File Your Income-tax return in 3 easy steps - myITreturn.com
myITreturn.com
Income-tax filing - easy!
(File your IT return in 5 minutes)
Skorydov myITreturn makes filing simple (and easy).
Start FREE by creating a user…
Using the e-filing application is FREE. You need to pay only once you are confirming for e-filing. Get started now
e-filing is easy, secure and takes minutes to file.
myITreturn assures that application is secure, fast and extremely easy to use. You will not need to submit any paper proof of TDS, earnings, deductions etc.
Maximum Refund Guaranteed (yes!)
myITreturn has been tested by experts and used by thousands to file their IT return with maximum refund.
That’s all for now. So create your login now!
and benefit from myITreturn.com. You should also invite your family and friends to e-file their IT return.
About myITreturn.com
Website address
https://myITreturn.com
About:
myITreturn.com is a web based Income-tax return filing solution for Individuals.
myITreturn.com is a project built on the idea to make the ever increasing tax filing headache a thing of the past. You should find this website very easy to use and very intuitive to use.
Pricing:
Rs. 199/- only
To start filing click the link below:
https://myitreturn.com
Skorydov Green Skorydov myITreturn.com - Go green. File your tax returns electronically.
*This message and any attachment is confidential and may be privileged or otherwise protected from disclosure. If you are not an intended recipient, please notify the sender and delete this message and any attachment immediately. If you are not an intended recipient you must not copy this message or attachment or disclose the contents to any other person. Unless otherwise specifically stated no legally binding commitments are created by this email. Any opinions expressed in this message are those of the author and do not necessarily reflect the opinions of any one else. Please do not reply to this message. [Published on 10/05/2008]
