I'm having trouble with getting an SD Card programmed from an image
working. Basically, I'm formatting the FAT partition of a loop device
and the writin the loopback image to the card. On boot and power, I
just see the ASIC id and nothing else. However formatting the sdcard
directly and copying the bootloader etc works.
This doesn't work:
losetup /dev/loop2 <img-name>
mkfs.msdos /dev/loop2 -n boot
mount /dev/loop2 /tmp/mnt
cp MLO ... /tmp/mnt
But this does work,
mkfs.msdos /dev/mmcblk0p1 -n boot
mount /dev/mmcblk0p1 /tmp/mnt
cp MLO ... /tmp/mnt
I initially thought since I was not specifying the loop device size,
it was switching to FAT32, but specifying a smaller loop device size
using --sizelimit doesn't change anything. Specifying -F 16 doesn't
make it work either.
I am curious to know what is different. Let me know if I'm missing
something obvious.
Joel
This doesn't work:
So you're in superfloppy mode now
cp MLO ... /tmp/mnt
And how are you writing that back to the card?
Joel,
Are you certain that the master boot record is the same in both cases? The ROM boot loader is very picky about that. Also ensure that all data between the MBR and the first partition start is 0. I presume you are creating the SD card image blank from /dev/zero but you don't show that below.
Also have you tried reading the image back and doing a comparison? If you control the environment you should be able to get a decent compare. (Zero the first N MB of the fat partition on the card before formating it. Don't zero all of it, people have seen issues with SD cards not handling that well.)
Bill
Joel,
Hi William,
I don't think its an MBR issue because just reformatting the FAT
partition after writing to the MMC card fixes it, so the issue is with
FAT
My loopback file is sparse to begin so it should read back zeros.
dd if=/dev/zero of=image bs=4k count=1 seek=$((256*1024))
well.)
Thanks, I'll try this.
Joel
So you're creating a 'superfloppy' with no partition table and the fs on the full disk.
And stop putting me in CC:, this is a subscriber only list, so if I can post to it I can receive your mails without CC:
Hi Koen,
This doesn't work:
cp MLO ... /tmp/mnt
I'm doing:
dd if=image of=/dev/mmcblk0 bs=10M
The dd command writes the whole image including the partition table,
fat and fs partitions to the card. The image file is an SD card image.
OK.
Joel
You said you're doing:
1) losetup /dev/loop2 <img-name>
That assigns the full image to loop2, so loop2 is like the complete sd card
2) mkfs.msdos /dev/loop2 -n boot
Now you format the complete card as fat, overwriting any partition table you had
3) mount /dev/loop2 /tmp/mnt
mount, nothing strange here
4) cp MLO ... /tmp/mnt
and nothing strange there.
But if you dd this to your SD card, you will only no partition table, only a fat fs -> superfloppy
1) losetup /dev/loop2<img-name>
Sorry that I didn't mention I was passing an offet to losetup [1]
Joel
[1] oe-core/meta/classes/image_types.bbclass at 04efd0c02dd004df260cb8e64875e5c046eec9a9 · joelagnel/oe-core · GitHub
32256, a truly magic number
This seems to be it, I can boot now. Thank you!
-Joel
