Failed to load capes during boot
Seems I'm unable to load established capes (this is after running make all_arm, make install_arm from bb.org-overlays):
Is this still the issue where custom capes can't load at boot, and one must use /etc/default/capemgr (on a 4.1.6-ti kernel)? TIA...
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.6-ti-r15 (root@a5-imx6q-wandboard-2gb) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Fri Sep 11 01:18:50 UTC 2015
[ 0.000000] Kernel command line: console=ttyO0,115200n8 bone_capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN bone_capemgr.enable_partno=BB-ADC,BB-BONE-REPLICAP root=UUID=69f859b1-c308-41c9-8ca7-a3d0042031e8 ro rootfstype=ext4 rootwait fixrtc coherent_pool=1M quiet
[ 3.718808] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,00C0,3214BBBK4221'
[ 3.718845] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 3.778229] bone_capemgr bone_capemgr: slot #0: No cape found
[ 3.808225] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 3.838222] bone_capemgr bone_capemgr: slot #1: No cape found
[ 3.898220] bone_capemgr bone_capemgr: slot #2: No cape found
[ 3.928053] bone_capemgr bone_capemgr: Invalid signature 'ffffffff' at slot 3
[ 3.935348] bone_capemgr bone_capemgr: slot #3: No cape found
[ 3.941176] bone_capemgr bone_capemgr: enabled_partno PARTNO 'BB-ADC' VER 'N/A' PR '0'
[ 3.941195] bone_capemgr bone_capemgr: slot #4: override
[ 3.941210] bone_capemgr bone_capemgr: Using override eeprom data at slot 4
[ 3.941226] bone_capemgr bone_capemgr: slot #4: 'Override Board Name,00A0,Override Manuf,BB-ADC'
[ 3.941343] bone_capemgr bone_capemgr: enabled_partno PARTNO 'BB-BONE-REPLICAP' VER 'N/A' PR '0'
[ 3.941356] bone_capemgr bone_capemgr: slot #5: override
[ 3.941368] bone_capemgr bone_capemgr: Using override eeprom data at slot 5
[ 3.941382] bone_capemgr bone_capemgr: slot #5: 'Override Board Name,00A0,Override Manuf,BB-BONE-REPLICAP'
[ 3.941869] bone_capemgr bone_capemgr: initialized OK.
[ 4.978395] bone_capemgr bone_capemgr: loader: failed to load slot-5 BB-BONE-REPLICAP:00A0 (prio 0)
[ 4.987789] bone_capemgr bone_capemgr: loader: failed to load slot-4 BB-ADC:00A0 (prio 0)
^these are not setup as overlays in v4.1.x...
From /boot/uEnv.txt enable:
dtb=am335x-boneblack-overlay.dtb
If you want the eMMC:
dtb=am335x-boneblack-emmc-overlay.dtb
Ah yeah, I noticed there was no dtb= set by default in uEnv.txt. I meant to ask about that. What does it default to if nothing is uncommented in the default uEnv.txt?
It'll default to whatever u-boot detected.. for the black..
am335x-boneblack.dtb gets loaded by default..
