Freetype failed in "bitbake base-image" for building Angstrom
I am trying to build an Angstrom image for Beagleboard.
I followed the instructions in http://www.angstrom-distribution.org/building-angstrom
I am using Ubuntu 10.04.
Bitbake nano goes through. But bitbake console-image is stuck with the
following error.
/host/Pradeep/Angstrom/setup_scripts/build/tmp-angstrom_2008_1/
sysroots/x86_64-linux/usr/armv7a/lib/gcc/arm-angstrom-linux-gnueabi/
4.3.3/../../../../arm-angstrom-linux-gnueabi/bin/ld: skipping
incompatible /usr/lib/libc.so when searching for -lc
/usr/lib/libc.a: could not read symbols: File format not recognized
collect2: ld returned 1 exit status
arm-angstrom-linux-gnueabi-libtool: install: error: relink `/host/
Pradeep/Angstrom/setup_scripts/build/tmp-angstrom_2008_1/work/armv7a-
angstrom-linux-gnueabi/freetype-2.4.3-r0/freetype-2.4.3/objs/
libfreetype.la' with the above command before installing it
make: *** [install] Error 1
+ die 'oe_
NOTE: package freetype-2.4.3-r0: task do_install: Failed
Please show me some pointers to fix this.
Pradeep
