Here is the output when:
- SD inserted
- Boot/User button pressed (It looks like it is being ignored)
U-Boot SPL 2016.03-00001-g148e520 (Jun 06 2016 - 11:27:44)
Trying to boot from MMC
bad magic
U-Boot 2016.03-00001-g148e520 (Jun 06 2016 - 11:27:44 -0500), Build: jenkins-github_Bootloader-Builder-395
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
Could not get PHY for cpsw: addr 0
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
Scanning mmc 1:1…
1263 bytes read in 16 ms (76.2 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.4.9-ti-r25 …
7833256 bytes read in 446 ms (16.7 MiB/s)
loading /boot/dtbs/4.4.9-ti-r25/am335x-bonegreen-wireless.dtb …
61860 bytes read in 47 ms (1.3 MiB/s)
loading /boot/initrd.img-4.4.9-ti-r25 …
4828115 bytes read in 281 ms (16.4 MiB/s)
debug: [console=ttyO0,115200n8 root=UUID=2b96442f-bc55-493c-8e3d-4c599d12fbad ro rootfstype=ext4 rootwait init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3-bbgw.sh] …
debug: [bootz 0x82000000 0x88080000:49abd3 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x7786a8 ]
Loading Ramdisk to 8fb65000, end 8ffffbd3 … OK
Loading Device Tree to 8fb52000, end 8fb641a3 … OK
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.9-ti-r25 (root@b3-jetson-tk1-2gb) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP Thu May 5 23:08:13 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine model: TI AM335x BeagleBone Green Wireless
[ 0.000000] cma: Reserved 24 MiB at 0x9e000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] PERCPU: Embedded 13 pages/cpu @df923000 s24320 r8192 d20736 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129408
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=UUID=2b96442f-bc55-493c-8e3d-4c599d12fbad ro rootfstype=ext4 rootwait init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3-bbgw.sh
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 474012K/522240K available (7344K kernel code, 914K rwdata, 3704K rodata, 604K init, 907K bss, 23652K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0ad2480 (11050 kB)
[ 0.000000] .init : 0xc0ad3000 - 0xc0b6a000 ( 604 kB)
[ 0.000000] .data : 0xc0b6a000 - 0xc0c4e818 ( 915 kB)
[ 0.000000] .bss : 0xc0c51000 - 0xc0d33de8 ( 908 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000011] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000030] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000042] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000222] Console: colour dummy device 80x30
[ 0.000248] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 0.000255] This ensures that you still see kernel messages. Please
[ 0.000261] update your kernel commandline.
[ 0.000278] Calibrating delay loop… 995.32 BogoMIPS (lpj=1990656)
[ 0.046925] pid_max: default: 32768 minimum: 301
[ 0.047056] Security Framework initialized
[ 0.047070] Yama: becoming mindful.
[ 0.047101] AppArmor: AppArmor disabled by boot time parameter
[ 0.047256] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.047268] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.048045] Initializing cgroup subsys io
[ 0.048073] Initializing cgroup subsys memory
[ 0.048111] Initializing cgroup subsys devices
[ 0.048127] Initializing cgroup subsys freezer
[ 0.048143] Initializing cgroup subsys net_cls
[ 0.048156] Initializing cgroup subsys perf_event
[ 0.048170] Initializing cgroup subsys net_prio
[ 0.048185] Initializing cgroup subsys pids
[ 0.048241] CPU: Testing write buffer coherency: ok
[ 0.048291] ftrace: allocating 34073 entries in 67 pages
[ 0.133357] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.133478] Setting up static identity map for 0x80008240 - 0x8000828c
[ 0.136866] Brought up 1 CPUs
[ 0.136885] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.136893] CPU: All CPU(s) started in SVC mode.
[ 0.138307] devtmpfs: initialized
[ 0.157087] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.175146] omap_hwmod: debugss: _wait_target_disable failed
[ 0.228862] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.231051] xor: measuring software checksum speed
[ 0.270925] arm4regs : 1221.000 MB/sec
[ 0.310925] 8regs : 1094.000 MB/sec
[ 0.350922] 32regs : 1093.000 MB/sec
[ 0.390922] neon : 1759.000 MB/sec
[ 0.390930] xor: using function: neon (1759.000 MB/sec)
[ 0.391023] pinctrl core: initialized pinctrl subsystem
[ 0.392980] NET: Registered protocol family 16
[ 0.395643] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.396840] cpuidle: using governor ladder
[ 0.396860] cpuidle: using governor menu
[ 0.401800] OMAP GPIO hardware version 0.1
[ 0.413402] No ATAGs?
[ 0.413432] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.413974] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.413987] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.491091] raid6: int32x1 gen() 269 MB/s
[ 0.558999] raid6: int32x1 xor() 236 MB/s
[ 0.627034] raid6: int32x2 gen() 356 MB/s
[ 0.694966] raid6: int32x2 xor() 269 MB/s
[ 0.763012] raid6: int32x4 gen() 405 MB/s
[ 0.831021] raid6: int32x4 xor() 259 MB/s
[ 0.899067] raid6: int32x8 gen() 359 MB/s
[ 0.966936] raid6: int32x8 xor() 231 MB/s
[ 1.034933] raid6: neonx1 gen() 1458 MB/s
[ 1.102953] raid6: neonx1 xor() 846 MB/s
[ 1.170928] raid6: neonx2 gen() 1881 MB/s
[ 1.238943] raid6: neonx2 xor() 1172 MB/s
[ 1.306935] raid6: neonx4 gen() 1975 MB/s
[ 1.374931] raid6: neonx4 xor() 1203 MB/s
[ 1.442942] raid6: neonx8 gen() 1211 MB/s
[ 1.510922] raid6: neonx8 xor() 671 MB/s
[ 1.510929] raid6: using algorithm neonx4 gen() 1975 MB/s
[ 1.510936] raid6: … xor() 1203 MB/s, rmw enabled
[ 1.510942] raid6: using intx1 recovery algorithm
[ 1.520010] edma 49000000.edma: TI EDMA DMA engine driver
[ 1.525065] SCSI subsystem initialized
[ 1.525785] usbcore: registered new interface driver usbfs
[ 1.525854] usbcore: registered new interface driver hub
[ 1.525946] usbcore: registered new device driver usb
[ 1.526524] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 1.526568] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 1.526677] media: Linux media interface: v0.10
[ 1.526738] Linux video capture interface: v2.00
[ 1.526831] pps_core: LinuxPPS API ver. 1 registered
