flashing internal flash from SD card gives an error...
HI ,
Can anyone help with this error?
I have made an image from the internal flash of a BBB to SD card using the utility in /opt/scripp/tools/eMMC/
That seemed to work fine. I now insert this into a second BBB to flash that units flash and part way through boot the system hangs with the following diagnostics…
Starting eMMC Flasher
FIX:
Your new BBB contains a newer model of eMMC, this model is not support
on the 3.8.x kernel till 3.8.13-bone80 was released with these 2
patches:
https://github.com/RobertCNelson/bb-kernel/commit/bd5a1f38c99bbe712d21c1e145b0c660dca9dee7
Your options for the 3.8.x kernel are as follows:
1: Upgrade to 3.8.13-bone80
means what log says:
Error: [/dev/mmcblk1] does not exist
writing to [/dev/mmcblk1] failed…
Could be eMMC hardware issue, can be driver/kernel issue.
