Initial goals:
Porting CTAG face2|4 Audio Card drivers to BeagleBoard-X15 (TI AM5728)
Before the GSoC project, the soundcard driver was only compatible with BeagleBone Black/Green- Create library to make use of C66x DSPs (especially for audio applications)
Development Process: -
- Before I started with development I did some research and planning for both project parts:
Part 1: Porting CTAG face2|4 Audio Card drivers to BB-X15
AM5728 pin multiplexing (e.g. calculated offset addresses for device tree)
Multichannel Audio Serial Port (McASP)
Standard audio drivers of BB-X15 (i.e. simple-audiocard, hdmi)
Device tree (dra74x.dtsi, am57xx-beagle-x15.dts)a- Part 2: Create library to make use of C66x DSPs
TI DSPLIB- 1. First I focused on soundcard driver development
Created device tree for SPI, McASP and ASoC soundcard configuration
Tested SPI with new device tree:
No SPIDEV device tree available for BB-X15 for testing
When hw_params() is triggered in ASoC machine driver, SPI changes have to occur
No changes detected with oscilloscope (serial debug) on Chip Select and MOSI
Turned out that problem was caused by breakout board and bug in device tree (pin offset address)- Tested McASP (I2S) interface:
Master clock for McASP is configured differently (compared with BeagleBone Black/Green (BBB/BBG))
Added device tree node property to distinguish between BBB/BBG and did some modifications in probe function to configure clocks differently
Kernel crash occured when DAI of McASP (bitclock / frameclock) is triggered (biggest problem in my whole GSoC project)
By disabling recovery in remoteproc kernel crash can be avoid and everything works fine- 2. Library (libdsp-x15) to make use of C66x DSPs (especially for audio applications)
Began with small DSP tests (e.g. TI OpenCL examples)
Had some problems with IFFT which was caused by wrong generated twiddle factors- Integrated Fast Fourier Transformation (FFT) and Inverse Fast Fouriere Transformations (IFFT)
A plot of FFT/IFFT test can be found here- Integrated Biquad filter
A Plot of biquad filter (200Hz cutoff / 0.707 Q factor / 6 dB gain) test with 1 kHz sine input signal can be found here- Created demo applications for spectrum plotting in real time
Created multi channel crossover demo application with finite impulse response biquad filter (not completely finished yet)
What I have achieved in comparison with initial goals: -
Porting soundcard drivers to BeagleBoard-X15:
This project part was achieved completely (except that remoteproc recovery has to be disabled to avoid kernel crash)- Create library to make use of C66x DSPs:
One sub goal was to continuously calculate the spectrum of an audio input channel
Has been realized with Jack Audio Connection Kit (JACK) and SDL1- Moreover an additional demo application which implements a frequency crossover with a biquad filter has been created (nearly):
Still some problems with real time audio signal via JACK (which I want to fix before final GSoC deadline)
Short feature description of both projects parts:
- CTAG face2|4 Audio Card can be used with BB-X15 and is still backwards compatible BBB/BBG (if device tree node of SBC is not set, BBB/BBG probe routine is called by default)
- All channels / features of audio card (AD1938 audio codec) can be used
- Pull Request for beagleboard kernel has been created already1. C66x DSP lib (libdsp-x15) offers the following operations:
- Fast Fourier Transformation (efficiency is linear to input samples). FFT with N=16384 takes about 2 milliseconds.
- Inverse Fast Fourier Transformation (efficiency is equal with FFT)
- Biquad filter (takes about 0.3 ms for 512 input samples)
Future Work:
- In the future I want to extend / improve the DSP library (libdsp-x15) and use the BB-X15 in connection with CTAG face2|4 Audio Card for a modular synthesizer modul in Eurorack format together with my mentor Robert Manzke
- Here are some of the ideas I want to implement with my library:
- Multi channel convolution reverb with FFT
- Additive synth (user can “draw” spectrum which is transformed to time domain with IFFT)
- GUI should be created with QT and be run without X11 or Desktop environment for performance
- Still some problems with QT (runtime errors due to OpenCL type conflicts of TI llvm) which I want to fix
- Realtime plots should be implemented with QT as well- Demo video
Project References:
