freeze on Uncompressing Linux... done, booting the kernel
plz people i just got my BeagleBoard XM rev B, trying to run ubuntu
netbook 10.10 OS
according to https://wiki.edubuntu.org/ARM/OMAPMaverickInstall
but it always freeze on Uncompressing Linux... done, booting the
kernel.
that a copy of run
Texas Instruments X-Loader 1.4.4ss (Sep 30 2010 - 14:44:32)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.09-rc1 (Sep 23 2010 - 11:20:00)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Beagle xM Rev A
Die ID #7eda00011ff00000015739eb0802602d
mmc1 is available
reading boot.scr
344 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
reading uImage
3687716 bytes read
reading uInitrd
6769443 bytes read
## Booting kernel from Legacy Image at 80000000 ...
   Image Name: Linux
   Data Size: 3687652 Bytes = 3.5 MiB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 81600000 ...
   Image Name: Ubuntu Initrd
   Image Type: ARM Linux RAMDisk Image (gzip compressed)
   Data Size: 6769379 Bytes = 6.5 MiB
   Load Address: 00000000
   Entry Point: 00000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
netbook 10.10 OS
kernel.
that a copy of run
6769443 bytes read
Image Name: Linux
OK
Starting kernel ...
This is not a bug, but the "DEFAULT" setting for their image, as documented at:
<quote>Notes about the process
An attached monitor, mouse and keyboard are expected for these images,
the installation process is all graphical after first reboot and the
images will boot into a graphical netbook session.</quote>
If you wish to change it, so it does output something, add
"console=ttyS2,115200n8" to your boot.scr
OR even:
<quote> The console is disabled by default, so don't be surprised to
see just "Uncompressing Linux... done, booting the kernel." at your
console. Please check https://wiki.ubuntu.com/ARM/BeagleEditBootscr to
understand how to activate it (on Panda just change ttyS2 to
ttyO2).</quote>
from the same site.. :wink:
Attach a monitor, be happy :slight_smile:
I struggled with the same problem for a long time before realizing the truth
