I’m trying to flash the Angstrom image onto the internal flash when booted from a micro SD. I am getting an error:
No space left on device
I’m using the Cloud9-IDE-GNOME xz image. It should fit!
What am I doing wrong?
-Tom
-Tom
Which device is this? The eMMC or the SD card?
Booted from SD card, flashing the eMMC.
What instructions are you following? I suggest you use the ones found at http://circuitco.com/support/index.php?title=Updating_The_Software
I was using these: but will try the way you suggested…
It is the process that I am more concerned with.
Got it to flash, but it took like 2 hours.
-Tom
one thing you might want to do
power the bone from a external 5v power supply @ least 1amp
flashing the emmc while powered from the USB can allow it to fail
I am using an external 2 amp power supply.
-Tom
It flashed fine, btw.
Two hours??? Should not have taken more than 45 minutes for the actual flashing process. Unless, the SD card has some speed issues.
I didn’t time it, but it took a long time. The SD card is only class 4.
-Tom
So, is everything working so far?
It flashed fine. It boots into the desktop, but when I unplug the cable and plug it back in, the networking is gone. So it’s a bad board.
-Tom
Tom,
You might be experiencing the same problem that the rest of us are seeing…see this thread:
https://groups.google.com/d/msg/beagleboard/mfQwHdfHyoo/_Fo_LMaPiagJ
However, Gerald indicated that there have been a couple of bad PHY devices that have been found in the RMA process.
-Dale
Yes, I’m following that thread also. Seems that not many people are experiencing this issue. Must have gotten a bad batch or something…
-Tom
Yes, a couple. Go ahead and request an RMA on that board and let us put it on the treadmill.
I will. I just gotta find out from my boss where he bought the boards. I forgot where…
-Tom
Adafruit, that’s where! I found the box it was shipped in. RMA request sent…
-Tom
