I am trying to connect the beagle bone black wireless over USB. but it is getting failed. I take the log over serial port. and those are given below. I am getting RNDIS command error -524, 0/24 . I also tried by booting latest debian image from SD card and that is also not worked. I am new to beagle bone .anybody can please me help out this? Thanks
U-Boot SPL 2017.01-00006-g55e748eda0 (Jan 18 2017 - 13:01:45)
Trying to boot from MMC2
U-Boot 2017.01-00006-g55e748eda0 (Jan 18 2017 - 13:01:45 -0600), Build: jenkins-github_Bootloader-Builder-503
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
Using default environment
Board: BeagleBone Black
Model: BeagleBone Black Wireless
not set. Validating first E-fuse MAC
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
Could not get PHY for cpsw: addr 0
cpsw
Press SPACE to abort autoboot in 2 seconds
board_name=[BBBW] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Bad device 0:2 0x82000000 **
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
2062 bytes read in 30 ms (66.4 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.19.94-ti-r42 …
10095592 bytes read in 657 ms (14.7 MiB/s)
loading /boot/dtbs/4.19.94-ti-r42/am335x-boneblack-wireless.dtb …
61131 bytes read in 75 ms (795.9 KiB/s)
debug: [uboot_fdt_buffer=] …
loading /boot/initrd.img-4.19.94-ti-r42 …
6589689 bytes read in 438 ms (14.3 MiB/s)
debug: [console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] …
debug: [bootz 0x82000000 0x88080000:648cf9 0x88000000] …
Loading Ramdisk to 8f9b7000, end 8ffffcf9 … OK
Loading Device Tree to 8f9a5000, end 8f9b6eca … OK
Starting kernel …
[ 0.000778] timer_probe: no matching timers found
[ 0.115526] l4_wkup_cm:clk:0010:0: failed to disable
[ 1.243838] omap_voltage_late_init: Voltage driver support not added
[ 1.447336] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1000000000 (-34)
Debian GNU/Linux 10 beaglebone ttyS0
BeagleBoard.org Debian Buster IoT Image 2020-04-06
Support: Beagleboard:BeagleBoneBlack Debian - eLinux.org
default username:password is [debian:temppwd]
beaglebone login: [ 41.935396] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 42.415044] PM: Cannot get wkup_m3_ipc handle
[ 52.788497] musb_g_ep0_irq 691: SetupEnd came in a wrong ep0stage in/status
[ 53.221726] RNDIS command error -524, 0/24
