Failed to flash eMMC from SD card...Using BBB-blank-debian-8.7-lxqt-4gb-armhf-2017-01-22-4gb.img
Failed with the signature-
llocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
failed_Logs.txt (27.7 KB)
Are you using a 5Volt DC power supply???
in /opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
Enable the [mkfs_options="-c"] option and try again:
https://github.com/RobertCNelson/boot-scripts/blob/master/tools/eMMC/init-eMMC-flasher-v3.sh#L29-L36
On Fri, 3 Feb 2017 12:17:07 -0600, Robert Nelson
<robertcnelson@gmail.com> declaimed the
following:
==> Formatting rootfs: /dev/mmcblk1p1 complete
==> Creating temporary rootfs directory (/tmp/rootfs)
==> Mounting /dev/mmcblk1p1 to /tmp/rootfs
  <SNIP>
[ 76.424892] EXT4-fs error (device mmcblk0p1): ext4_lookup:1583: inode
#48103: comm rsync: deleted inode referenced: 57566
  Pardon my jumping in, but based on the device names, those (to me --
admittedly I'm not well up on Linux device/file systems) look like
corruption on the source SD card, not the destination eMMC.
Good Catch, yes you are right. Looks like the initial microSD flash failed..
