FFT on PRU
Is there any library for do FFT calculations on the PRU??
thanks
If such exists or technically feasible :slight_smile:
It’s unlikely that you’ll find a complete solution running on PRUSS, since PRU assembler has very limited math capability (+, -, * and boolean operators). Division is not supported (except by factors of 2) and trigonometry is far beyond the scope.
But it should be possible to generate a hybrid solution with look-up tables, pre-computed on the host CPU and the PRU doing the simple math. I haven’t seen such a solution yet.
Happy coding, share your results!
BR
