Is there a way I can flash the binaries viz: x-load.bin, u-boot.bin, uImage, … on the Beagleboard’s NAND.
Is there a utility same as we use in android fastboot utility.
please suggest.
NARAYANA wrote:
Is there a way I can flash the binaries viz: x-load.bin, u-boot.bin, uImage, .. on the Beagleboard's NAND.
please suggest.
you can boot the beagleboard from usb or serial, search for "pusb" and "pserial"
once you get code uploaded and started this way, you can flash the NAND
