I’m now trying to install Fedora 20 on my BBB, with following instructions.
https://fedoraproject.org/wiki/Architectures/ARM/F20/Installation#For_the_BeagleBone_Black
Now I completed this procedure on Ubuntu 13.10, and installed SD card into the board then plugged USB cable with pressing SW2.
But nothing happened except the PWR LED lits.
I don’t have any idea what kind of information I may need to solve this problem.
So please give me some advice of what to inspect.
I’ve done the followings.
*Booted without SD card and it succeeded.
*Checked SD card’s partition. There are three partitions (UBOOT, _swap, and __), it seems reasonable.
*Created boot SD card on windows, with win32DiskImager and VFAT file. But it doesn’t work.
Satoki
I'm now trying to install Fedora 20 on my BBB, with following instructions.
I don't have any idea what kind of information I may need to solve this
problem.
using a usb-serial cable to show what you have so far would help..
ask #fedora-arm on freenode, it's there image..
I've done the followings.
*Checked SD card's partition. There are three partitions (UBOOT, _swap, and
doesn't work.
hi, Robert
Thank you for your advice.The problem has been solved with usb-serial cable.
I’ll ask this kind on freenode next time.
2014年1月8日水曜日 22時57分06秒 UTC+9 RobertCNelson:
