I have tried to configure and build FFmpeg from source ffmpeg-0.5
version.
I have did make disclean before configuration.
configuration option is as per below:
"./configure --prefix=/home/Rachit/Developments/ffmpeg/ --enable-cross-
compile --cc="arm-none-linux-gnueabi-gcc" --host-cflags="-O3 -pipe -
march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp -ftree-
vectorize -ffast-math" --arch=arm --cpu=cortex-a8"
it has configured successfully then I did "make"
So After few building process I got following error:
cp -p ffmpeg_g ffmpeg
strip ffmpeg
strip: Unable to recognise the format of the input file `ffmpeg'
make: *** [ffmpeg] Error 1
How to solve this error?
I have also tried with 'bitbake ffmpeg" and it has successfully
created package.
Actually I am looking to build application which require libavcodec
and libavformat lib. So I am looking to build FFmpeg.
Please guide if i am looking wrong path.
Rachit
