Flashing Debian image from network
I have a SD card image, which I use to backup and restore emmc images from/to a network drive using dd. I wonder, if it is possible to flash Robert’s new Debian images in the same way instead of putting the flasher image onto an SD card and flash from this SD card? Can I use e.g. bone-debian-7.8-console-armhf-2015-02-22-2gb.img and dd it directly to the eMMC?
Regards
Axel
The emmc’s uuid would not be setup, creating interesting missing rootfs conditions on bootup when you have the microsd plugged in.
Can I do this manually? I assume I should find this in your flasher script, so just a short hint is sufficient.
Or any other idea, how to flash safely that way?
Thanks and regards
Axel
Von unterwegs gesendet
copy the uuid of the rootfs partition into /boot/uEnv.txt using the
uuid variable..
