ftdi libftd2xx problem
I need to get the ftdi libftd2xx library installed on my beaglebone black.
But I have a problem. After installing as documented I got the following error message:
(from the EEPROM example)
./read
./read: error while loading shared libraries: libftd2xx.so: cannot open shared object file: No such file or directory
I double checked it is in /usr/local/lib/
and I also placed it in /usr/lib/
Knows someone a salutation?
evs <evanspronsen@...> writes:
Hi, I need to get the ftdi libftd2xx library installed on my beaglebone
black. But I have a problem. After installing as documented I got the
following error message: (from the EEPROM example)./read
libftd2xx.so: cannot open shared object file: No such file or directoryI
double checked it is in /usr/local/lib/ and I also placed it in
/usr/lib/ Knows someone a salutation?Thanks,
I am actually facing the same problem here with my BBB, the libraries under
both /usr/local/lib and /usr/local. Was wondering if you managed to fix
this? Anyone else?
