can’t parse gpios property
[ 1.965204] of_get_named_gpio_flags: can’t parse gpios property
[ 1.965212] of_get_named_gpio_flags: can’t parse gpios property
[ 1.965252] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[ 1.971441] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 1.979441] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[ 1.985826] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 1.992957] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 2.000640] mmc.11 supply vmmc_aux not found, using dummy regulator
[ 2.007386] omap_hsmmc mmc.11: pins are not configured from the driver
[ 2.041562] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 2.053288] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 2.060605] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 2.069587] leds-gpio gpio-leds.8: pins are not configured from the driver
[ 2.076841] of_get_named_gpio_flags exited with status 53
[ 2.076855] of_get_named_gpio_flags exited with status 54
[ 2.076866] of_get_named_gpio_flags exited with status 55
[ 2.076878] of_get_named_gpio_flags exited with status 56
[ 2.076896] of_get_named_gpio_flags exited with status 53
[ 2.077058] of_get_named_gpio_flags exited with status 54
[ 2.077182] of_get_named_gpio_flags exited with status 55
[ 2.077303] of_get_named_gpio_flags exited with status 56
[ 2.077654] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.084379] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 2.091599] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 2.099185] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 2.105509] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 2.112683] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 2.120544] usbcore: registered new interface driver usbhid
[ 2.126484] usbhid: USB HID core driver
[ 2.130585] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.139934] ashmem: initialized
[ 2.143634] logger: created 256K log ‘log_main’
[ 2.148614] mmc0: new high speed SDHC card at address 0007
[ 2.154664] logger: created 256K log ‘log_events’
[ 2.160128] mmcblk0: mmc0:0007 SD04G 3.67 GiB
[ 2.165093] logger: created 256K log ‘log_radio’
[ 2.170920] logger: created 256K log ‘log_system’
[ 2.176067] mmcblk0: p1 p2
[ 2.182222] of_get_named_gpio_flags exited with status 59
[ 2.183229] davinci_evm sound.14: nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[ 2.193253] TCP: cubic registered
[ 2.196911] NET: Registered protocol family 10
[ 2.202665] NET: Registered protocol family 17
[ 2.207805] Key type dns_resolver registered
[ 2.212506] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.220660] ThumbEE CPU extension supported.
[ 2.225194] Registering SWP/SWPB emulation handler
[ 2.231154] registered taskstats version 1
[ 2.237206] of_get_named_gpio_flags: can’t parse gpios property
[ 2.237230] tilcdc 4830e000.fb: No power control GPIO
[ 2.277073] mmc1: BKOPS_EN bit is not set
[ 2.283799] mmc1: new high speed MMC card at address 0001
[ 2.290034] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[ 2.295145] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 2.301717] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 2.309872] mmcblk1: p1 p2
[ 2.314800] mmcblk1boot1: unknown partition table
[ 2.321485] mmcblk1boot0: unknown partition table
[ 2.356194] tilcdc 4830e000.fb: found TDA19988
[ 2.361514] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.368468] [drm] No driver support for vblank timestamp query.
[ 2.375000] tilcdc 4830e000.fb: No connectors reported connected with modes
[ 2.382332] [drm] Cannot find any crtc or sizes - going 1024x768
[ 2.396843] Console: switching to colour frame buffer device 128x48
[ 2.408554] tilcdc 4830e000.fb: fb0: frame buffer device
[ 2.414228] tilcdc 4830e000.fb: registered panic notifier
[ 2.419920] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 2.474789] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.481212] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.488604] libphy: 4a101000.mdio: probed
[ 2.492855] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.502663] Detected MACID = d0:ff:50:09:53:07
[ 2.507292] cpsw 4a100000.ethernet: NAPI disabled
[ 2.513691] omap_rtc 44e3e000.rtc: setting system clock to 2014-01-20 04:20:05 UTC (1390191605)
[ 2.527899] ALSA device list:
[ 2.531071] #0: TI BeagleBone Black
[ 2.547884] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.556517] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.568655] devtmpfs: mounted
[ 2.572227] Freeing init memory: 292K
[ 3.409794] init: ureadahead main process (88) terminated with status 5
[ 4.890134] systemd-udevd[193]: starting version 204
[ 6.336695] init: plymouth main process (98) killed by ABRT signal
[ 6.356373] init: plymouth-splash main process (226) terminated with status 2
[ 7.217673] net eth0: initializing cpsw version 1.12 (0)
[ 7.220206] net eth0: phy found : id is : 0x7c0f1
[ 7.220306] libphy: PHY 4a101000.mdio:01 not found
[ 7.225390] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 7.247580] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.824601] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 8.649013] init: plymouth-log main process (296) terminated with status 1
[ 9.300172] init: plymouth-upstart-bridge main process (316) terminated with status 1
[ 10.297785] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
[ 10.297860] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.450374] init: failsafe main process (360) killed by TERM signal
[ 27.550559] gadget: using random self ethernet address
[ 27.550596] gadget: using random host ethernet address
[ 27.552364] usb0: MAC 6e:b3:a4:53:39:77
[ 27.552381] usb0: HOST MAC 72:a8:8d:e0:d0:c4
[ 27.556943] gadget: Mass Storage Function, version: 2009/09/11
[ 27.556967] gadget: Number of LUNs=1
[ 27.556993] lun0: LUN: removable file: /dev/mmcblk0p1
[ 27.557082] gadget: Multifunction Composite Gadget
[ 27.557121] gadget: g_multi ready
[ 27.557164] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 27.557529] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 27.557560] musb-hdrc musb-hdrc.0.auto: supports USB remote wakeup
[ 27.557644] usb usb2: default language 0x0409
[ 27.557682] usb usb2: udev 1, busnum 2, minor = 128
[ 27.557695] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 27.557706] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 27.557717] usb usb2: Product: MUSB HDRC host driver
[ 27.557728] usb usb2: Manufacturer: Linux 3.8.13-bone30 musb-hcd
[ 27.557738] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 27.558249] usb usb2: usb_probe_device
[ 27.558267] usb usb2: configuration #1 chosen from 1 choice
[ 27.558317] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[ 27.558457] hub 2-0:1.0: usb_probe_interface
[ 27.558472] hub 2-0:1.0: usb_probe_interface - got id
[ 27.558493] hub 2-0:1.0: USB hub found
[ 27.558520] hub 2-0:1.0: 1 port detected
[ 27.558532] hub 2-0:1.0: standalone hub
[ 27.558541] hub 2-0:1.0: individual port power switching
[ 27.558551] hub 2-0:1.0: no over-current protection
[ 27.558561] hub 2-0:1.0: Single TT
[ 27.558572] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 27.558583] hub 2-0:1.0: power on to power good time: 10ms
[ 27.558607] hub 2-0:1.0: local power source is good
[ 27.558690] hub 2-0:1.0: enabling power on all ports
[ 27.658685] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 27.658757] hub 2-0:1.0: hub_suspend
[ 27.658791] usb usb2: bus auto-suspend, wakeup 1
[ 29.722324] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 30.488175] usb usb1: usb auto-resume
[ 30.488233] hub 1-0:1.0: hub_resume
[ 30.488337] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 30.876191] init: plymouth-stop pre-start process (839) terminated with status 1
[ 120.750046] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[ 120.750325] hub 1-0:1.0: port 1, status 0101, change 0001, 12 Mb/s
[ 120.859676] hub 1-0:1.0: debounce: port 1: total 100ms stable 100ms status 0x101
[ 120.965165] usb 1-1: new full-speed USB device number 2 using musb-hdrc
[ 121.084268] usb 1-1: ep0 maxpacket = 8
[ 121.085958] usb 1-1: default language 0x0409
[ 121.090549] usb 1-1: udev 2, busnum 1, minor = 1
[ 121.090604] usb 1-1: New USB device found, idVendor=0403, idProduct=6001
[ 121.090643] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 121.090677] usb 1-1: Product: FT232R USB UART
[ 121.090710] usb 1-1: Manufacturer: FTDI
[ 121.090742] usb 1-1: SerialNumber: A700ahEf
[ 121.094286] usb 1-1: usb_probe_device
[ 121.094348] usb 1-1: configuration #1 chosen from 1 choice
[ 121.096216] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[ 121.101572] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[ 121.101693] hub 1-0:1.0: port 1 enable change, status 00000103
[ 121.208970] usbcore: registered new interface driver usbserial
[ 121.213415] usbcore: registered new interface driver usbserial_generic
[ 121.213652] usbserial: USB Serial support registered for generic
[ 121.256581] usbcore: registered new interface driver ftdi_sio
[ 121.256886] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 121.257269] ftdi_sio 1-1:1.0: usb_probe_interface
[ 121.257317] ftdi_sio 1-1:1.0: usb_probe_interface - got id
[ 121.257400] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
[ 121.257808] usb 1-1: Detected FT232RL
[ 121.257847] usb 1-1: Number of endpoints 2
[ 121.257882] usb 1-1: Endpoint 1 MaxPacketSize 64
[ 121.257917] usb 1-1: Endpoint 2 MaxPacketSize 64
[ 121.258164] usb 1-1: Setting MaxPacketSize 64
[ 121.280447] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
And this is the dmesg outut if I start it up with the device plugged in:
[ 0.000249] Calibrating delay loop… 663.07 BogoMIPS (lpj=647168)
[ 0.035026] pid_max: default: 32768 minimum: 301
[ 0.035177] Security Framework initialized
[ 0.035243] Mount-cache hash table entries: 512
[ 0.041284] Initializing cgroup subsys memory
[ 0.041326] Initializing cgroup subsys blkio
[ 0.041426] CPU: Testing write buffer coherency: ok
[ 0.041856] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.041911] Setting up static identity map for 0x8060e908 - 0x8060e960
[ 0.042978] Brought up 1 CPUs
[ 0.042994] SMP: Total of 1 processors activated (663.07 BogoMIPS).
[ 0.043822] devtmpfs: initialized
[ 0.101498] pinctrl core: initialized pinctrl subsystem
[ 0.101664] rstctl core: initialized rstctl subsystem
[ 0.102006] regulator-dummy: no parameters
[ 0.102369] NET: Registered protocol family 16
[ 0.102900] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.108722] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.109194] platform 49000000.edma: alias fck already exists
[ 0.109214] platform 49000000.edma: alias fck already exists
[ 0.109273] platform 49000000.edma: alias fck already exists
[ 0.109983] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.110079] OMAP GPIO hardware version 0.1
[ 0.111005] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.111834] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.112607] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.112895] of_get_named_gpio_flags exited with status 52
[ 0.112918] gpio-rctrl rstctl.4: loaded OK
[ 0.116217] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.117573] cpsw.0: No hwaddr in dt. Using d0:ff:50:09:53:07 from efuse
[ 0.117595] cpsw.1: No hwaddr in dt. Using d0:ff:50:09:53:09 from efuse
[ 0.125949] bio: create slab at 0
[ 0.132840] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.133000] of_get_named_gpio_flags: can’t parse gpios property
[ 0.133149] vmmcsd_fixed: 3300 mV
[ 0.134855] SCSI subsystem initialized
[ 0.135130] usbcore: registered new interface driver usbfs
[ 0.135196] usbcore: registered new interface driver hub
[ 0.135434] usbcore: registered new device driver usb
[ 0.136824] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.137869] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.139594] DCDC1: at 1500 mV
[ 0.140460] vdd_mpu: 925 <–> 1325 mV at 1325 mV
[ 0.141327] vdd_core: 925 <–> 1150 mV at 1125 mV
[ 0.142157] LDO1: at 1800 mV
[ 0.143034] LDO2: at 3300 mV
[ 0.144562] LDO3: 1800 mV
[ 0.145392] LDO4: at 3300 mV
[ 0.146137] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.146727] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.147285] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.148905] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.149066] media: Linux media interface: v0.10
[ 0.149131] Linux video capture interface: v2.00
[ 0.149221] pps_core: LinuxPPS API ver. 1 registered
[ 0.149675] Advanced Linux Sound Architecture Driver Initialized.
[ 0.150449] NetLabel: Initializing
[ 0.150462] NetLabel: domain hash size = 128
[ 0.150469] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.150545] NetLabel: unlabeled traffic allowed by default
[ 0.150728] Switching to clocksource gp_timer
[ 0.184662] NET: Registered protocol family 2
[ 0.185362] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.185445] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.185535] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.185602] TCP: reno registered
[ 0.185618] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.185643] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.185910] NET: Registered protocol family 1
[ 0.186426] RPC: Registered named UNIX socket transport module.
[ 0.186441] RPC: Registered udp transport module.
[ 0.186449] RPC: Registered tcp transport module.
[ 0.186456] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.186974] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.187229] CPU PMU: attempt to register multiple PMU devices!
[ 0.187258] arm-pmu: probe of arm-pmu failed with error -28
[ 0.187562] omap2_mbox_probe: platform not supported
[ 0.347928] VFS: Disk quotas dquot_6.5.2
[ 0.348190] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.349023] NFS: Registering the id_resolver key type
[ 0.349111] Key type id_resolver registered
[ 0.349122] Key type id_legacy registered
[ 0.349167] fuse init (API version 7.20)
[ 0.349735] Btrfs loaded
[ 0.349850] msgmni has been set to 990
[ 0.351714] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.351732] io scheduler noop registered
[ 0.351741] io scheduler deadline registered
[ 0.351767] io scheduler cfq registered (default)
[ 0.352968] tps65217-bl tps65217-bl: no platform data provided
[ 0.353000] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.353571] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.355086] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.355412] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 1.090133] console [ttyO0] enabled
[ 1.094611] [drm] Initialized drm 1.1.0 20060810
[ 1.107493] brd: module loaded
[ 1.114858] loop: module loaded
[ 1.118282] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.125585] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.132875] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.140236] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.147517] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.161445] bone-capemgr bone_capemgr.9: Baseboard: ‘A335BNLT,0A6A,5113BBBK0383’
[ 1.169237] bone-capemgr bone_capemgr.9: compatible-baseboard=ti,beaglebone-black
[ 1.207448] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 1.244553] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 1.281662] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 1.318771] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 1.325018] bone-capemgr bone_capemgr.9: slot #4: specific override
[ 1.331616] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 4
[ 1.339661] bone-capemgr bone_capemgr.9: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[ 1.349788] bone-capemgr bone_capemgr.9: slot #5: specific override
[ 1.356386] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 5
[ 1.364431] bone-capemgr bone_capemgr.9: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[ 1.374446] bone-capemgr bone_capemgr.9: slot #6: specific override
[ 1.381041] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 6
[ 1.389086] bone-capemgr bone_capemgr.9: slot #6: ‘Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN’
[ 1.399564] bone-capemgr bone_capemgr.9: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.408449] bone-capemgr bone_capemgr.9: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.417300] bone-capemgr bone_capemgr.9: loader: before slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.426077] bone-capemgr bone_capemgr.9: loader: check slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.434779] bone-capemgr bone_capemgr.9: initialized OK.
[ 1.440376] bone-capemgr bone_capemgr.9: loader: before slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.449236] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.459234] OneNAND driver initializing
[ 1.464191] usbcore: registered new interface driver cdc_ether
[ 1.470372] bone-capemgr bone_capemgr.9: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.479207] usbcore: registered new interface driver rndis_host
[ 1.485489] bone-capemgr bone_capemgr.9: loader: after slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.494187] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.503034] usbcore: registered new interface driver cdc_ncm
[ 1.509005] bone-capemgr bone_capemgr.9: slot #4: Requesting firmware ‘cape-bone-2g-emmc1.dtbo’ for board-name ‘Bone-LT-eMMC-2G’, version ‘00A0’
[ 1.523167] usbcore: registered new interface driver cdc_acm
[ 1.529146] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.537549] Initializing USB Mass Storage driver…
[ 1.542695] bone-capemgr bone_capemgr.9: slot #4: dtbo ‘cape-bone-2g-emmc1.dtbo’ loaded; converting to live tree
[ 1.553417] bone-capemgr bone_capemgr.9: slot #5: Requesting firmware ‘cape-boneblack-hdmi-00A0.dtbo’ for board-name ‘Bone-Black-HDMI’, version ‘00A0’
[ 1.567636] usbcore: registered new interface driver usb-storage
[ 1.573948] USB Mass Storage support registered.
[ 1.579012] bone-capemgr bone_capemgr.9: slot #4: #2 overlays
[ 1.585677] bone-capemgr bone_capemgr.9: slot #4: Applied #2 overlays.
[ 1.592581] bone-capemgr bone_capemgr.9: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.601297] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.610094] bone-capemgr bone_capemgr.9: slot #5: dtbo ‘cape-boneblack-hdmi-00A0.dtbo’ loaded; converting to live tree
[ 1.621510] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.628128] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.633375] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.642737] bone-capemgr bone_capemgr.9: slot #5: #4 overlays
[ 1.650264] platform 4830e000.fb: alias fck already exists
[ 1.656175] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.656190] musb-hdrc: MHDRC RTL version 2.0
[ 1.656199] musb-hdrc: setup fifo_mode 4
[ 1.656216] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.656319] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.661388] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.667746] bone-capemgr bone_capemgr.9: slot #5: Applied #4 overlays.
[ 1.674684] bone-capemgr bone_capemgr.9: loader: done slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 1.683317] bone-capemgr bone_capemgr.9: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.692638] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.697899] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.706708] bone-capemgr bone_capemgr.9: loader: after slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.715519] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.715532] musb-hdrc: MHDRC RTL version 2.0
[ 1.715540] musb-hdrc: setup fifo_mode 4
[ 1.715553] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.715650] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.720706] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.726019] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.732083] bone-capemgr bone_capemgr.9: slot #6: Requesting firmware ‘cape-boneblack-hdmin-00A0.dtbo’ for board-name ‘Bone-Black-HDMIN’, version ‘00A0’
[ 1.746553] bone-capemgr bone_capemgr.9: slot #6: dtbo ‘cape-boneblack-hdmin-00A0.dtbo’ loaded; converting to live tree
[ 1.758284] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.766551] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[ 1.766634] usb usb1: default language 0x0409
[ 1.766670] usb usb1: udev 1, busnum 1, minor = 0
[ 1.766682] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.773846] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.781435] usb usb1: Product: MUSB HDRC host driver
[ 1.786655] usb usb1: Manufacturer: Linux 3.8.13-bone30 musb-hcd
[ 1.792965] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.798427] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 1.808049] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 1.814823] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 1.825038] usb usb1: usb_probe_device
[ 1.825058] usb usb1: configuration #1 chosen from 1 choice
[ 1.825112] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 1.825226] hub 1-0:1.0: usb_probe_interface
[ 1.825239] hub 1-0:1.0: usb_probe_interface - got id
[ 1.825258] hub 1-0:1.0: USB hub found
[ 1.829290] hub 1-0:1.0: 1 port detected
[ 1.833442] hub 1-0:1.0: standalone hub
[ 1.833454] hub 1-0:1.0: individual port power switching
[ 1.833464] hub 1-0:1.0: no over-current protection
[ 1.833473] hub 1-0:1.0: Single TT
[ 1.833485] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 1.833495] hub 1-0:1.0: power on to power good time: 10ms
[ 1.833522] hub 1-0:1.0: local power source is good
[ 1.833589] hub 1-0:1.0: enabling power on all ports
[ 1.834327] mousedev: PS/2 mouse device common for all mice
[ 1.841932] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.849668] i2c /dev entries driver
[ 1.854419] pps_ldisc: PPS line discipline registered
[ 1.859853] Driver for 1-wire Dallas network protocol.
[ 1.866601] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.874335] device-mapper: ioctl: 4.23.1-ioctl (2012-12-18) initialised: dm-devel@redhat.com
[ 1.883283] cpuidle: using governor ladder
[ 1.887620] cpuidle: using governor menu
[ 1.892032] of_get_named_gpio_flags exited with status 6
[ 1.892044] of_get_named_gpio_flags: can’t parse gpios property
[ 1.892054] of_get_named_gpio_flags: can’t parse gpios property
[ 1.892078] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 1.899319] omap_hsmmc mmc.5: Failed to get rstctl; not using any
[ 1.906049] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 1.913248] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 1.920574] mmc.5 supply vmmc_aux not found, using dummy regulator
[ 1.927437] omap_hsmmc mmc.5: pins are not configured from the driver
[ 1.934335] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 1.934388] hub 1-0:1.0: hub_suspend
[ 1.934417] usb usb1: bus auto-suspend, wakeup 1
[ 1.961546] of_get_named_gpio_flags: can’t parse gpios property
[ 1.961563] of_get_named_gpio_flags: can’t parse gpios property
[ 1.961572] of_get_named_gpio_flags: can’t parse gpios property
[ 1.961611] gpio-rctrl rstctl.4: gpio_rctrl_request eMMC_RSTn
[ 1.967801] omap_hsmmc mmc.11: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 1.975802] gpio-rctrl rstctl.4: gpio_rctrl_deassert eMMC_RSTn
[ 1.982187] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 1.989317] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 1.996752] mmc.11 supply vmmc_aux not found, using dummy regulator
[ 2.003694] omap_hsmmc mmc.11: pins are not configured from the driver
[ 2.037907] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 2.049638] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 2.056955] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 2.065937] leds-gpio gpio-leds.8: pins are not configured from the driver
[ 2.073194] of_get_named_gpio_flags exited with status 53
[ 2.073208] of_get_named_gpio_flags exited with status 54
[ 2.073219] of_get_named_gpio_flags exited with status 55
[ 2.073231] of_get_named_gpio_flags exited with status 56
[ 2.073249] of_get_named_gpio_flags exited with status 53
[ 2.073409] of_get_named_gpio_flags exited with status 54
[ 2.073536] of_get_named_gpio_flags exited with status 55
[ 2.073659] of_get_named_gpio_flags exited with status 56
[ 2.074005] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.080723] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 2.087945] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 2.095547] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 2.101873] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 2.109052] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 2.116918] usbcore: registered new interface driver usbhid
[ 2.122861] usbhid: USB HID core driver
[ 2.126964] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.136307] ashmem: initialized
[ 2.140013] logger: created 256K log ‘log_main’
[ 2.145005] mmc0: new high speed SDHC card at address 0007
[ 2.151033] logger: created 256K log ‘log_events’
[ 2.156501] mmcblk0: mmc0:0007 SD04G 3.67 GiB
[ 2.161463] logger: created 256K log ‘log_radio’
[ 2.167288] logger: created 256K log ‘log_system’
[ 2.172438] mmcblk0: p1 p2
[ 2.178644] of_get_named_gpio_flags exited with status 59
[ 2.179601] davinci_evm sound.14: nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[ 2.189625] TCP: cubic registered
[ 2.193282] NET: Registered protocol family 10
[ 2.199028] NET: Registered protocol family 17
[ 2.204057] Key type dns_resolver registered
[ 2.208770] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 2.216927] ThumbEE CPU extension supported.
[ 2.221468] Registering SWP/SWPB emulation handler
[ 2.227417] registered taskstats version 1
[ 2.233561] of_get_named_gpio_flags: can’t parse gpios property
[ 2.233586] tilcdc 4830e000.fb: No power control GPIO
[ 2.273421] mmc1: BKOPS_EN bit is not set
[ 2.280142] mmc1: new high speed MMC card at address 0001
[ 2.286386] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[ 2.291516] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 2.298087] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 2.306247] mmcblk1: p1 p2
[ 2.311168] mmcblk1boot1: unknown partition table
[ 2.317861] mmcblk1boot0: unknown partition table
[ 2.352540] tilcdc 4830e000.fb: found TDA19988
[ 2.357862] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 2.364814] [drm] No driver support for vblank timestamp query.
[ 2.371342] tilcdc 4830e000.fb: No connectors reported connected with modes
[ 2.378671] [drm] Cannot find any crtc or sizes - going 1024x768
[ 2.393192] Console: switching to colour frame buffer device 128x48
[ 2.404902] tilcdc 4830e000.fb: fb0: frame buffer device
[ 2.410579] tilcdc 4830e000.fb: registered panic notifier
[ 2.416268] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 2.471145] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.477568] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.484999] libphy: 4a101000.mdio: probed
[ 2.489246] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 2.499049] Detected MACID = d0:ff:50:09:53:07
[ 2.503683] cpsw 4a100000.ethernet: NAPI disabled
[ 2.510084] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.524189] ALSA device list:
[ 2.527365] #0: TI BeagleBone Black
[ 2.535349] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.543091] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 9.447772] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 9.453991] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 27570
[ 9.454530] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 27625
[ 9.454602] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 27624
[ 9.454653] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 25686
[ 9.454703] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 27619
[ 9.454747] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 27618
[ 9.454795] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 27565
[ 9.454836] EXT4-fs (mmcblk0p2): 7 orphan inodes deleted
[ 9.460478] EXT4-fs (mmcblk0p2): recovery complete
[ 10.886124] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.894711] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 10.906843] devtmpfs: mounted
[ 10.910541] Freeing init memory: 292K
[ 11.724888] init: ureadahead main process (89) terminated with status 5
[ 13.197633] systemd-udevd[194]: starting version 204
[ 14.711970] init: plymouth main process (99) killed by ABRT signal
[ 14.733153] init: plymouth-splash main process (229) terminated with status 2
[ 15.401997] net eth0: initializing cpsw version 1.12 (0)
[ 15.404381] net eth0: phy found : id is : 0x7c0f1
[ 15.404404] libphy: PHY 4a101000.mdio:01 not found
[ 15.409483] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 15.435083] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.097423] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 16.962265] init: plymouth-log main process (297) terminated with status 1
[ 17.589319] init: plymouth-upstart-bridge main process (318) terminated with status 1
[ 18.481508] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
[ 18.481579] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 22.811747] init: failsafe main process (362) killed by TERM signal
[ 31.209271] gadget: using random self ethernet address
[ 31.209307] gadget: using random host ethernet address
[ 31.211013] usb0: MAC ee:18:59:62:1b:3c
[ 31.211032] usb0: HOST MAC 36:f3:09:b0:d6:62
[ 31.215424] gadget: Mass Storage Function, version: 2009/09/11
[ 31.215448] gadget: Number of LUNs=1
[ 31.215474] lun0: LUN: removable file: /dev/mmcblk0p1
[ 31.215551] gadget: Multifunction Composite Gadget
[ 31.215586] gadget: g_multi ready
[ 31.215633] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 31.215997] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 31.216028] musb-hdrc musb-hdrc.0.auto: supports USB remote wakeup
[ 31.216113] usb usb2: default language 0x0409
[ 31.216150] usb usb2: udev 1, busnum 2, minor = 128
[ 31.216163] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 31.216175] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 31.216186] usb usb2: Product: MUSB HDRC host driver
[ 31.216197] usb usb2: Manufacturer: Linux 3.8.13-bone30 musb-hcd
[ 31.216207] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 31.216714] usb usb2: usb_probe_device
[ 31.216733] usb usb2: configuration #1 chosen from 1 choice
[ 31.216784] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[ 31.216920] hub 2-0:1.0: usb_probe_interface
[ 31.216933] hub 2-0:1.0: usb_probe_interface - got id
[ 31.216953] hub 2-0:1.0: USB hub found
[ 31.216979] hub 2-0:1.0: 1 port detected
[ 31.216991] hub 2-0:1.0: standalone hub
[ 31.217000] hub 2-0:1.0: individual port power switching
[ 31.217010] hub 2-0:1.0: no over-current protection
[ 31.217019] hub 2-0:1.0: Single TT
[ 31.217031] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 31.217041] hub 2-0:1.0: power on to power good time: 10ms
[ 31.217066] hub 2-0:1.0: local power source is good
[ 31.217152] hub 2-0:1.0: enabling power on all ports
[ 31.317284] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 31.317361] hub 2-0:1.0: hub_suspend
[ 31.317394] usb usb2: bus auto-suspend, wakeup 1
[ 33.296356] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 33.443066] usb usb1: usb auto-resume
[ 33.443125] hub 1-0:1.0: hub_resume
[ 33.443229] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 33.714867] init: plymouth-stop pre-start process (818) terminated with status 1
