In the meanwhile I'd like to ask you if Angstrom is the best choice to do what I described above. I see other OS: Debian, Mamona, Mojo... What are the differences among them? How to select the best for a specific application?
Is there a tutorial which describe how to develop, download and debug C/C++ QT-based application?
I forgot to ask if you suggest to use a Linux OS (as developing system) or a Windows one may be work as well. I have both on my machine, so it isn't a problem use one or the other.
Marco Trapanese
Femtotech
Italy
Marco,
I don't know how to change screen resolution. Someone will probably
chime in soon, or else you could ask over at the IRC.
Ångström has by far the best support for BeagleBoard, especially Koen
Kooi. Ångström is optimized for embedded systems so does better on a
card with only 128 MB of DRAM. It does have Qt-embedded: see
http://groups.google.com/group/beagleboard/browse_thread/thread/17dd128c3f8816cf/db43ffa1c18a8e83?lnk=gst&q=Qt#db43ffa1c18a8e83.
I don't know where there might be a tutorial. I've never used Qt
myself: I avoid C++ whenever possible, especially for embedded
systems.
For development Linux is almost always your best choice since it will
provide the tools you need and you won't have to jump through hoops to
get them to work. I personally use Windows 2000 because I need it for
other work, and just to be ornery. ["To be ornery" means to be
difficult just for the sake of being difficult.]
John
Hello!
Few short questions:
1) http://code.google.com/p/beagleboard/wiki/BeagleBoardDiagnostics
After type "Execute the boot command" I should get
OMAP3 beagleboard.org # run bootcmd
reading uImage
1856680 bytes read
reading rd-ext2.bin
3394477 bytes read
instead I get:
0 bytes read
reading rd-ext2.bin
3394477 bytes read
Wrong Image Format for bootm command
ERROR: can't get kernel image!
I copied MLO first to the SD. I also downloaded the files twice to be sure they aren't corrupted.
2) http://elinux.org/BeagleBoardBeginners - Angstrom
When I boot with external power supply and USB in host mode I can login with a mouse or a keyboard. When I power the beagleboard from my desktop PC through the USB cable I can login from the serial terminal, but on the screen I see the selection language window and I can't do anything because I can't use neither the mouse nor the keyboard (USB is NOT in host mode now). How to get the Angstrom desktop in this way?
3) Windows detects the "OMAP 3430" when I connect the beagleboard and ask me for drivers. Where could I find them?
4) I'm able to compile code on the host machine using Eclipse + QT. I compile for the processor of the host machine, indeed. How to configure the compiler for OMAP3430 cross-compilation? How to use Eclipse+RSE to download and debug code on beagleboard? I didn't find a tutorial on these concepts.
I thank you very much for any suggestion.
Marco
Hello!
1) Google Code Archive - Long-term storage for Google Code Project Hosting.
reading uImage
1856680 bytes read
reading rd-ext2.bin
3394477 bytes read
instead I get:
0 bytes read
reading rd-ext2.bin
3394477 bytes read
Before copying everything again, did you reformat the card? The above
is difficult to explain without some error in the uImage file.
2) BeagleBoardBeginners - eLinux.org - Angstrom
login
desktop
You can use a serial port connection to use a serial console. You can
also use USB networking and then Synergy (keyboard and mouse) or
X11VNC (keyboard, mouse, and display) to use the keyboard and mouse
from your desktop PC.
Beagleboard:Main Page - eLinux.org points to an application that
uses libusb to download code using the ROM bootloader that you are
seeing. I'm not aware of any drivers per se.
configure
these concepts.
I'm not familiar with the details of using Eclipse. In general, you
need to configure your compiler to target ARM Cortex-A8 and the
GNUEABI. There are many examples of how to call GCC to build for the
BeagleBoard. Hopefully someone with more Eclipse experience will add
to this.
Yes, of course. I used the HP USB Disk Storage Format Tool 2.0.6.
Ok, I’ll investigate on this.
to this.
So I need the CodeSourcery GNUEABI?
In this case I should be able to configure it because I used it for Luminary Micro (ARM Cortex-M3).
Anyway, if someone has any tips on this is welcome!
Marco
Jason Kridner said the following on 12/22/2008 07:47 AM:
Libusb was successfull in Linux, Not windows.. Windows might need a
filter driver.. See http://libusb-win32.sourceforge.net/ nothing much
has taken place in that community.. so numerous SPx could have made
things differently..
if anyone has experience with libusb-win32 and would like to help in
updating the board-recovery stuff.. do let us know the soln..
NM
